uname -a
Linux kamal-20hjs1c700 5.18.14-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sun Jul 24 09:00:58 UTC 2022 x86_64 GNU/Linux
extension dash to dock not working, also Material Shell
any idea ??
uname -a
any idea ??
You did what this person did
Please stop mixing extensions from repository with the ones from AUR or from extensions site. Material-shell extension works fine on my end, the one provided in repository.
i already check this before, but not working, what do u mean stop mixing, but default manjaro download this extension from so i uninstall from official repositories then i install from AUR but still not working
I know for sure that material-shell extension from our repository is working perfectly fine. Make sure you do not have any leftovers in ~/.local/share/gnome-shell/extensions/material-shell@papyelgringo
or something, also make sure you do not run some other extension that might not be compatible with it.
@bogdancovaciu I fixe this issue with alt+F2 then tap r and execute the command and it s working, before i reboot the pc and it s weird if not working after restarting system, finally thank u for u time + help
