Ethernet Broken ThinkPad Kernel 5.7-rc2,3,4,5,6,7
After this morning update, we now have two ethernet connections that are displayed. We deleted them and it was replaced by this:
New 802-3-ethernet connection.
After re-configuration we still have two connections and we lost Internet:
1.enp2s0
2.eth1
Turn off wired connection or the modem has no effect. Reset the modem was the only solution for 5.6.5-3. For Kernel 5.7-rc2, only enp2s0 works not eth1.
Deleting one of them deletes both.
Edit: eth1 did not have a MAC address, overwriting (restrict to device) this connection with the default MAC address (enp2s0) removes eth1. Back to normal.
Still have the bug after a fresh install of the latest ISO 20.0-rc3 (2020422). Enabling the unstable channel brings back the same issue.
Deleting both of them with remove selected connection gives after restart the same result:
Not using WIFI
inxi -N
driver: r8169
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
driver: rtw_pci
This bug is not present on Kubuntu 20.04 for the same Kernel.
Edit: After this morning updates (20200424), upon restart a second dead connection is created (wired connection 1).
Hi
same problem here!
New Manjaro Mate install with kernel 5.7
This bug is gone here, but we stop using Manjaro because of the GUFW issue. Delete the second connection with the minus in red first, then try to rename the connection to see if it comes back.
DNS's setup (Adguard) is made directly in the Modem. No need to redo the setup for each installation.
Primary:176.103.130.130
Secondary:176.103.130.131
Modem IP Address is tweaked to 172.xxx.xx.xx
Not able to paste the rest, new user reason...
Here's the error for Kernel 5.7-rc3:
journalctl -f
-- Logs begin at Sun 2020-05-03 08:10:13 EDT. --
May 03 13:14:03 un kernel: audit: type=1131 audit(1588526043.729:54): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:14:03 un audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:14:03 un audit: AUDIT1334 prog-id=10 op=UNLOAD
May 03 13:14:03 un audit: AUDIT1334 prog-id=9 op=UNLOAD
May 03 13:14:03 un kernel: audit: type=1334 audit(1588526043.873:55): prog-id=10 op=UNLOAD
May 03 13:14:03 un kernel: audit: type=1334 audit(1588526043.873:56): prog-id=9 op=UNLOAD
May 03 13:14:05 un plasmashell[1307]: Using QByteRef with an index pointing outside the valid range of a QByteArray. The corresponding behavior is deprecated, and will be changed in a future version of Qt.
May 03 13:14:05 un kwin_x11[1260]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 11363, resource id: 31457418, major code: 18 (ChangeProperty), minor code: 0
May 03 13:14:05 un systemd[1167]: Started apps-org.kde.konsole-cb4e6f122879476fb537439303ccdfd7.scope.
May 03 13:14:14 un NetworkManager[752]: [1588526054.9990] dhcp4 (eth1): request timed out
May 03 13:14:14 un NetworkManager[752]: [1588526054.9991] dhcp4 (eth1): state changed unknown -> timeout
May 03 13:14:14 un NetworkManager[752]: [1588526054.9992] device (eth1): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
May 03 13:14:15 un NetworkManager[752]: [1588526055.0000] manager: NetworkManager state is now DISCONNECTED
May 03 13:14:15 un NetworkManager[752]: [1588526055.0016] device (eth1): Activation: failed for connection 'Wired connection 1'
May 03 13:14:15 un NetworkManager[752]: [1588526055.0023] device (eth1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
May 03 13:14:15 un avahi-daemon[745]: Withdrawing address record for fe80::f71:e1ce:6460:8a51 on eth1.
May 03 13:14:15 un avahi-daemon[745]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::f71:e1ce:6460:8a51.
May 03 13:14:15 un avahi-daemon[745]: Interface eth1.IPv6 no longer relevant for mDNS.
