I can connect to home WLAN with KDE (network manager).
How can I connect to WLAN at startup.
I have found some information how to establish WLAN at boot, but none worked for me.
What did you already tried?
There is only one important thing to do, store the Wifi password unencrypted and make sure NM is instructed to automatically connect to this specific Wifi network.
I have tried this: https://askubuntu.com/questions/1277/how-do-i-configure-wifi-to-log-in-to-wpa-at-boot-time-regardless-of-user-being
Did you made sure you saved the password unencrypted?
Not only the Option “All users may connect to this network”, also in the password field, “Store the password for all users” . The Wifi password is then saved in the nmconnection file in /etc/NetworkManager/system-connections
Now, the problem with WLAN login is solved.
