Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=e980b863-ca1f-4e22-bb6b-665a19ddff2d rw quiet apparmor=1
security=apparmor resume=UUID=3a5c48ea-fa12-4147-b57e-4dbdb9d07104
udev.log_priority=3
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: Timi product: TM1701 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Timi model: TM1701 v: MP serial: <filter> UEFI: INSYDE
v: XMAKB5R0P0502 date: 10/13/2017
ID-1: BAT0 charge: 36.0 Wh condition: 41.3/60.0 Wh (69%) volts: 8.6/7.6
model: SUNWODA R15B01W type: Li-ion serial: <filter> status: Charging
RAM: total: 7.66 GiB used: 2.98 GiB (38.9%)
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 8 MiB bogomips: 32012
Speed: 700 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 700 2: 700 3: 700
4: 700 5: 700 6: 700 7: 700 8: 700
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Xiaomi driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917 class ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Xiaomi Mi Notebook Pro
driver: N/A alternate: nouveau bus ID: 01:00.0 chip ID: 10de:1d12
class ID: 0302
Device-3: Chicony XiaoMi USB 2.0 Webcam type: USB driver: uvcvideo
bus ID: 1-6:3 chip ID: 04f2:b59a class ID: 0e02
Display: wayland server: X.Org 21.0.99.1 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: XWAYLAND0 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Xiaomi
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71 class ID: 0403
Sound Server: ALSA v: k5.10.15-1-MANJARO
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000
bus ID: 03:00.0 chip ID: 8086:24fd class ID: 0280
bus ID: 1-5:2 chip ID: 8087:0a2b class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 704.24 GiB used: 330.31 GiB (46.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: Extreme Pro 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 101200RL temp: 30.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: MZVLW256HEHP-00000
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: CXB7401Q temp: 20.9 C
scheme: GPT
ID-1: / raw size: 456.66 GiB size: 448.5 GiB (98.21%)
used: 330.31 GiB (73.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: e980b863-ca1f-4e22-bb6b-665a19ddff2d
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 592C-3652
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 3a5c48ea-fa12-4147-b57e-4dbdb9d07104
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 499 MiB fs: ntfs label: N/A
uuid: A68E15988E15625B
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 100 MiB fs: vfat label: N/A
uuid: A27D-5F71
ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p4 maj-min: 259:8 size: 237.87 GiB fs: ntfs label: N/A
uuid: 40AE7F22AE7F0FA0
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-5:2 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2b
class ID: e001
Device-2: 1-6:3 info: Chicony XiaoMi USB 2.0 Webcam type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b59a
class ID: 0e02
Device-3: 1-7:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 class ID: ff00
serial: <filter>
Device-4: 1-8:5 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 04f3:0c1a
class ID: 0000
Device-5: 1-9:6 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 25a7:fa23 class ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 287 Uptime: 4h 46m wakeups: 7 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: 2195 pacman: 2147 lib: 493 flatpak: 35
snap: 13 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.3.01
I dual boot Manjaro gnome and Windows 10 on my laptop. I have an external microphone, but when I plug it in to the combined audio jack on my notebook, it gets detected as a headphone, and I am unable to use the microphone. The Microphone works on Windows, so I assume this is a software issue.
