Ext HDD and KDE
I went over to KDE from XFCE since Steam will launch from XFCE. My Ext HDD keeps unmounting at random. Didn’t have this issue with Xfce.
The Drive is a Seagate 4TB. Flash sticks work fine.
Add a record for the drive to /etc/fstab, and be sure to add nofail to the mount options.
Don’t know what put down for the record. The drive has an off switch and I turn it off when not in use.
UUID=the-uuid-of-the-partition   /where/to/mount/it   filesystem-type   noauto,nofail,user,other-mount-options-here   0   0
  • If it’s ext4, then you can use noauto,nofail,defaults,user as the mount options.
  • If it’s NTFS, use ntfs-3g as the filesystem type, and noauto,nofail,uuid=1000,gid=1000,utf8,user as the mount options.
  • You can find out the UUID by way of… :arrow_down:
lsblk -o NAME,UUID,MOUNTPOINT
That’s okay, as long as it’s got the nofail mount option.
