I recently bought a used HP ProBook 6460b in order to convert it into a machine to do some coding. I installed the latest Manjaro XFCE Edition on it.
In order to make my life easier, i wanted to get manjaro to mount my network share automatically, but only when im at home.
so i did the following
create an .smbcredentials file
create a target folder in /mnt
test a command to mount the drive in the target folder
move .smbcredentials to / and change ownership to root
chmod 600 . smbcredentials
test the mount command again.
until this point, no problem.
in order to check if i am home or not and than mount the drive, i created the following script
/usr/local/bin/fritzmount.sh
#!/bin/bash
sleep 30s
if [[ $(/usr/bin/arping -c 1 192.168.178.1|cgrep -i --color --no-numbers "F0:B0:XX:XX:XX:XX") ]]; then
mount -t cifs -o credentials=/.smbcredentials,vers=1.0,noserverino //192.168.178.1/FRITZ.NAS/Nas/user /mnt/fritznas/
else
echo "not found"
fi
and that script seems to work too
i finally created a .service file with the following content
[Unit]
# Type=simple|forking|oneshot|dbus|notify|idle
Description=Automount for Fritz Nas
## make sure we only start the service after network is up
Wants=network-online.target
After=network.target
[Service]
## here we can set custom environment variables
Type=oneshot
User=root
WorkingDirectory=/usr/local/bin
ExecStart=fritzmount.sh
StandardOutput=append:/mount.log
StandardError=append:/mounterror.log
# don't use 'nobody' if your script needs to access user files
# (if User is not set the service will run as root)
#User=nobody
# Useful during debugging; remove it once the service is working
#StandardOutput=console
[Install]
WantedBy=multi-user.target
and ran
sudo systemd-analyze verify automount_fritzbox.service
wich passed without problems
However, after restarting the pc, the drive was not mounted.
No matter where i look, i cant seem to figure out why and as such i turn to you for insight.
Heres the journal output, looks like the script got executed
↪ journalctl -u automount_fritzbox.service 14:06:31
-- Journal begins at Thu 2021-01-14 20:31:50 CET, ends at Wed 2021-01-20 14:07:44 CET. --
Jan 18 19:13:08 jerome-devstation systemd[1]: /etc/systemd/system/automount_fritzbox.service:21: Failed to parse output specifier, ignoring: console
Jan 18 19:17:14 jerome-devstation systemd[1]: /etc/systemd/system/automount_fritzbox.service:22: Failed to parse output specifier, ignoring: console
-- Boot 7eaa771c1b294e0b8ea17e04d8cc9a57 --
Jan 18 19:22:37 jerome-devstation systemd[1]: Starting Automount for Fritz Nas...
Jan 18 19:22:50 jerome-devstation systemd[1]: automount_fritzbox.service: Succeeded.
Jan 18 19:22:50 jerome-devstation systemd[1]: Finished Automount for Fritz Nas.
Jan 18 19:26:25 jerome-devstation systemd[1]: Starting Automount for Fritz Nas...
Jan 18 19:26:27 jerome-devstation systemd[1]: automount_fritzbox.service: Succeeded.
Jan 18 19:26:27 jerome-devstation systemd[1]: Finished Automount for Fritz Nas.
Jan 18 19:30:40 jerome-devstation systemd[1]: /etc/systemd/system/automount_fritzbox.service:22: Failed to parse output specifier, ignoring: console
-- Boot 7978e997ddc14c10a4f9a4033a07ef82 --
Jan 18 19:37:41 jerome-devstation systemd[1]: Starting Automount for Fritz Nas...
Jan 18 19:38:37 jerome-devstation systemd[1]: automount_fritzbox.service: Succeeded.
Jan 18 19:38:37 jerome-devstation systemd[1]: Finished Automount for Fritz Nas.
-- Boot 2bc140dad13549b184c78ddab9484299 --
Jan 18 19:43:38 jerome-devstation systemd[1]: Starting Automount for Fritz Nas...
Jan 18 19:44:32 jerome-devstation systemd[1]: automount_fritzbox.service: Succeeded.
Jan 18 19:44:32 jerome-devstation systemd[1]: Finished Automount for Fritz Nas.
Jan 18 19:50:40 jerome-devstation systemd[1]: Starting Automount for Fritz Nas...
Jan 18 19:51:12 jerome-devstation systemd[1]: automount_fritzbox.service: Succeeded.
Jan 18 19:51:12 jerome-devstation systemd[1]: Finished Automount for Fritz Nas.
-- Boot 10d9edff1477428b8cb63c140e2e5a36 --
Jan 20 11:38:40 jerome-devstation systemd[1]: Starting Automount for Fritz Nas...
Jan 20 11:39:17 jerome-devstation systemd[1]: automount_fritzbox.service: Succeeded.
Jan 20 11:39:17 jerome-devstation systemd[1]: Finished Automount for Fritz Nas.
-- Boot 92e6e0eacef4449bbcff089ab876e7a4 --
Jan 20 13:35:44 jerome-devstation systemd[1]: Starting Automount for Fritz Nas...
Jan 20 14:01:36 jerome-devstation systemd[1]: automount_fritzbox.service: Succeeded.
Jan 20 14:01:36 jerome-devstation systemd[1]: Finished Automount for Fritz Nas.
sulumar at jerome-devstation in /m/fritznas
however, ls -la
[sulumar@jerome-devstation]
[14:11:36 fritznas]$ ls -la
insgesamt 8,0K
drwxr-xr-x 2 root root 4,0K 18. Jan 19:45 .
drwxr-xr-x 3 root root 4,0K 18. Jan 19:45 ..
it seems its still not mounted
i checked the mounterror.log and found this
↪ cat mounterror.log
/usr/bin/arping: NETLINK_ROUTE unexpected iov element
my best guess is the arping goes off before the wifi connection is established
i tried to get the script to check by pinging the router and waiting for a reply but i cant get the bash script to work propperly.
Hell, it cant be that difficult to check for a working network connection. i must be missing something.
Here is the bash script i wrote, but that wont even run manually
throws out
.> /fritzmount.sh: Zeile 3: [: syntax error: `-q’ unexpected
./fritzmount.sh: Zeile 3: 20: Datei oder Verzeichnis nicht gefunden
./fritzmount.sh: Zeile 9: [: Fehlende »]«
before proceeding to try and mount the drive, if connected
if not connected or not on my home network it pings indefinitely
i=0
while [ ! ping -q -c 1 -W 1 192.168.178.1 >> /dev/null ] || [ i < 20 ]; do
let "i = i+1"
sleep 1
done
if [ i >= 20]; then
echo "Network Down"
else
if [[ $(/usr/bin/arping -c 1 192.168.178.1|cgrep -i --no-numbers "F0:B0:14:57:E5:21") ]]; then
mount -t cifs -o credentials=/.smbcredentials,vers=1.0,noserverino //192.168.178.1/FRITZ.NAS/Nas/Jerome /mnt/fritznas/
else
echo "not home"
fi
fi
you’d think that after coding some C, some java and some python, id grasp bash but obviously not
