I have a bash script that adds a custom resolution to my monitor. (77hz instead of 60hz)
however I added it to settings-autostart but I won’t start after the pc boots. I know the script works because I can still just right click and execute it manually.
Is there anything I can change or add here to make it start after boot?
thank you!
P.S.: I found a similar problem, but this guy’s solution didn’t work for me.
Bonus question: will xrandr (and this script) still work if I change to wayland in the future?
And no, xrandr will not work under wayland.
If you need the script to start later, place sleep 5
above the main command, and that will delay it 5 seconds with my example.
Or create a desktop file as mentioned here
and add it to ~/.config/autostart/
or maybe the sh script file directly to ~/.config/autostart-scripts/ but i can’t guarantee … never used that ever.
Hey thanks so much, I didn’t such a good answer.
As I am not really good with scripts in general and because it took me ages to figure out how to create custom resolutions, this will be my weekend project.
But I will let you know if it worked, you have given me plenty of options, thanks for that!
