Errors on Lokinet
I Installed Lokinet, seems ok.
https://aur.archlinux.org/packages/lokinet
But service seems reluctant.
~]$ systemctl start lokinet
Job for lokinet.service failed because the control process exited with error code.
See "systemctl status lokinet.service" and "journalctl -xeu lokinet.service" for details.
[sum@ordi1 ~]$ journalctl -xeu lokinet.service
nov. 07 19:33:11 ordi1 lokinet[64434]: [ERR] [](560) 2022-11-07 18:33:11.350 GM>
nov. 07 19:33:11 ordi1 systemd[1]: lokinet.service: Main process exited, code=e>
â–‘â–‘ Subject: Unit process exited
â–‘â–‘ Defined-By: systemd
â–‘â–‘ Support: https://forum.manjaro.org/c/support
â–‘â–‘
â–‘â–‘ An ExecStart= process belonging to unit lokinet.service has exited.
â–‘â–‘
â–‘â–‘ The process' exit code is 'exited' and its exit status is 2.
nov. 07 19:33:11 ordi1 systemd[1]: lokinet.service: Failed with result 'exit-co>
â–‘â–‘ Subject: Unit failed
â–‘â–‘
â–‘â–‘ The unit lokinet.service has entered the 'failed' state with result 'exit-co>
nov. 07 19:33:11 ordi1 systemd[1]: Failed to start Lokinet: Anonymous Network l>
░░ Subject: L'unité (unit) lokinet.service a échoué
â–‘â–‘
░░ L'unité (unit) lokinet.service a échoué, avec le résultat failed.
lines 71-93/93 (END)
A nice soul could bring hints ? :nerd_face:
Im not sure how to help,you are aware the lokinet package hasnt been updated since July, right? You may have better luck with the lokinet-bin package, it was updated in September.
No luck with the -bin : doesn’t compile (Error)
It’s also an earlier versions, seemingly.
For now I’m still stuck.
Does anybody use Lokinet on Manjaro ?
binary packages are not compiled - just used as is
(they contain the already precompiled binary - just as every repo package, for instance)
… we are left to guess what the error might have been …
and, for what it’s worth:
I was curious to learn what that lokinet is all about
The website had a lot of words - which did not amount to any meaning to me.
So I dug a little deeper - meaning: not just on their website and FAQ
and found this:
A Review of Lokinet (Oxen): A Road to Nowhere?
which seems to give a bit more actual information
my personal conclusion:
I wouldn’t touch this with a ten feet pole - you’d have to pay me to even try and install it :wink:
Hi,
Thank you for caring.
The install fail happened with pamac GUI.
With yay, inbstall succeeds, but service doesn’t start:
[sum@ordi1 ~]$ yay -S lokinet-bin
:: VĂ©rification des conflits...
:: VĂ©rification des conflits internes...
[Repo:2]  fstrm-0.6.1-1  unbound-1.17.0-1
[Aur:1]  lokinet-bin-0.9.9-1
:: (1/1) PKGBUILD téléchargé : lokinet-bin
  1 lokinet-bin                      (Fichiers de compilation existants)
==> Afficher les diffs ?
==> [N]Aucun [A]Tous [Ab]Annuler [I]nstallés [No]nInstallés ou (1 2 3, 1-3, ^4)
:: (1/1) Lecture de SRCINFO : lokinet-bin
[sudo] Mot de passe de sum :
résolution des dépendances…
recherche des conflits entre paquets…
Paquets (2) fstrm-0.6.1-1  unbound-1.17.0-1
Taille totale installée :  4,15 MiB
:: Procéder à l’installation ? [O/n]
(2/2) vérification des clés dans le trousseau      [----------------------] 100%
(2/2) vérification de l’intégrité des paquets      [----------------------] 100%
(2/2) chargement des fichiers des paquets          [----------------------] 100%
(2/2) analyse des conflits entre fichiers          [----------------------] 100%
(2/2) vérification de l’espace disque disponible   [----------------------] 100%
:: Traitement des changements du paquet…
(1/2) installation de fstrm                        [----------------------] 100%
(2/2) installation de unbound                      [----------------------] 100%
DĂ©pendances optionnelles pour unbound
    expat: for unbound-anchor [installé]
    sh: for unbound-control-setup [installé]
    python: for python-bindings [installé]
:: Exécution des crochets (« hooks ») de post-transaction…
(1/4) Creating system user accounts...