May 03 13:14:15 un kded5[1256]: networkstatus: SolidNetwork changed status: 1
May 03 13:14:15 un kded5[1256]: networkstatus: "SolidNetwork" , 1
May 03 13:14:15 un NetworkManager[752]: [1588526055.0123] dhcp4 (eth1): canceled DHCP transaction
May 03 13:14:15 un NetworkManager[752]: [1588526055.0124] dhcp4 (eth1): state changed timeout -> done
May 03 13:14:15 un NetworkManager[752]: [1588526055.0183] policy: auto-activating connection 'Wired connection 1' (de0ead4e-3679-32fd-9ea9-b5ae804b0e5a)
May 03 13:14:15 un NetworkManager[752]: [1588526055.0216] device (eth1): Activation: starting connection 'Wired connection 1' (de0ead4e-3679-32fd-9ea9-b5ae804b0e5a)
May 03 13:14:15 un NetworkManager[752]: [1588526055.0219] device (eth1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
May 03 13:14:15 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:14:15 un NetworkManager[752]: [1588526055.0230] manager: NetworkManager state is now CONNECTING
May 03 13:14:15 un NetworkManager[752]: [1588526055.0235] device (eth1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 03 13:14:15 un NetworkManager[752]: [1588526055.0250] device (eth1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
May 03 13:14:15 un NetworkManager[752]: [1588526055.0258] dhcp4 (eth1): activation: beginning transaction (timeout in 45 seconds)
May 03 13:14:15 un avahi-daemon[745]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::f71:e1ce:6460:8a51.
May 03 13:14:15 un avahi-daemon[745]: New relevant interface eth1.IPv6 for mDNS.
May 03 13:14:15 un systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
May 03 13:14:15 un avahi-daemon[745]: Registering new address record for fe80::f71:e1ce:6460:8a51 on eth1..
May 03 13:14:15 un systemd[1]: Condition check resulted in First Boot Wizard being skipped.
May 03 13:14:15 un systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
May 03 13:14:15 un systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
May 03 13:14:15 un systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
May 03 13:14:15 un systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
May 03 13:14:15 un systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
May 03 13:14:15 un systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
May 03 13:14:15 un systemd[1]: Condition check resulted in Create System Users being skipped.
May 03 13:14:15 un systemd[1]: Condition check resulted in Update is Completed being skipped.
May 03 13:14:15 un systemd[1]: Starting Network Manager Script Dispatcher Service...
May 03 13:14:15 un kdeconnectd[1327]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/1"
May 03 13:14:15 un DiscoverNotifier[1324]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/1"
May 03 13:14:15 un dbus-daemon[749]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
May 03 13:14:15 un systemd[1]: Started Network Manager Script Dispatcher Service.
May 03 13:14:15 un kernel: audit: type=1130 audit(1588526055.039:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:14:15 un audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:14:15 un kded5[1256]: networkstatus: SolidNetwork changed status: 3
May 03 13:14:15 un kded5[1256]: networkstatus: "SolidNetwork" , 3
May 03 13:14:15 un kded5[1256]: plasma-nm: Unhandled active connection state change: 1
May 03 13:14:17 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:14:17 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:14:21 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:14:21 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:14:25 un systemd[1]: NetworkManager-dispatcher.service: Succeeded.
May 03 13:14:25 un audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:14:25 un kernel: audit: type=1131 audit(1588526065.003:58): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:14:29 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:14:29 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:14:33 un plasma_waitforname[1385]: org.kde.knotifications: WaitForName: Service was not registered within timeout
May 03 13:14:33 un dbus-daemon[1186]: [session uid=1000 pid=1186] Activated service 'org.freedesktop.Notifications' failed: Process org.freedesktop.Notifications exited with status 1
May 03 13:14:33 un msm_kde_notifier[1355]: "qt5-translations"
May 03 13:14:34 un kate[1496]: sonnet.core: No language dictionaries for the language: "en_US"
May 03 13:14:45 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:14:45 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:14:59 un NetworkManager[752]: [1588526099.9988] dhcp4 (eth1): request timed out
May 03 13:14:59 un NetworkManager[752]: [1588526099.9988] dhcp4 (eth1): state changed unknown -> timeout
May 03 13:14:59 un NetworkManager[752]: [1588526099.9990] device (eth1): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
May 03 13:14:59 un NetworkManager[752]: [1588526099.9998] manager: NetworkManager state is now DISCONNECTED
May 03 13:15:00 un NetworkManager[752]: [1588526100.0009] device (eth1): Activation: failed for connection 'Wired connection 1'
May 03 13:15:00 un NetworkManager[752]: [1588526100.0012] device (eth1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
May 03 13:15:00 un dbus-daemon[1186]: [session uid=1000 pid=1186] Activating service name='org.freedesktop.Notifications' requested by ':1.12' (uid=1000 pid=1256 comm="/usr/bin/kded5 ")
May 03 13:15:00 un avahi-daemon[745]: Withdrawing address record for fe80::f71:e1ce:6460:8a51 on eth1.
May 03 13:15:00 un kded5[1256]: networkstatus: SolidNetwork changed status: 1
May 03 13:15:00 un avahi-daemon[745]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::f71:e1ce:6460:8a51.
