Ethernet doesn't exist as an option
My ethernet does not seem to exist in my network manager after a most recent upgrade of my system on 11/14 with
pacman -Syyuu
on my manjaro laptop.
Anyone have any places for me to start to debug this? I'm not a networking aficionado.
I tried to downgrade my kernel and networkmanager both to last known working version but I still do not even get an ethernet option (wifi is working fine).
I don't know why you use such command to update your system.
Only use
sudo pacman -Syu
If you have change your mirrorlist - use
sudo pacman -Syyu
I use such command because it allows me to downgrade packages if necessary during system upgrade. The command you posted has given me issues in the past because it does not.
As mentioned you should only use "uu" if it is a situation that requires it.
You need to post your system details. Use USB Android phone tethering if you need a connection. Do not post an output as a pic.
inxi -Fxxxz
You would also be well advised to learn how to do backups.
If your using the 5.3 kernel, downgrade to a different series.
I'd suggest an LTS series like 4.19, less issues, and you don't have to worry about it going EOL on you anytime soon.
Yeah I downgraded to 4.19 and the issue seems to be resolved, although I would like to be able to use the newer kernel.
From a working kernel my ouput is:
  Host: sailfish Kernel: 4.19.84-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.2.0 Desktop: Cinnamon 4.2.4 dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: Dell product: Precision 5530 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 0FP2W2 v: A00 serial: <filter> UEFI: Dell v: 1.13.0
  date: 08/22/2019
  ID-1: BAT0 charge: 61.8 Wh condition: 87.7/97.0 Wh (90%) volts: 12.7/11.4
  model: SMP DELL GPM0365 type: Li-ion serial: <filter> status: Charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse M510
  status: Discharging
  Topology: 6-Core model: Intel Core i9-8950HK bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 12.0 MiB
  bogomips: 69720
  Speed: 888 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 853 2: 859
  3: 860 4: 853 5: 872 6: 875 7: 854 8: 856 9: 844 10: 836 11: 839 12: 838
  Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA GP107GLM [Quadro P2000 Mobile] driver: N/A
  bus ID: 01:00.0 chip ID: 10de:1cba
  Display: x11 server: X.Org 1.20.5 driver: intel FAILED: nvidia
  resolution: 2560x1440~60Hz, 2560x1440~60Hz
  OpenGL: renderer: Mesa DRI Intel UHD Graphics 630 (Coffeelake 3x8 GT2)
  v: 4.5 Mesa 19.2.4 compat-v: 3.0 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
  v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
  Device-2: Realtek type: USB driver: snd-usb-audio bus ID: 3-1.5:3
  chip ID: 0bda:4014 serial: <filter>
  Sound Server: ALSA v: k4.19.84-1-MANJARO
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Dell driver: ath10k_pci v: kernel port: efa0 bus ID: 3b:00.0
  chip ID: 168c:003e
  IF: wlp59s0 state: up mac: <filter>
  Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-4:3
  chip ID: 0cf3:e010
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
  bus ID: 4-1.2:3 chip ID: 0bda:8153 serial: <filter>
  IF: ens4u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-47ec8ff8ca91 state: down mac: <filter>
  IF-ID-2: br-6d3648237fce state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  Local Storage: total: 953.87 GiB used: 103.24 GiB (10.8%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV1T02 NVMe 1024GB
  size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: AADA4106
  scheme: GPT
  ID-1: / size: 43.00 GiB used: 39.05 GiB (90.8%) fs: ext4
  dev: /dev/nvme0n1p6
  ID-2: /home size: 147.03 GiB used: 64.14 GiB (43.6%) fs: ext4
  dev: /dev/nvme0n1p7
  ID-3: swap-1 size: 1000.0 MiB used: 0 KiB (0.0%) fs: swap
  dev: /dev/nvme0n1p5
  System Temperatures: cpu: 72.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2506 fan-2: 2499
  Processes: 329 Uptime: 28m Memory: 31.04 GiB used: 3.07 GiB (9.9%)
  Init: systemd v: 242 Compilers: gcc: 9.2.0 clang: 9.0.0 Shell: zsh
  v: 5.7.1 running in: gnome-terminal inxi: 3.0.36
I will get you the output from a non working kernel shortly.
Why?
Normal "stable" releases usually introduce regressions, issue and bugs, then they go EOL and get removed from the repositories. LTS releases are usually pretty solid, have years of upstream support and security fixes, and unless you have new hardware that you need to be supported, is a better solution.
Don't get me started on the mainline kernels, talk about being used as a guinea pig. :wink:
I have an old media/file server here still running 4.4 because it has hardware that just isn't compatible with the newer kernels, 4.9 crashes at random and reboots, a lot, and 4.14 completely crashes on boot with a kernel dump.
I totally agree this attitude stuns me. Especially coming from people using very old hardware. On my older computers I generally run 4.14 as I find that kernel has the least issues with some of the very old hardware I own.
The most funny thing is how some users get right ingignant and pissed at Manjaro if their system won't run properly on the latest kernel. Those cases kill me.
I will mark your suggestion to switch kernels as the solution.
Yea, well If you go through the forum, there seems to be a reoccurring theme with the 5.3 kernel, and networking issues.
You are quite right. Usually one of my first suggestions is to try a different kernel. I have even been ranted on for suggesting this so often. Some users think this is not a valid solution at all, Some simply think it is their God given right to be on the newest kernel and will not accept any answer that does not allow them to use the latest and greatest.
Laughable, man.
What about the endless stream of users that claim they have used Linux for twenty years ask for help and go in a endless loop of failing because they never listen to any advice given i call them attention seekers, and time wasters, Lol
or help vampire :vampire:
PS to @rubyi. These rants were not directed personally at you. It was simply venting, as some users have attitudes that tend to rub helpers on the forum the wrong way after a while.
No offense to you intended. Sorry if we came off that way.
@tbg
No worries. I can totally see it from both sides. For me, I downgraded and that seemed to work fine. I know I need to use certain kernel versions because of some HDMI/display issues on older/certain kernels (I'm running pretty new ~2019 hardware). So, in that thought I could kind of understand wanting to use a newer kernel to fix certain problems where downgrading would fix the problem at hand but introduce others and thus not be a "solution" of fixing the problem on that specific kernel version.
That said, it is a fine workaround for my case as everything seems to be ok on 4.19.
I do have new hardware that has display issues on certain kernel versions.
Yes, however that is kind of part of the reason why there are LTS kernels to begin with. Not only do they receive security fixes, but also other fixes, like driver (modules) getting backported for just the reasons you mentioned. Unless you need a proprietary driver that isn't compatible with one, or more of the LTS kernels, well then, in that case, blame Nvidia. :wink:
