I did not disable it. My installation is basically just fresh out of the box
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/usr/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2020-10-04 02:13:07 HKT; 4min 32s ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 245 (systemd-timesyn)
Status: "Connecting to time server 202.112.29.82:123 (2.arch.pool.ntp.org)."
Tasks: 2 (limit: 4252)
CGroup: /system.slice/systemd-timesyncd.service
└─245 /usr/lib/systemd/systemd-timesyncd
Oct 04 02:16:02 raspi systemd-timesyncd[245]: Timed out waiting for reply from 119.28.206.193:123 (0.arch.pool.ntp.org).
Oct 04 02:16:12 raspi systemd-timesyncd[245]: Timed out waiting for reply from 119.28.183.184:123 (0.arch.pool.ntp.org).
Oct 04 02:16:22 raspi systemd-timesyncd[245]: Timed out waiting for reply from 162.159.200.123:123 (0.arch.pool.ntp.org).
Oct 04 02:16:32 raspi systemd-timesyncd[245]: Timed out waiting for reply from 162.159.200.123:123 (1.arch.pool.ntp.org).
Oct 04 02:16:43 raspi systemd-timesyncd[245]: Timed out waiting for reply from 84.16.67.12:123 (1.arch.pool.ntp.org).
Oct 04 02:16:53 raspi systemd-timesyncd[245]: Timed out waiting for reply from 193.182.111.142:123 (1.arch.pool.ntp.org).
Oct 04 02:17:03 raspi systemd-timesyncd[245]: Timed out waiting for reply from 144.76.76.107:123 (1.arch.pool.ntp.org).
Oct 04 02:17:13 raspi systemd-timesyncd[245]: Timed out waiting for reply from 193.182.111.142:123 (2.arch.pool.ntp.org).
Oct 04 02:17:24 raspi systemd-timesyncd[245]: Timed out waiting for reply from 119.28.183.184:123 (2.arch.pool.ntp.org).
Oct 04 02:17:34 raspi systemd-timesyncd[245]: Timed out waiting for reply from 193.182.111.14:123 (2.arch.pool.ntp.org).
Activating it with timedatectl set-ntp true did not help
I just installed a fresh vanilla Manjaro ARM minimal on a SD card on my RPI4, i have chosen the same parameters as you, even the timezone Asia/Hong_Kong.
I had no issue with internet connection, i get an ip address automatically.
So, i doubt the issue comes from Manjaro, or it’s out of my competences, i can’t help you more.
What options or settings have you got on the router side ?
that did not do the trick. I flushed the card and installed ubuntu 20.04 lts which complained about the ethernet adapter being in power safe mode. I disabled power saving through /sys/class/net/eth/power/config
then I installed raspbian 64-bit which assigned a 169.x.y.z and ultimately also failed to connect to the network.
I then tried to set up wifi which was softblocked. after configuration wpa_cli failed to find any networks so I just trashed the raspberry and am going to use a proper desktop for the job.
I have a couple of Manjaro minimal installs on RPi4, one uses wifi, the other wired ethernet.
For the wired network, the only thing I needed to do was to create:
/etc/systemd/network/10-wired.network
[Match]
Name=eth0
[Network]
DHCP=yes
And then reboot.
I used a similar setup for the wireless. No additional software or configuration required.