May 03 13:15:00 un kded5[1256]: networkstatus: "SolidNetwork" , 1
May 03 13:15:00 un avahi-daemon[745]: Interface eth1.IPv6 no longer relevant for mDNS.
May 03 13:15:00 un NetworkManager[752]: [1588526100.0190] dhcp4 (eth1): canceled DHCP transaction
May 03 13:15:00 un NetworkManager[752]: [1588526100.0191] dhcp4 (eth1): state changed timeout -> done
May 03 13:15:00 un NetworkManager[752]: [1588526100.0220] policy: auto-activating connection 'Wired connection 1' (de0ead4e-3679-32fd-9ea9-b5ae804b0e5a)
May 03 13:15:00 un NetworkManager[752]: [1588526100.0233] device (eth1): Activation: starting connection 'Wired connection 1' (de0ead4e-3679-32fd-9ea9-b5ae804b0e5a)
May 03 13:15:00 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:00 un NetworkManager[752]: [1588526100.0258] device (eth1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
May 03 13:15:00 un NetworkManager[752]: [1588526100.0265] manager: NetworkManager state is now CONNECTING
May 03 13:15:00 un NetworkManager[752]: [1588526100.0269] device (eth1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 03 13:15:00 un systemd[1]: Starting Network Manager Script Dispatcher Service...
May 03 13:15:00 un NetworkManager[752]: [1588526100.0284] device (eth1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
May 03 13:15:00 un NetworkManager[752]: [1588526100.0289] dhcp4 (eth1): activation: beginning transaction (timeout in 45 seconds)
May 03 13:15:00 un avahi-daemon[745]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::f71:e1ce:6460:8a51.
May 03 13:15:00 un avahi-daemon[745]: New relevant interface eth1.IPv6 for mDNS.
May 03 13:15:00 un avahi-daemon[745]: Registering new address record for fe80::f71:e1ce:6460:8a51 on eth1.
May 03 13:15:00 un kdeconnectd[1327]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/2"
May 03 13:15:00 un dbus-daemon[749]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
May 03 13:15:00 un systemd[1]: Started Network Manager Script Dispatcher Service.
May 03 13:15:00 un audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:15:00 un DiscoverNotifier[1324]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/2"
May 03 13:15:00 un kernel: audit: type=1130 audit(1588526100.036:59): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:15:00 un kded5[1256]: plasma-nm: Unhandled active connection state change: 1
May 03 13:15:00 un kded5[1256]: networkstatus: SolidNetwork changed status: 3
May 03 13:15:00 un kded5[1256]: networkstatus: "SolidNetwork" , 3
May 03 13:15:02 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:02 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:15:06 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:06 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:15:10 un systemd[1]: NetworkManager-dispatcher.service: Succeeded.
May 03 13:15:10 un audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:15:10 un kernel: audit: type=1131 audit(1588526110.006:60): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:15:14 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:14 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:15:30 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:30 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:15:44 un NetworkManager[752]: [1588526144.9983] dhcp4 (eth1): request timed out
May 03 13:15:44 un NetworkManager[752]: [1588526144.9984] dhcp4 (eth1): state changed unknown -> timeout
May 03 13:15:44 un NetworkManager[752]: [1588526144.9985] device (eth1): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
May 03 13:15:44 un NetworkManager[752]: [1588526144.9990] manager: NetworkManager state is now DISCONNECTED
May 03 13:15:45 un NetworkManager[752]: [1588526145.0004] device (eth1): Activation: failed for connection 'Wired connection 1'
May 03 13:15:45 un NetworkManager[752]: [1588526145.0008] device (eth1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
May 03 13:15:45 un avahi-daemon[745]: Withdrawing address record for fe80::f71:e1ce:6460:8a51 on eth1.
May 03 13:15:45 un avahi-daemon[745]: Leaving mDNS multicast group on interface eth1.IPv6 with address fe80::f71:e1ce:6460:8a51.
May 03 13:15:45 un avahi-daemon[745]: Interface eth1.IPv6 no longer relevant for mDNS.
