Ethernet not working but wifi works
i have problem i cant use my Ethernet but wifi works
[kiko@kiko-pc ~]$ inxi -Fx
  Host: kiko-pc Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc
  v: 10.1.0 Desktop: Xfce 4.14.2 Distro: Manjaro Linux
  Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
  v: 0695130000004610000600000 serial: <root required>
  Mobo: Hewlett-Packard model: 1670 v: 09.49 serial: <root required>
  BIOS: Hewlett-Packard v: F.42 date: 12/08/2011
  ID-1: BAT0 charge: 32.5 Wh condition: 32.5/32.5 Wh (100%)
  model: Hewlett-Packard Primary status: Full
  Topology: Dual Core model: Intel Core i5-2450M bits: 64 type: MT MCP
  arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19962
  Speed: 801 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 1064 2: 948
  3: 1088 4: 910
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  Device-2: AMD Seymour [Radeon HD 6400M/7400M Series]
  vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.20.8 driver: modesetting
  resolution: 1280x720~60Hz, 1280x1024_60.00~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
  v: 3.3 Mesa 20.1.3 direct render: Yes
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  Sound Server: ALSA v: k5.6.19-2-MANJARO
  Device-1: Broadcom and subsidiaries BCM4313 802.11bgn Wireless Network
  Adapter
  vendor: Hewlett-Packard driver: wl v: kernel port: 4000 bus ID: 02:00.0
  IF: wlp2s0 state: up mac: 08:ed:b9:04:96:0f
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 03:00.0
  IF: eno1 state: up speed: 100 Mbps duplex: full mac: 80:c1:6e:57:2b:38
  Local Storage: total: 465.76 GiB used: 129.51 GiB (27.8%)
  ID-1: /dev/sda vendor: Hitachi model: HTS545050B9A300 size: 465.76 GiB
  ID-1: / size: 244.73 GiB used: 129.51 GiB (52.9%) fs: ext4 dev: /dev/sda1
  ID-2: swap-1 size: 10.09 GiB used: 524 KiB (0.0%) fs: swap dev: /dev/sda4
  System Temperatures: cpu: 63.0 C mobo: N/A gpu: radeon temp: 58 C
  Processes: 209 Uptime: 1h 39m Memory: 3.79 GiB used: 2.33 GiB (61.4%)
  Init: systemd Compilers: gcc: 10.1.0 clang: 10.0.0 Shell: bash v: 5.0.18
  inxi: 3.0.37
i try to use it
sudo modprobe -r r8169 && sleep 3 && sudo modprobe r8169 && sudo systemctl restart NetworkManager
but nothing works
ifconfig
[kiko@kiko-pc ~]$ ifconfig
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        ether 80:c1:6e:57:2b:38  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 112  bytes 15394 (15.0 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 4188  bytes 371230 (362.5 KiB)
        TX packets 4188  bytes 371230 (362.5 KiB)
wlp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.6  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fdb4:f58e:8ed3:da00:b891:5dda:76ac:6d55  prefixlen 64  scopeid 0x0<global>
        inet6 fe80::2fbd:afc:e40:765  prefixlen 64  scopeid 0x20<link>
        ether 08:ed:b9:04:96:0f  txqueuelen 1000  (Ethernet)
        RX packets 174996  bytes 238513271 (227.4 MiB)
        RX errors 0  dropped 0  overruns 0  frame 344991
        TX packets 101889  bytes 8667561 (8.2 MiB)
        device interrupt 16
