I don’t know where to start…When I start copying files which sizes like 1 gig/500 mb, the pc lags…it’s massively slows down even mouse pointer…when files r completely copies/moved, the pc becomes normal…
I searched solution about it…I get wiki about vm.dirty.ratio and vm.dirty.background but I don’t understand them…but I changed it to a article after first installation of Manjaro Gnome…
I didn’t had that problem in kde neon, ubuntu
Please post your system info as outlined here:
Welcome to Manjaro!
To allow all of us helpful gurus on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone probably linked you to this tutorial, so if you’re reading this in response to a question, please click the green link above this text to bring you to the full and unabridged text of the tutorial…
Kernel: 5.4.108-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=58be6df1-4173-425c-bb5f-e8585e518acd ro quiet udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 3.38.2.1
Type: Portable System: Dell product: Inspiron N4050 v: N/A serial: <filter>
Chassis: type: 8 serial: <filter>
Mobo: Dell model: 0X0DC1 v: A09 serial: <filter> BIOS: Dell v: A09
date: 11/02/2012
RAM: total: 3.76 GiB used: 1.54 GiB (41.1%)
Info: Dual Core model: Intel Core i3-2310M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
cache: L2: 3 MiB bogomips: 16768
Speed: 798 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
4: 798
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx
monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs
pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer
vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: Realtek Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:4 chip-ID: 0bda:58c1 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 21.0.1 compat-v: 3.0 direct render: Yes
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.4.108-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter
vendor: Hewlett-Packard driver: wl v: kernel modules: bcma port: e000
bus-ID: 09:00.0 chip-ID: 14e4:4727 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
Message: No Bluetooth data was found.
Message: No LVM data was found.
Local Storage: total: 465.76 GiB used: 27.92 GiB (6.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A scheme: GPT
Optical-1: /dev/sr0 vendor: MATSHITA model: DVD+-RW UJ8B1 rev: D.05
dev-links: cdrom
ID-1: / raw-size: 15 GiB size: 14.71 GiB (98.01%) used: 11.23 GiB (76.3%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 58be6df1-4173-425c-bb5f-e8585e518acd
ID-2: /home raw-size: 45.53 GiB size: 44.56 GiB (97.88%)
used: 16.69 GiB (37.5%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: d4712707-27f4-4b68-a587-ece89f82f88b
Kernel: swappiness: 10 (default 60) cache-pressure: 70 (default 100)
ID-1: swap-1 type: file size: 1.5 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 8 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda5 maj-min: 8:5 size: 93.13 GiB fs: ext4 label: Rakin
uuid: 991d4bc0-8150-4947-b570-667f5dbe2eb9
ID-3: /dev/sda6 maj-min: 8:6 size: 93.13 GiB fs: ext4 label: Entertainment
uuid: 2a4331b1-4da5-4503-a171-bb916cf52ebb
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.2:3 info: Xiaomi Mi Wireless Combo type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 2717:5010 class-ID: 0301
Device-2: 1-1.5:4 info: Realtek Integrated Webcam type: Video
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Device-1: 2-1.6:3 info: Realtek RTS5138 Card Reader Controller
type: Mass Storage driver: ums-realtek interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0bda:0138 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 54.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2922
Processes: 214 Uptime: 12m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1142 lib: 364 flatpak: 0 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.03
You could maybe try to put some parameters to their default values, like swappiness.
What i notice is that your kernel will start swapping when you have almost no RAM available, so your swap will be used for pretty much everything at this stage.
Do you have this behavior all the times ? I mean, if you copy your 1Go file straight at start, with no application running (browser…), what would happen ?
This issue is new or do you have it from the time you installed Manjaro ?
Did you try to change your kernel with 5.10 or 5.11 ?
Even if I don’t open any application except nautilus at start, same problem goes on!
I have the problem from beginning when I installed Manjaro…!
Well I should try changing kernel with 5.10…I’ll let u know
P.S.:- Should I increase swappiness!? I run Manjaro with hdd, no ssd!
Hey it worked with 5.10 LTS…
Everything works, nothing slows down except sometimes little bit of sluggish but thats okay!
What should I do with 5.4 LTS? I have new update of these two!
Well, you can delete it if it causes issues.
You could also get the 5.11 to see if it’s better than 5.10, and then you decide the one you keep running.
Personally, i have both 5.10 and 5.11 installed but 5.11 running because it’s fine for me.
Last question :- I have older hardware running…
Old CPU, old GPU and old hdd…will I have any problem running 5.11?
Not necessarily, i have a Haswell cpu, so it’s quite old too.
Anyway, you can install and run it, and go back to 5.10 LTS if you experience issues. It’s easy with Manjaro Settings Manager. Or stay with 5.10 if you are happy with it.
Riggs
20 April 2021 12:35
10
That’s the best way at this time. I did the same a few days ago
Tnx for ur suggestion mate!
system
Closed
6 May 2021 10:31
12
