Evince is too slow to open in xfce. Why?
There any best alternative to xfce, while this problem is not solved?
Please, I use Manjaro xfce all the time.
Look for xdg-desktop-portal in the installed packages. If you see xdg-desktop-portal-gnome - deinstall it and install xdg-desktop-portal-gtk instead.
Hello, Teo! Thank you!
I have both installed.
Hello, Teo!
I remove xdg-desktop-portal-gnome and it seems ok now.
I loose your last message, because I did not click in Activate button. Can I recover it?
Thank you!
