My laptop (Asus X200-CA) connected to an LG 27GL650 monitor is being identified as “Goldstar Company Ltd. 24”! The monitor is being driven at only 60Hz maximum (through HDMI), when it actually supports 144Hz! The monitor works fine at the advertised frequency with other Windows 10 machines that I use it with.
Is it possible to change any configuration to effect the refresh rate the monitor is actually capable of?
I can create a /etc/X11/xorg.conf.d/90-monitor.conf file and feed identification, but I don’t know how to fix the refresh rate.
Here’s the output of inxi -Fazy:
Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=8ec7d842-f0bc-45ad-8743-df2a7acfe3c2 rw quiet
resume=UUID=6af34573-65b2-408b-80f1-726fc9375780
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: X200CAP v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X200CAP v: 1.0 serial: <filter>
UEFI: American Megatrends v: X200CAP.205 date: 09/18/2013
ID-1: BAT0 charge: 24.7 Wh condition: 25.2/33.5 Wh (75%) volts: 11.3/11.3
model: ASUSTeK X200-30 type: Li-ion serial: N/A status: Unknown cycles: 328
Device-1: hidpp_battery_0
model: Logitech Wireless Mobile Mouse MX Anywhere 2S serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
Topology: Dual Core model: Intel Core i3-3217U bits: 64 type: MT MCP
arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 14373
Speed: 798 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
4: 798
Type: l1tf
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 2-4:3 chip ID: 0bda:5603 serial: <filter>
Display: x11 server: X.Org 1.20.8 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.1.6 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.8.3-2-MANJARO
Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Foxconn
driver: rt2800pci v: 2.3.0 port: f040 bus ID: 02:00.0 chip ID: 1814:3290
IF: wlp2s0f0 state: up mac: <filter>
Device-2: Qualcomm Atheros QCA8172 Fast Ethernet vendor: ASUSTeK driver: alx
v: kernel port: e000 bus ID: 03:00.0 chip ID: 1969:10a0
Local Storage: total: 236.00 GiB used: 68.53 GiB (29.0%)
ID-1: /dev/sda vendor: KingSpec model: ACSC2M256S25 size: 236.00 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 0529 scheme: GPT
ID-1: / raw size: 227.87 GiB size: 223.30 GiB (97.99%)
used: 68.53 GiB (30.7%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 7.83 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 59.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3200
Processes: 186 Uptime: 18m Memory: 3.55 GiB used: 1.40 GiB (39.5%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1451 lib: 424 flatpak: 0 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.05
Here’s the output of xdpyinfo | grep -B2 resolution:
screen #0:
dimensions: 1920x1080 pixels (508x286 millimeters)
resolution: 96x96 dots per inch
depths (7): 24, 1, 4, 8, 15, 16, 32
root window id: 0x135
Searched around in the forums, but links of interest report a " Oops! That page doesn’t exist or is private." error (Manjaro’s forum is not allowing to include links).
Would be great if anyone can help with the issue. Thanks in advance.
Note: Am new to the Manjaro forum. Since there’s no monitor category, I chose ‘Graphics Cards & HDPI’. If this requires to be moved elsewhere, please let me know.
