I installed Manjaro fresh and it never sleeps longer tan few seconds. The machine sleeps well, but after around 30 seconds, Manjaro starts up automatically to the login screen.
I deactived Wifi, Bluetooth and network adapter.
My PC use:
CPU: Intel i7-6700
Board: ASUS Z270-A Prime
iGPU: HD530
SSD Samsung EVO 970 NVME
Kernel: 5.15.28
Manjaro KDE
No extra Software is installed after installation.
Hibernation also doesn’t work. Same problem like suspend mode.
Is there any possible solution?
Current complete hardware, kernel, and software information would help, even if it’s a fresh installation or recent update.
Yes, i put more information in my first post.
Anything unusual listed here?
systemd-inhibit --list
Immediately after waking from suspend, you can check the tail-end of the log for hints:
journalctl -e
Or to limit it to kernel messages. (You might need to invoke sudo
for this one.)
journalctl -e --dmesg
Thanks for this commands- Here are the output of
Mär 19 17:33:38 christopher-manjaro kernel: audit: type=1130 audit(1647707618.523:77): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 19 17:33:38 christopher-manjaro kernel: audit: type=1131 audit(1647707618.523:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hybrid-sleep comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 19 17:33:38 christopher-manjaro kernel: audit: type=1334 audit(1647707618.586:79): prog-id=0 op=UNLOAD
Mär 19 17:33:38 christopher-manjaro kernel: e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Down
Mär 19 17:33:38 christopher-manjaro kernel: audit: type=1130 audit(1647707618.650:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 19 17:33:41 christopher-manjaro kernel: e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
Mär 19 17:33:41 christopher-manjaro kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp0s31f6: link becomes ready
Mär 19 17:33:41 christopher-manjaro kernel: audit: type=1334 audit(1647707621.636:81): prog-id=22 op=LOAD
Mär 19 17:33:41 christopher-manjaro kernel: audit: type=1300 audit(1647707621.636:81): arch=c000003e syscall=321 success=yes exit=25 a0=5 a1=7ffc1221d3e0 a2=80 a3=7ffc1221d3e0 items=0 ppid=1 pid=473 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
Mär 19 17:33:41 christopher-manjaro kernel: audit: type=1327 audit(1647707621.636:81): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mär 19 17:33:46 christopher-manjaro kernel: audit: type=1100 audit(1647707626.113:82): pid=1188 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:unix_chkpwd acct="christopher" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mär 19 17:33:48 christopher-manjaro kernel: audit: type=1131 audit(1647707628.660:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 19 17:34:27 christopher-manjaro kernel: audit: type=1111 audit(1647707667.286:84): pid=473 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp0s31f6" ifindex=2 args=2000 pid=717 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mär 19 17:34:30 christopher-manjaro kernel: audit: type=1111 audit(1647707670.836:85): pid=473 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp0s31f6" ifindex=2 args=0 pid=717 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Mär 19 17:38:46 christopher-manjaro kernel: PM: suspend entry (deep)
Mär 19 17:39:47 christopher-manjaro kernel: Filesystems sync: 0.030 seconds
Mär 19 17:39:47 christopher-manjaro kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
Mär 19 17:39:47 christopher-manjaro kernel: OOM killer disabled.
Mär 19 17:39:47 christopher-manjaro kernel: Freezing remaining freezable tasks ... (elapsed 0.000 seconds) done.
Mär 19 17:39:47 christopher-manjaro kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Mär 19 17:39:47 christopher-manjaro kernel: e1000e: EEE TX LPI TIMER: 00000011
Mär 19 17:39:47 christopher-manjaro kernel: sd 1:0:0:0: [sda] Synchronizing SCSI cache
Mär 19 17:39:47 christopher-manjaro kernel: sd 1:0:0:0: [sda] Stopping disk
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: EC: interrupt blocked
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: PM: Preparing to enter system sleep state S3
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: EC: event blocked
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: EC: EC stopped
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: PM: Saving platform NVS memory
Mär 19 17:39:47 christopher-manjaro kernel: Disabling non-boot CPUs ...
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: CPU 1 is now offline
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: CPU 2 is now offline
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: CPU 3 is now offline
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: CPU 4 is now offline
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: CPU 5 is now offline
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: CPU 6 is now offline
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: CPU 7 is now offline
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: PM: Low-level resume complete
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: EC: EC started
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: PM: Restoring platform NVS memory
Mär 19 17:39:47 christopher-manjaro kernel: Enabling non-boot CPUs ...