(2/4) Reloading system manager configuration...
(3/4) Creating temporary files...
(4/4) Arming ConditionNeedsUpdate...
==> Création du paquet lokinet-bin 0.9.9-1 (jeu. 10 nov. 2022 08:57:55)
==> Récupération des sources…
  -> Téléchargement de lokinet-0.9.9.tar.xz…
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 3807k  100 3807k    0     0  1616k      0  0:00:02  0:00:02 --:--:-- 1616k
  -> lokinet.conf trouvé
  -> lokinet.service trouvé
  -> lokinet-vpn.service trouvé
  -> lokinet-bootstrap.service trouvé
  -> lokinet-default-config.service trouvé
  -> lokinet-resume.service trouvé
  -> lokinet.sysusers trouvé
  -> lokinet.tmpfiles trouvé
  -> lokinet.pkla trouvé
  -> lokinet.rules trouvé
  -> Téléchargement de LICENSE…
100 35148  100 35148    0     0   115k      0 --:--:-- --:--:-- --:--:--  115k
==> Validation des fichiers source avec sha256sums…
    lokinet-0.9.9.tar.xz ... RĂ©ussite
    lokinet.conf ... Ignoré
    lokinet.service ... RĂ©ussite
    lokinet-vpn.service ... RĂ©ussite
    lokinet-bootstrap.service ... RĂ©ussite
    lokinet-default-config.service ... RĂ©ussite
    lokinet-resume.service ... RĂ©ussite
    lokinet.sysusers ... RĂ©ussite
    lokinet.tmpfiles ... RĂ©ussite
    lokinet.pkla ... RĂ©ussite
    lokinet.rules ... RĂ©ussite
    LICENSE ... RĂ©ussite
 -> unbound dépendance non satisfaite, suppression de la file d'attente
==> Création du paquet lokinet-bin 0.9.9-1 (jeu. 10 nov. 2022 08:57:59)
==> Vérification des dépendances pour l’exécution…
==> Vérification des dépendances pour la compilation…
  -> lokinet-0.9.9.tar.xz trouvé
  -> LICENSE trouvé
==> Suppression du répertoire $srcdir/ existant…
==> Extraction des sources…
  -> Extraction de lokinet-0.9.9.tar.xz avec bsdtar
==> Les sources sont prĂŞtes.
==> Création du paquet lokinet-bin 0.9.9-1 (jeu. 10 nov. 2022 08:58:00)
==> ATTENTION : Utilisation de l’arbre $srcdir/ existant
==> Entre dans l’environnement fakeroot…
==> Lancement de package()…
==> Nettoyage de l’installation…
  -> Suppression des fichiers libtool…
  -> Suppression des fichiers indésirables…
  -> Suppression des fichiers de bibliothèques statiques…
  -> Nettoyage des symboles inutiles dans les fichiers binaires et les bibliothèques…
  -> Compression des pages de man/info…
==> Recherche des erreurs d’empaquetage…
==> Création du paquet « lokinet-bin »…
  -> Génération du fichier .PKGINFO…
  -> Génération du fichier .BUILDINFO…
  -> Ajout du fichier install…
  -> Génération du fichier .MTREE…
  -> Compression du paquet…
==> Quitte l’environnement fakeroot.
