Remove this, or comment it out. And don’t edit things if you don’t understand them. Also I see you have python in IgnorePkg, that will end up well too.
I dont recall ever adding this directly to the file, and commented it out on Brahma’s advice.
Now that I have removed the [eschwartz] bit i think thats got it working again.
Its asking me to install 566 updates so i’ll review this.
Thankyou all for the help
No one else did. If you didn’t add it directly then you ran some command from some random guide that added it. Same goes for IgnorePkg = python
. I won’t be surprised if you break the system after very next update., since this is a partial upgrade.
You should also restore original config files brahma made you modify.