Mär 19 17:39:47 christopher-manjaro kernel: x86: Booting SMP configuration:
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
Mär 19 17:39:47 christopher-manjaro kernel: CPU1 is up
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
Mär 19 17:39:47 christopher-manjaro kernel: CPU2 is up
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
Mär 19 17:39:47 christopher-manjaro kernel: CPU3 is up
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
Mär 19 17:39:47 christopher-manjaro kernel: CPU4 is up
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
Mär 19 17:39:47 christopher-manjaro kernel: CPU5 is up
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
Mär 19 17:39:47 christopher-manjaro kernel: CPU6 is up
Mär 19 17:39:47 christopher-manjaro kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
Mär 19 17:39:47 christopher-manjaro kernel: CPU7 is up
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: PM: Waking up from system sleep state S3
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: EC: interrupt unblocked
Mär 19 17:39:47 christopher-manjaro kernel: ACPI: EC: event unblocked
Mär 19 17:39:47 christopher-manjaro kernel: i915 0000:00:02.0: [drm] [ENCODER:94:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
Mär 19 17:39:47 christopher-manjaro kernel: i915 0000:00:02.0: [drm] [ENCODER:110:DDI C/PHY C] is disabled/in DSI mode with an ungated DDI clock, gate it
Mär 19 17:39:47 christopher-manjaro kernel: i915 0000:00:02.0: [drm] [ENCODER:114:DDI D/PHY D] is disabled/in DSI mode with an ungated DDI clock, gate it
Mär 19 17:39:47 christopher-manjaro kernel: sd 1:0:0:0: [sda] Starting disk
Mär 19 17:39:47 christopher-manjaro kernel: nvme nvme0: Shutdown timeout set to 8 seconds
Mär 19 17:39:47 christopher-manjaro kernel: nvme nvme0: 8/0/0 default/read/poll queues
Mär 19 17:39:47 christopher-manjaro kernel: ata3: SATA link down (SStatus 4 SControl 300)
Mär 19 17:39:47 christopher-manjaro kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Mär 19 17:39:47 christopher-manjaro kernel: ata4: SATA link down (SStatus 4 SControl 300)
Mär 19 17:39:47 christopher-manjaro kernel: ata1: SATA link down (SStatus 4 SControl 300)
Mär 19 17:39:47 christopher-manjaro kernel: ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
Mär 19 17:39:47 christopher-manjaro kernel: ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
Mär 19 17:39:47 christopher-manjaro kernel: ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
Mär 19 17:39:47 christopher-manjaro kernel: ata2.00: configured for UDMA/133
Mär 19 17:39:47 christopher-manjaro kernel: OOM killer enabled.
Mär 19 17:39:47 christopher-manjaro kernel: Restarting tasks ... done.
Mär 19 17:39:47 christopher-manjaro kernel: PM: suspend exit
Mär 19 17:39:47 christopher-manjaro kernel: audit: type=1130 audit(1647707987.480:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 19 17:39:47 christopher-manjaro kernel: audit: type=1131 audit(1647707987.480:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 19 17:39:47 christopher-manjaro kernel: audit: type=1334 audit(1647707987.670:88): prog-id=0 op=UNLOAD
Mär 19 17:39:47 christopher-manjaro kernel: e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Down
Mär 19 17:39:47 christopher-manjaro kernel: audit: type=1130 audit(1647707987.720:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Mär 19 17:39:50 christopher-manjaro kernel: e1000e 0000:00:1f.6 enp0s31f6: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
Mär 19 17:39:50 christopher-manjaro kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp0s31f6: link becomes ready
Mär 19 17:39:52 christopher-manjaro kernel: audit: type=1334 audit(1647707992.516:90): prog-id=23 op=LOAD
Mär 19 17:39:52 christopher-manjaro kernel: audit: type=1300 audit(1647707992.516:90): arch=c000003e syscall=321 success=yes exit=25 a0=5 a1=7ffc1221d3e0 a2=80 a3=7ffc1221d3e0 items=0 ppid=1 pid=473 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="NetworkManager" exe="/usr/bin/NetworkManager" subj==unconfined key=(null)
Mär 19 17:39:52 christopher-manjaro kernel: audit: type=1327 audit(1647707992.516:90): proctitle=2F7573722F62696E2F4E6574776F726B4D616E61676572002D2D6E6F2D6461656D6F6E
Mär 19 17:39:56 christopher-manjaro kernel: audit: type=1100 audit(1647707996.416:91): pid=2201 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:unix_chkpwd acct="christopher" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Mär 19 17:39:57 christopher-manjaro kernel: audit: type=1131 audit(1647707997.730:92): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
and from
WHO UID USER PID COMM WHAT WHY MODE
ModemManager 0 root 479 ModemManager sleep ModemManager needs to reset devices delay
NetworkManager 0 root 473 NetworkManager sleep NetworkManager needs to turn off networks delay
UPower 0 root 814 upowerd sleep Pause device polling delay
Bildschirmsperre 1000 christopher 704 ksmserver sleep Stellt sicher, dass der Bildschirm vor dem Herunterfahren gesperrt wird delay
PowerDevil 1000 christopher 718 org_kde_powerde handle-power-key:handle-suspend-key:handle-hibernate-key:handle-lid-switch KDE handles power events block
5 inhibitors listed.
