I haven’t had time to use the PBP much lately. Let alone make checks on Wayfire specifically.
But improvements on that image are definitely on my mind
PS:
For stability… Personally, I find it more stable than Plasma or XFCE. I compile stuff only in tty2 or Wayfire. It’s not feature rich (cough, I use nmtui for wifi connection as there is no widget, cough) but I have no complaints when it comes to being stable
I don’t use Wifi on this device, as I have an ethernet available, but I do use USB headphones, which works flawlessly.
It is just the onboard audio cards, that are not present.
I am doing the same experiment at the moment but with a raspi 4b 4gb. Ssd connected to usb3 and you have enough storage space. But I would like to have a little bit more cpu power. The odroid n2+ looks nice but unfortunately it has only 1 hdmi out and I have a 2 screen setup.
Not a bad compromise, although I can’t say as I’ve tried it. I use a Pinebook Pro most days, and the only downsides to that are the keyboard and trackpad. Otherwise, it’s the same CPU and GPU as the Rock Pi 4C.
According Ubuntu 20.10 for ODROID-N2/C4/HC4 from brad. I was looking for solution to get sound on GT King Pro not sure it will work on GT King Pro but it seems to work on Odroid N2.
So far, I haven’t run into any issues with it. As it’s not a mobile setup, I don’t really care much about effecient cores, so the more performance cores the better.
Any updates here? Trying to understand the difference between panfrost and bifrost. Was thinking about getting a n2+ simply to get a a73 setup to play with. I’ve been daily driving a RPI4b with Manjaro and it has literally full support for all the hardware and has been a dream, but I could do with more single core and some more cores couldn’t hurt either. Been considering my next step being one of these a73 boards such as the vim3, odroid n2+, or hikey 970 (although the 970 is dumb expensive).
