as the title says, and i need to remove and reinstall it for it to work again.
i tried flatpak repair
,but it doesn’t fix it.
it’s been like that for 3 or 4 updates.
any ideas?
Not the solution to your problem but have you tried using zoom from the aur instead?
no i haven’t and there seems to be quit some traffic in the comment section there for various issues.
i generally tend to avoid AUR packages as i don’t really know what a certain PKGBUILD really does,
even though i try to check them before hand to make sure their safe.(but my knowledge in this matter is very limited).
edit:
im my previous post around a month ago,someone suggested to:
" download the package from the zoom download webpage and run the following command with pacman, which I found in the man pages.
pacman -U /home/user/zoom_x86_64.pkg.tar.gz Install zoom package from a local file.
I’m not sure it’s a good idea installing apps from outside the repositories right?
I’m certainly not an expert but the instructions here
Are for manjaro + arch so I think it should be pretty safe
If you don’t trust AUR, why do you trust flatpak? Conceptually, they are equal.
Did you try running it from the terminal and retrieve the output?
flatpak run -v us.zoom.Zoom
@sawdoctor
i might try that,but how does it gets updated,i have a feeling it will create a whole mess in the PC.
@mithrial
F: No installations directory in /etc/flatpak/installations.d. Skipping
F: Opening system flatpak installation at path /var/lib/flatpak
F: Opening user flatpak installation at path /home/usrname/.local/share/flatpak
F: Opening user flatpak installation at path /home/username/.local/share/flatpak
F: Cleaning up unused container id 288489891
F: Allocated instance id 2186594225
F: Add defaults in dir /us/zoom/Zoom/
F: Add locks in dir /us/zoom/Zoom/
F: Allowing x11 access
F: Allowing pulseaudio access
F: Pulseaudio user configuration file '/home/username/.config/pulse/client.conf': Error opening file /home/username/.config/pulse/client.conf: No such file or directory
F: Running 'bwrap --args 38 xdg-dbus-proxy --args=41'
F: Running 'bwrap --args 38 zoom'
journalctl -p 3 -xb
systemd-coredump[1897]: Process 1854 (zoom) of user 1000 dumped core.
Stack trace of thread 3:
#0 0x00007f1286ae97f5 n/a (n/a + 0x0)
░░ Subject: Process 1854 (zoom) dumped core
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 1854 (zoom) crashed and dumped core.
this time a system shutdown fixed it.(in addition to the reboot after the update)
i think it’s related to the nvidia updates;
i ran “flatpak repair” and it shows:
Verifying flathub:runtime/org.freedesktop.Platform.GL.nvidia-460-80/x86_64/1.4
but my Nvidia version is 465,since the latest update.
what’s weird is that Skype always works fine.
I do use zoom from the aur since ca. 14 month. Updates work fine at my pc (with trizen)