May 03 13:15:45 un kded5[1256]: networkstatus: SolidNetwork changed status: 1
May 03 13:15:45 un kded5[1256]: networkstatus: "SolidNetwork" , 1
May 03 13:15:45 un NetworkManager[752]: [1588526145.0256] dhcp4 (eth1): canceled DHCP transaction
May 03 13:15:45 un NetworkManager[752]: [1588526145.0257] dhcp4 (eth1): state changed timeout -> done
May 03 13:15:45 un NetworkManager[752]: [1588526145.0316] policy: auto-activating connection 'Wired connection 1' (de0ead4e-3679-32fd-9ea9-b5ae804b0e5a)
May 03 13:15:45 un NetworkManager[752]: [1588526145.0347] device (eth1): Activation: starting connection 'Wired connection 1' (de0ead4e-3679-32fd-9ea9-b5ae804b0e5a)
May 03 13:15:45 un NetworkManager[752]: [1588526145.0349] device (eth1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
May 03 13:15:45 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:45 un NetworkManager[752]: [1588526145.0353] manager: NetworkManager state is now CONNECTING
May 03 13:15:45 un NetworkManager[752]: [1588526145.0356] device (eth1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
May 03 13:15:45 un NetworkManager[752]: [1588526145.0365] device (eth1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
May 03 13:15:45 un NetworkManager[752]: [1588526145.0373] dhcp4 (eth1): activation: beginning transaction (timeout in 45 seconds)
May 03 13:15:45 un systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
May 03 13:15:45 un systemd[1]: Condition check resulted in First Boot Wizard being skipped.
May 03 13:15:45 un avahi-daemon[745]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::f71:e1ce:6460:8a51.
May 03 13:15:45 un systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
May 03 13:15:45 un avahi-daemon[745]: New relevant interface eth1.IPv6 for mDNS.
May 03 13:15:45 un systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
May 03 13:15:45 un avahi-daemon[745]: Registering new address record for fe80::f71:e1ce:6460:8a51 on eth1.*.
May 03 13:15:45 un systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
May 03 13:15:45 un systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
May 03 13:15:45 un systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
May 03 13:15:45 un systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
May 03 13:15:45 un systemd[1]: Condition check resulted in Create System Users being skipped.
May 03 13:15:45 un systemd[1]: Condition check resulted in Update is Completed being skipped.
May 03 13:15:45 un systemd[1]: Starting Network Manager Script Dispatcher Service...
May 03 13:15:45 un DiscoverNotifier[1324]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/3"
May 03 13:15:45 un kdeconnectd[1327]: "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/3"
May 03 13:15:45 un dbus-daemon[749]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
May 03 13:15:45 un systemd[1]: Started Network Manager Script Dispatcher Service.
May 03 13:15:45 un audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:15:45 un kernel: audit: type=1130 audit(1588526145.045:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:15:45 un kded5[1256]: networkstatus: SolidNetwork changed status: 3
May 03 13:15:45 un kded5[1256]: networkstatus: "SolidNetwork" , 3
May 03 13:15:45 un kded5[1256]: plasma-nm: Unhandled active connection state change: 1
May 03 13:15:47 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:47 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:15:51 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:51 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:15:55 un systemd[1]: NetworkManager-dispatcher.service: Succeeded.
May 03 13:15:55 un audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:15:55 un kernel: audit: type=1131 audit(1588526155.002:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 03 13:15:59 un dbus-daemon[749]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.14' (uid=0 pid=752 comm="/usr/bin/NetworkManager --no-daemon ")
May 03 13:15:59 un dbus-daemon[749]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.resolve1.service': Unit dbus-org.freedesktop.resolve1.service not found.
May 03 13:16:00 un plasma_waitforname[1600]: org.kde.knotifications: WaitForName: Service was not registered within timeout
May 03 13:16:00 un dbus-daemon[1186]: [session uid=1000 pid=1186] Activated service 'org.freedesktop.Notifications' failed: Process org.freedesktop.Notifications exited with status 1
Fresh install latest testing ISO L56.8
Compiling Kernel 5.7-rc3 brings back this issue. The computer connects to the second (no MAC address) one. Previous post result.
At first, removing the second one deletes both. A new wired connection must be created to access the Internet. Upon restart, this bug came back for a second and last time, but removing the second does not remove the previous one.
There is a second bug with 5.7, show desktop in taskbar comes back after each restart.
Network Manager works normally after the second correction.
Same issue this morning with the fourth release candidate, a second connection is created and the machine boots there. Nothing wrong with the second restart.
Apart the taskbar, the rest is OK on the unstable channel.
Fresh install Cinnamon 20.0 Kernel 5.7-rc3
Similar and worst issue in Cinnamon 20.0, the kernel creates a second dead connection. The default Ethernet one becomes Realtek RTL8111/8168/8411PCI Express Gigabite Ethernet Controller. Its name in settings: PCI Ethernet.
