Evolution doesn't load calendar and task data
Since this morning, July 1st 2023, upon start Evolution (3.48.1) doesn’t load the calendar and task data anymore. The data is all on my local HD. On first start, Evolution tried to load the data and then showed a timeout error message. After reboot and on second try, it looks like it doesn’t even try to load the data.
Yesterday everything worked fine. Mail and contacts are loaded properly. Any ideas where to start looking? Thanks!
I’m stupid. The check boxes for the different calendars and task lists were simply unchecked, and I didn’t notice.
I would still like to know why that happened overnight though…
