Experiencing issues with Peripherals
I’m new to Manjaro and Linux in general and recently switched from Windows 10 and was encountering two issues I couldn’t find a fix for on my own:
  • upon restart, mouse and keyboard (that being a logitech g305 and an HP Pavillon 600), won’t respond for a variable amount of time, sometimes just for a minute, sometimes for more than 10. I was wondering if there was a script I could force the machine to run to make it check for wireless peripherals or something like that, but I lack the technical to skill to know whether that’s a sensible, viable or possible solution, and wouldn’t know how to do it.
  • the headphones: at random intervals, then they’ll stop receiving sound for a few (10-30) seconds, and then be disconnected and quickly reconnected until the process begins again.
Including the result of inxi --admin --verbosity=7 --filter --no-host, as I was told it’s helpful:
System:    Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=8e9b0aaf-d336-4cab-8a4e-cf5e4016e269 rw
           quiet apparmor=1 security=apparmor resume=UUID=040a6917-7067-4f9c-a01e-10311812ee47
           udev.log_priority=3
           Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux
           base: Arch Linux
Machine:   Type: Desktop System: Micro-Star product: MS-7C79 v: 1.0 serial: <filter>
           Mobo: Micro-Star model: MPG Z490 GAMING EDGE WIFI (MS-7C79) v: 1.0 serial: <filter>
           UEFI: American Megatrends v: 1.30 date: 10/12/2020
Battery:   Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming Mouse serial: <filter>
           charge: 100% (should be ignored) rechargeable: yes status: Discharging
Memory:    RAM: total: 15.49 GiB used: 8.25 GiB (53.3%)
CPU:       Info: 6-Core model: Intel Core i5-10600K bits: 64 type: MT MCP arch: Comet Lake family: 6
           model-id: A5 (165) stepping: 5 microcode: E2 cache: L2: 12 MiB bogomips: 98441
           Speed: 4500 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 4500 2: 4500 3: 4500 4: 4500 5: 4500
           6: 4500 7: 4500 8: 4500 9: 4500 10: 4500 11: 4500 12: 4500
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon art avx
           avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
           dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp
           hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm
           lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
           pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg
           sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
           tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics:  Device-1: Intel vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc5
           class-ID: 0300
           Device-2: Microdia PC-LM1E type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1:2 chip-ID: 0c45:636d
           class-ID: 0102 serial: <filter>
           Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
           alternate: fbdev,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
           Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24")
           OpenGL: renderer: Mesa Intel UHD Graphics 630 (CML GT2) v: 4.6 Mesa 21.0.3 direct render: Yes
Audio:     Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
           Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.27 running: yes
Network:   Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 4000 bus-ID: 00:14.3
           chip-ID: 8086:06f0 class-ID: 0280
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
           Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000
           bus-ID: 02:00.0 chip-ID: 10ec:8125 class-ID: 0200
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:8 chip-ID: 8087:0026 class-ID: e001
Logical:   Message: No logical block device data found.
RAID:      Message: No RAID data found.
Drives:    Local Storage: total: 931.51 GiB used: 85.57 GiB (9.2%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
           block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter>
           rev: 2B2QEXM7 temp: 40.9 C scheme: GPT
Partition: ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%) used: 85.53 GiB (9.4%) fs: ext4
           dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A uuid: 8e9b0aaf-d336-4cab-8a4e-cf5e4016e269
           ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 296 KiB (0.1%) fs: vfat
           dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL uuid: 2786-03A3
Swap:      Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8.8 GiB used: 43.5 MiB (0.5%) priority: -2 dev: /dev/nvme0n1p3
           maj-min: 259:3 label: N/A uuid: 040a6917-7067-4f9c-a01e-10311812ee47
Unmounted: Message: No unmounted partitions found.
USB:       Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
           Device-1: 1-1:2 info: Microdia PC-LM1E type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4
           rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0c45:636d class-ID: 0102 serial: <filter>
           Device-2: 1-7:3 info: Primax HP Wireless Keyboard Mouse Kit type: Keyboard,HID,Mouse
           driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0461:4e90
           class-ID: 0301
           Device-3: 1-8:4 info: Logitech USB Receiver type: Keyboard,Mouse,HID
           driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
           chip-ID: 046d:c53f class-ID: 0300
           Hub-2: 1-11:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s power: 100mA
           Device-1: 1-12:7 info: Micro Star MYSTIC LIGHT type: HID driver: hid-generic,usbhid interfaces: 1
           rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 1462:7c79 class-ID: 0300 serial: <filter>
           Device-2: 1-14:8 info: Intel type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
           power: 100mA chip-ID: 8087:0026 class-ID: e001
           Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
           Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
           Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s chip-ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 41.0 C mobo: N/A
Info:      Processes: 322 Uptime: 13h 20m wakeups: 6 Init: systemd v: 247 tool: systemctl Compilers: gcc: 10.2.0
           Packages: 1269 pacman: 1255 lib: 333 flatpak: 5 snap: 9 Shell: Bash v: 5.1.8 running-in: konsole
           inxi: 3.3.04
:+1: Welcome to Manjaro! :+1:
Thank you for providing the inxi output and I started editing it as it seems malformatted, so please:
  • Run the same inxi again
  • edit your post by pressing the and then the pencil
  • paste the inxi output as is in-between the two ```
as that is going to take you 10 seconds, whereas it’s going to take me 10 minutes to untangle the spaghetti that your output is right now. Then it’ll be more readable…
Then :heart: this post and I’ll have another look!
is it good now?
  1. You seem to have a wireless mouse. Can you try a wired one first and see if it happens there too?
  2. Have a look if there is a BIOS / UEFI firmware update first
  3. Try 5.4 LTS or 5.12 stable and see if it goes away all by itself there. If it does, delete 5.10
:crossed_fingers:
