Since the last major update the laptop consumption during sleep mode has increased a fair bit (going from 20% to 30% in 24h or so). The USB devices hooked on the USB now remain powered despite the bios specifying that power to USB ports should be turned off when sleeping. That’s also a new behaviour since the update.
My inxi -Fza output:
System: Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=4fc9ec4c-2db3-4009-89d9-131f97cbc022 rw quiet
resume=UUID=12be5ddb-10e3-4ad8-ae1e-164a24687f25 apparmor=1 security=apparmor sysrq_always_enabled=1
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: SAMSUNG product: 700Z3C/700Z5C v: 0.1 serial: <filter> Chassis: type: 9 v: 0.1
serial: <filter>
Mobo: SAMSUNG model: 700Z3C/700Z5C v: FAB1 serial: <filter> UEFI [Legacy]: Phoenix v: P02AAG date: 04/26/2012
Battery: ID-1: BAT1 charge: 41.4 Wh condition: 51.8/65.1 Wh (80%) volts: 15.7/14.8 model: SAMSUNG Electronics type: Li-ion
serial: N/A status: Unknown
CPU: Info: Dual Core model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19963
Speed: 1358 MHz min/max: 1200/3100 MHz Core speeds (MHz): 1: 1686 2: 1892 3: 2102 4: 1707
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0166
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] vendor: Samsung Co driver: N/A
alternate: nouveau bus ID: 01:00.0 chip ID: 10de:1140
Device-3: Silicon Motion WebCam SC-13HDL11431N type: USB driver: uvcvideo bus ID: 2-1.4:4 chip ID: 2232:1018
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting alternate: fbdev,intel,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 928x285mm (36.5x11.2") s-diag: 971mm (38.2")
Monitor-1: LVDS-1 res: 1600x900 hz: 60
Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3") diag: 584mm (23")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.2.2 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Samsung Co driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.8.18-1-MANJARO
Network: Device-1: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel port: 3000 bus ID: 02:00.0 chip ID: 8086:088e
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Samsung Co driver: N/A modules: r8169
port: 2000 bus ID: 03:00.0 chip ID: 10ec:8168
Drives: Local Storage: total: 938.98 GiB used: 590.15 GiB (62.9%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0002 scheme: MBR
ID-2: /dev/sdb vendor: SanDisk model: iSSD P4 8GB size: 7.46 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s serial: <filter> rev: 9.14 scheme: MBR
Partition: ID-1: / raw size: 195.31 GiB size: 191.25 GiB (97.92%) used: 132.25 GiB (69.1%) fs: ext4 dev: /dev/sda3
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 7.72 GiB used: 1.79 GiB (23.1%) priority: -2 dev: /dev/sda8
Sensors: System Temperatures: cpu: 82.0 C mobo: 29.8 C
Info: Processes: 257 Uptime: 9d 5h 34m Memory: 7.56 GiB used: 5.04 GiB (66.7%) Init: systemd v: 246 Compilers:
gcc: 10.2.0 alt: 8 clang: 11.0.0 Packages: pacman: 1974 lib: 467 flatpak: 0 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.08