This time, the second connection has a cloned MAC Address, but it refuses to connect. Also, it is not possible to delete this connection, not even with reset > Forget. Connect automatically must be OFF.
Nothing abnormal in Kernel 5.6.8 or dot 10-3.
For KDE, this bug was not present in 5.7-rc0 and not sure at 100%, probably rc1 too. It was introduced in rc2 and it has not gotten any corrections since then.
This install ends up with no password. Plus, the clock is locked 4 hours behind New-York time.
Kernel 5.7-rc4 is available in the unstable channel only (13 packages).
It is a known issue that linux57 has a general network problem. That is a developer kernel and not used for normal usage just yet.
Same ball game, except that rc5 creates a second connection permanently.
Plus, Tor Alpha 9.5a12 does not start and tor launcher is 2 builds behind schedule and it does not update.
A 10 minutes fresh install. See you next week!
Gnome 20200511 L56.11
Same in Gnome for rc7.
nmcli connection show
NAME UUID TYPE DEVICE
Adguard a9f0bc68-5611-4d6f-9efc-02a44eb21b43 ethernet eth1
Adguard a9f0bc68-5611-4d6f-9efc-02a44eb21b43 ethernet enp2s0
uname -a
Linux gnome 5.7.0-1-MANJARO #1 SMP PREEMPT Mon May 25 09:03:22 UTC 2020 x86_64 GNU/Linux
The real one is enp2s0 (PCI Ethernet), eth1 (Ethernet OFF) is a false dead duplication.
Tomorrow, Kernel 5.7 will be on the stable channel.
I was looking for Gnome 3.37.0.1, but the unstable branch is empty.
Try this:
Problem is in the r16x driver. There is one pointer (to phy driver) that is not working well.
Gnome 20200531 L56.15-1
Kernel 5.7.0 is not available, only rc7.
Unless there's an error in the procedure, eth1 (dead) remains visible in network applet. No gain, still have to uncheck connect automatically + unremovable.
gedit /usr/lib/systemd/system/refresh-network.target
[Unit]
Description=Refresh network
After=network.target
Before=multi-user.target
[Install]
WantedBy=refresh-network.service
  1. Overwrite existing file ?
gedit /usr/lib/systemd/system/multi-user.target
[> Unit]
After=refresh-network.target
[Service]
Type=oneshot
ExecStart=/usr/local/bin/refresh-network.sh
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
gedit /usr/local/bin/refresh-network.sh
tmp="/tmp/refresh-net.$$.log"
command() {
st=$1
shift
logger -s -t "refresh network" "$* .................."
eval $* | tee $tmp
logger -s -t "refresh network" -f $tmp
logger -s -t "refresh network" "$* ...... RV: $?"
sleep $st
command 0 nmcli networking off
command 3 sudo systemctl stop NetworkManager
command 0 sudo ip link set enp3s0 down
command 0 sudo modprobe -r r8169
command 0 sudo modprobe r8169
command 0 sudo ip link set enp3s0 mode DEFAULT
command 0 sudo ip link set enp3s0 up
command 3 sudo systemctl start NetworkManager
command 0 nmcli networking on
cat /usr/lib/systemd/system/refresh-network.target
[Unit]
[Install]
cat /usr/local/bin/refresh-network.sh [126]
command() {
st=$1
shift
eval $* | tee $tmp
sleep $st
cat /usr/lib/systemd/system/multi-user.target
SPDX-License-Identifier: LGPL-2.1+
This file is part of systemd.
systemd is free software; you can redistribute it and/or modify it
under the terms of the GNU Lesser General Public License as published by
the Free Software Foundation; either version 2.1 of the License, or
(at your option) any later version.
[Unit]
[Service]
Type=oneshot
RemainAfterExit=yes
[Install]
nmcli device
DEVICE TYPE STATE CONNECTION
enp2s0 ethernet connected Cloudflare
eth1 ethernet connecting (getting IP configuration) Wired connection 1
wlp4s0 wifi unavailable --
lo loopback unmanaged
It seems OK now:
KDE Plasma Version: 5.19.80
KDE Frameworks Version: 5.71.0
Qt Version: 5.15.0
Kernel Version: 5.7.0-3-MANJARO
OS Type: 64-bit
Processors: 8 Ă— AMD Ryzen 7 2700U with Radeon Vega Mobile Gfx
Memory: 7.5 GiB of RAM
Graphics Processor: AMD RAVEN
nmcli device
enp2s0 ethernet connected Wired connection 1
lo loopback unmanaged --
This topic was automatically closed after 90 days. New replies are no longer allowed.
