pacman has been failing to sync databases for a few month now which means ive not been able to install updates or new packages. I finally got some time last night to take a look. The error message I am getting is a 404 when trying to sync the eschwartz.db.
This only occurs/tries to check when I have AUR packages on.
Has the location changed? how do I get/set the new one?
Ive included only the first part, which is where the error shows as the rest just say “checking… package name” and then it asks if I want to edit the build files at the end
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
0.219 United_Kingdom : https://mirror.cyberhost.uk/sites/manjaro/
0.192 United_Kingdom : http://manjaro.mirrors.uk2.net/
::INFO Writing mirror list
::United_Kingdom : http://manjaro.mirrors.uk2.net/stable/$repo/$arch
::United_Kingdom : https://mirror.cyberhost.uk/sites/manjaro/stable/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
error: GPGME error: No data
:: Synchronising package databases...
core 169.4 KiB 1107 KiB/s 00:00 [##########################################################################################################] 100%
extra 1884.0 KiB 3.58 MiB/s 00:01 [##########################################################################################################] 100%
community 7.0 MiB 2.34 MiB/s 00:03 [##########################################################################################################] 100%
multilib 178.9 KiB 1017 KiB/s 00:00 [##########################################################################################################] 100%
eschwartz.db failed to download
error: failed retrieving file 'eschwartz.db' from pkgbuild.com : The requested URL returned error: 404
error: failed to synchronize all databases (failed to retrieve some files)
::Singapore : https://download.nus.edu.sg/mirror/manjaro/stable
error: failed to synchronize all databases (no servers configured for repository)
so navigate to /etc/pacman.d/mirrorlist and open the mirrorlist file and is it empty?
try put in there this:
## Manjaro Linux custom mirrorlist
## Generated on 2022-05-13 19:23
## Please use 'pacman-mirrors -id' To reset custom mirrorlist
## Please use 'pacman-mirrors -c all' To reset custom mirrorlist
## To remove custom config run 'pacman-mirrors -c all'
## Country : Austria
Server = https://mirror.easyname.at/manjaro/stable/$repo/$arch
## Country : Germany
Server = https://manjaro.moson.eu/stable/$repo/$arch
Server = https://mirror.alpix.eu/manjaro/stable/$repo/$arch
## Country : United_Kingdom
Server = https://mirror.cyberhost.uk/sites/manjaro/stable/$repo/$arch
## Country : Bulgaria
Server = https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
## Country : Finland
Server = https://manjaro.kyberorg.fi/stable/$repo/$arch
Server = https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
## Country : Portugal
Server = https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
## Manjaro Linux default mirrorlist
## Generated on 2022-05-16 09:19
## Please use 'pacman-mirrors -f [NUMBER] [NUMBER]' to modify mirrorlist
## (Use 0 for all mirrors)
Server = https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
Server = https://mirrors.gethosted.online/manjaro/repos/stable/$repo/$arch
## Country : Netherlands
Server = http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
Server = https://mirror.koddos.net/manjaro/stable/$repo/$arch
There were more in the file but cropped it for brevity
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc manjaro-system
# If upgrades are available for these packages they will be asked for first
SyncFirst = manjaro-system archlinux-keyring manjaro-keyring
#XferCommand = /usr/bin/curl -C - -f %u > %o
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta = 0.7
Architecture = auto
IgnorePkg = python docker-compose
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
#Color
#TotalDownload
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Never
LocalFileSigLevel = Never
#RemoteFileSigLevel = Never
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
[core]
SigLevel = Never
Include = /etc/pacman.d/mirrorlist
[extra]
SigLevel = Never
[community]
SigLevel = Never
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
SigLevel = Never
[eschwartz]
# Server = https://pkgbuild.com/~eschwartz/repo/$arch
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Never
#Server = file:///home/custompkgs
::INFO To remove custom config run 'sudo pacman-mirrors -c all'