==> Création terminée : lokinet-bin 0.9.9-1 (jeu. 10 nov. 2022 08:58:01)
==> Nettoyage…
chargement des paquets…
Paquets (1) lokinet-bin-0.9.9-1
Taille totale installée :  10,22 MiB
(1/1) vérification des clés dans le trousseau        [-----------------------------------------------------------------------------] 100%
(1/1) vérification de l’intégrité des paquets        [-----------------------------------------------------------------------------] 100%
(1/1) chargement des fichiers des paquets        [-----------------------------------------------------------------------------] 100%
(1/1) analyse des conflits entre fichiers        [-----------------------------------------------------------------------------] 100%
(1/1) vérification de l’espace disque disponible        [-----------------------------------------------------------------------------] 100%
(1/1) installation de lokinet-bin        [-----------------------------------------------------------------------------] 100%
avertissement : les permissions pour le répertoire /usr/share/polkit-1/rules.d/ sont différentes
système de fichiers : 750, paquet : 755
  To generate default config (optional, will be invoked by lokinet service if needed):
    systemctl start lokinet-default-config
  To adjust upstream DNS servers and other options, edit /var/lib/lokinet/lokinet.ini
  To start lokinet:
  To get .loki domains resolve, enable systemd-resolved: https://wiki.archlinux.org/index.php/Systemd-resolved
  Alternatively, replace /etc/resolv.conf contents with:
    nameserver 127.3.2.1
[sum@ordi1 ~]$
[sum@ordi1 ~]$ systemctl start lokinet-default-config
[sum@ordi1 ~]$ systemctl status lokinet.service
â—Ź lokinet.service - LokiNET: Anonymous Network layer thingydoo
     Loaded: loaded (/usr/lib/systemd/system/lokinet.service; disabled; preset: disabled)
     Active: activating (auto-restart) (Result: exit-code) since Thu 2022-11-10 09:00:27 CET; 517ms ago
    Process: 15210 ExecStart=/usr/bin/lokinet lokinet.ini (code=exited, status=2)
   Main PID: 15210 (code=exited, status=2)
        CPU: 14ms
â–‘â–‘
nov. 10 09:00:37 ordi1 systemd[1]: lokinet.service: Scheduled restart job, restart counter is at 16.
░░ Subject: Le redémarrage automatique d'une unité (unit) a été planifié
â–‘â–‘
░░ Le redémarrage automatique de l'unité (unit) lokinet.service a été planifié, en
░░ raison de sa configuration avec le paramètre Restart=.
nov. 10 09:00:37 ordi1 systemd[1]: Stopped LokiNET: Anonymous Network layer thingydoo.
░░ Subject: L'unité (unit) lokinet.service a terminé son arrêt
â–‘â–‘
░░ L'unité (unit) lokinet.service a terminé son arrêt.
nov. 10 09:00:37 ordi1 systemd[1]: Starting LokiNET: Anonymous Network layer thingydoo...
░░ Subject: L'unité (unit) lokinet.service a commencé à démarrer
â–‘â–‘
░░ L'unité (unit) lokinet.service a commencé à démarrer.
