ExpressVPN extensions chrome
anyone help me why expressvpn extension in chrome not working , error app not found but successfully installed expressvpn app in manjaro os, and i can connect to USA or other server
(…) but successfully installed expressvpn app in manjaro os, and i can connect to USA or other server
So you already have an active vpn connection, no need extension in your browser
but I want GUI interface , expressvpn extension works like full in pc. not only in chrome. expressvpn live chat also says if you want GUI interface for linux you can install extension
Maybe here in the web store is what you search ? (i let you search the english page):
ok but expressvpn extension already installed, you can see that in screen shot
Here, read this fully and you should be able to.
already followed all tutorial but extension not detecting expressvpn app
extension not detecting expressvpn app . i tried chrome, brave , firefox . not working
Yes really frustrating. ExpressVPN extension had never worked for me on Manjaro with Brave browser. Yes it worked with Chrome and Firefox (and obviously the desktop app was installed and working).
For the first time though, today I noticed it is working on Brave Stable Version 1.33.106 Chromium: 96.0.4664.110 (Official Build) (64-bit). I never re-installed it, and know it was not working before.
But on my Brave Nightly Version 1.36.4 Chromium: 97.0.4692.56 (Official Build) nightly (64-bit) still not working. Tried uninstalling, closed browser, re-opened and re-installed the extension. Tried also copying extension folder over from Brave Stable. No luck - just says ‘App Not Found’.
It’s very frustrating. I did just write an app at GitHub - Danie10/warp-cli-gui: GUI app to read settings and stats from Cloudflare WARP CLI for Linux, and change some settings for Cloudflare WARP which is similar to what ExpressVPN does, and if there is any interest, I could whip one together for ExpressVPN. It just interacts with the CLI to connect, disconnect, show status, change some settings, and maybe choose alternative locations to connect to (browser independent). But won’t be a browser extension per se. But maybe firing up Firefox or Chrome may still be good for most folks.
First off … browser extensions are just that - they wont have any effect on the rest of your system.
But I could also mention there are at least 2 different express vpn GUI packages in the AUR.
Here is a possible solution to having a similar GUI as the browser extension, but it runs independently on the desktop - it’s working for me. See https://github.com/bourretbrandon/expressvpn-gui. And also a Python based one at Vojko Pribudić / expressvpn-gui · GitLab.
how you fixed this? i tried how many time i don’t know. with many restarts but never work.
and i tried expressvpn stable and expressvpn BETA both are not working , firefox and chrome.
please tell me how you installed and it worked you say so tell me step by step :slightly_smiling_face:
