Hi,
When I’m using Windscribe-cli to connect to a server I get
“/etc/resolv.conf is not a symlink, this may break DNS”
the Internet works fine for few minutes and then a Notification popsup about Limited Connectivity (I still works after)
``Connecting to Turkey Istanbul Ataturk (UDP:443)
Firewall Enabled
Connected to Turkey Istanbul Ataturk
Your IP changed from x to x ``
System info:
inxi --admin --verbosity=7 --filter --no-host
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=60c1e63a-0416-40a5-9450-d64778e4765d rw quiet apparmor=1
security=apparmor resume=UUID=475208a7-56e7-4fcb-8264-6132f4981a7c
udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Pavilion Notebook
v: Type1ProductConfigId serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 8216 v: 83.18 serial: <filter> UEFI: Insyde v: F.55
date: 07/01/2020
ID-1: BAT0 charge: N/A condition: N/A volts: 7.5 min: 7.7
model: Hewlett-Packard Primary type: Li-ion serial: N/A
status: Unknown
RAM: total: 7.66 GiB used: 3.05 GiB (39.9%)
RAM Report:
Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142)
stepping: 9 microcode: DE cache: L2: 3 MiB bogomips: 21607
Speed: 3100 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 3100
2: 3100 3: 3100 4: 3100
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:134d class-ID: 0302
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
integrated webcam
type: USB driver: uvcvideo bus-ID: 1-3:2 chip-ID: 05c8:038e
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak]
driver: iwlwifi v: kernel port: 3000 bus-ID: 05:00.0
chip-ID: 8086:24fb class-ID: 0280
IP v4: <filter> scope: global
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-7:3 chip-ID: 8087:0aa7 class-ID: e001
Message: No LVM data was found.
Local Storage: total: 931.51 GiB used: 490.46 GiB (52.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi)
model: HTS541010A9E680 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: A7G0 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW GUE1N rev: UE00
dev-links: cdrom
ID-1: / raw-size: 79.95 GiB size: 78.14 GiB (97.74%)
used: 24.32 GiB (31.1%) fs: ext4 dev: /dev/sda11 maj-min: 8:11
label: N/A uuid: 60c1e63a-0416-40a5-9450-d64778e4765d
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 82.4 MiB (32.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
label: LOCAL DISK uuid: 6605-7490
ID-3: /mnt/028098C28098BE1B raw-size: 243.54 GiB
size: 243.54 GiB (100.00%) used: 117.92 GiB (48.4%) fs: ntfs
dev: /dev/sda3 maj-min: 8:3 label: N/A uuid: 028098C28098BE1B
ID-4: /mnt/Local Disk raw-size: 154.88 GiB size: 154.88 GiB (100.00%)
used: 83.53 GiB (53.9%) fs: ntfs dev: /dev/sda5 maj-min: 8:5
label: Local Disk uuid: 2810C5C310C597E8
ID-5: /mnt/New Volume raw-size: 232.95 GiB size: 232.95 GiB (100.00%)
used: 132.49 GiB (56.9%) fs: ntfs dev: /dev/sda7 maj-min: 8:7
label: New Volume uuid: 74BEF488BEF443E0
ID-6: /mnt/Rakesh raw-size: 203.79 GiB size: 203.79 GiB (100.00%)
used: 132.2 GiB (64.9%) fs: ntfs dev: /dev/sda6 maj-min: 8:6
label: Rakesh uuid: CE6E96456E9625ED
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 1.46 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda10 maj-min: 8:10 label: N/A
uuid: 475208a7-56e7-4fcb-8264-6132f4981a7c
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda4 maj-min: 8:4 size: 576 MiB fs: ntfs label: N/A
uuid: 04387227387217BE
ID-3: /dev/sda8 maj-min: 8:8 size: 980 MiB fs: ntfs label: N/A
uuid: A83A1B163A1AE15C
ID-4: /dev/sda9 maj-min: 8:9 size: 13.15 GiB fs: ntfs label: RECOVERY
uuid: 126850E76850CADD
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-3:2 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD integrated webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:038e class-ID: 0e02 serial: <filter>
Device-2: 1-7:3 info: Intel Wireless-AC 3168 Bluetooth
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aa7 class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0
speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 71.0 C mobo: N/A
Processes: 211 Uptime: 2h 52m wakeups: 2 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1330
lib: 345 flatpak: 0 Shell: Bash v: 5.1.0 running-in: konsole
inxi: 3.3.03 ```
