/etc/sysctl.d/ is being ignored
Hi all, I want to make a sysctl setting permanent (dev.i915.perf_stream_paranoid=0). As such, I put the configuration into /etc/sysctl.d/99-i915psp.conf. However this file is being ignored at boot and the value is defaulting to 1. After I run sysctl --system, the correct value is set, but somehow this does not happen at boot. Example commands below. Any insight or suggestions would be most appreciated.
$ cat /etc/sysctl.d/99-i915psp.conf
$ sysctl -n dev.i915.perf_stream_paranoid
1
$ sudo sysctl --system
Applying /usr/lib/sysctl.d/10-manjaro.conf …
fs.inotify.max_user_instances = 1024
fs.inotify.max_user_watches = 524288
Applying /usr/lib/sysctl.d/50-coredump.conf …
kernel.core_pattern = |/usr/lib/systemd/systemd-coredump %P %u %g %s %t %c %h
kernel.core_pipe_limit = 16
fs.suid_dumpable = 2
Applying /usr/lib/sysctl.d/50-default.conf …
kernel.sysrq = 16
kernel.core_uses_pid = 1
net.ipv4.conf.default.rp_filter = 2
sysctl: setting key “net.ipv4.conf.all.rp_filter”: Invalid argument
net.ipv4.conf.default.accept_source_route = 0
sysctl: setting key “net.ipv4.conf.all.accept_source_route”: Invalid argument
net.ipv4.conf.default.promote_secondaries = 1
sysctl: setting key “net.ipv4.conf.all.promote_secondaries”: Invalid argument
net.ipv4.ping_group_range = 0 2147483647
net.core.default_qdisc = fq_codel
fs.protected_hardlinks = 1
fs.protected_symlinks = 1
fs.protected_regular = 1
fs.protected_fifos = 1
Applying /usr/lib/sysctl.d/50-pid-max.conf …
kernel.pid_max = 4194304
Applying /etc/sysctl.d/99-i915psp.conf …
dev.i915.perf_stream_paranoid = 0
0
I had to look up what you are trying to do.
On boot, the i915 kernal module enables the paranoid performance collection mode by default. To use the VK_INTEL_performance_query extension, this paranoid mode must be disabled.
A manual approach to do this is to perform the following command:
sudo sysctl -w dev.i915.perf_stream_paranoid=0
An automated approach to do this is to add a cron job that executes whenever the platform reboots, as follows:
sudo crontab -e # Add the following line at the end or as the 1st no comment line:
@reboot /sbin/sysctl -w dev.i915.perf_stream_paranoid=0
From the above quote it seems you are trying to enable paranoid mode - which then seems to fallback to disabled.
Hi!
I’m having the same problem on my desktop, while on my laptop the sysctl.d file worked as intended.
Did you manage to solve following @linux-aarhus answer? :slightly_smiling_face:
yes, it worked