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.589 GMT [+0.000s] /daemon/lokinet.cpp:238        Using config file: "lokinet.ini"
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.589 GMT [+0.000s] /llarp/context.cpp:64        lokinet-0.9.9-release Gluten Free Edition
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.589 GMT [+0.000s] /llarp/context.cpp:65        starting up
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.590 GMT [+0.001s] /llarp/router/router.cpp:1196        Bound RPC server to tcp://127.0.0.1:1190
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.590 GMT [+0.001s] /llarp/router/router.cpp:700        Loaded 3 bootstrap routers
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.590 GMT [+0.001s] /llarp/router/router.cpp:772        router profiling enabled
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.590 GMT [+0.001s] /llarp/router/router.cpp:775        no profiles file at "/var/lib/lokinet/profiles.dat" skipping
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.590 GMT [+0.001s] /llarp/handlers/tun.cpp:168        endpoint:yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy.loki setting to>
nov. 10 09:00:37 ordi1 lokinet[15242]: [NFO] [lokinet](830) 2022-11-10 08:00:37.591 GMT [+0.002s] /llarp/handlers/tun.cpp:344        endpoint:yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy.loki skipping l>
nov. 10 09:00:37 ordi1 lokinet[15242]: [ERR] [](830) 2022-11-10 08:00:37.593 GMT [+0.004s] /llarp/ev/ev_libuv.cpp:323        failed to bind and start receiving on 127.3.2.1:53: address already in use
nov. 10 09:00:37 ordi1 lokinet[15242]: [ERR] [](830) 2022-11-10 08:00:37.593 GMT [+0.004s] /llarp/handlers/tun.cpp:989        endpoint:epxz9xypmuebh6drogur7yg8kuku9mmpto3ufcujuewdsxyza8py.loki failed to start D>
nov. 10 09:00:37 ordi1 lokinet[15242]: [ERR] [](830) 2022-11-10 08:00:37.593 GMT [+0.004s] /llarp/service/context.cpp:153        default failed to start
nov. 10 09:00:37 ordi1 lokinet[15242]: [ERR] [](830) 2022-11-10 08:00:37.593 GMT [+0.004s] /llarp/router/router.cpp:1308        Failed to start hidden service context
nov. 10 09:00:37 ordi1 systemd[1]: lokinet.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
â–‘â–‘
â–‘â–‘
nov. 10 09:00:37 ordi1 systemd[1]: lokinet.service: Failed with result 'exit-code'.
â–‘â–‘
â–‘â–‘ The unit lokinet.service has entered the 'failed' state with result 'exit-code'.
nov. 10 09:00:37 ordi1 systemd[1]: Failed to start LokiNET: Anonymous Network layer thingydoo.
â–‘â–‘
lines 817-871/871 (END)
I explore as a user the distributed solutions I2P - IPFS - Zeronet…
If I feel it’s not mature, at least I know and can follow.
The analysis you indicate is certainly frightening (as any obscure cryptomining projet) : I’ll on ly test on my VM’s :wink:
Thats how I came to GNU/Linux frow W$: I waited till about 2010 to find user friendly distros :slight_smile:
Read and explore errors then. They are written right here:
I’d start with first one - what is already listening there? Some other instance of lokinet or whatever…
Hi, thank you for caring.
As said : I explore as a user, not as a dev.
Now I also can check when properly directed.
Here, could we have NextDNS as suspect ?
~]$ sudo ss -tunlp
Netid   State    Recv-Q   Send-Q     Local Address:Port      Peer Address:Port  Process
udp     UNCONN   0        0                0.0.0.0:53664          0.0.0.0:*      users:(("dat-fox-helper",pid=8783,fd=29))
udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*      users:(("dat-fox-helper",pid=8783,fd=25))
udp     UNCONN   0        0                0.0.0.0:5353           0.0.0.0:*      users:(("avahi-daemon",pid=631,fd=12))
udp     UNCONN   0        0                0.0.0.0:55073          0.0.0.0:*      users:(("firefox",pid=8548,fd=172))
udp     UNCONN   0        0                0.0.0.0:38713          0.0.0.0:*      users:(("firefox",pid=8548,fd=178))
udp     UNCONN   0        0                0.0.0.0:33096          0.0.0.0:*      users:(("avahi-daemon",pid=631,fd=14))
udp     UNCONN   0        0                0.0.0.0:59921          0.0.0.0:*      users:(("dat-fox-helper",pid=8783,fd=26))
udp     UNCONN   0        0                0.0.0.0:51961          0.0.0.0:*      users:(("firefox",pid=8548,fd=118))
udp     UNCONN   0        0                   [::]:5353              [::]:*      users:(("avahi-daemon",pid=631,fd=13))
udp     UNCONN   0        0                      *:53                   *:*      users:(("nextdns",pid=694,fd=11))
udp     UNCONN   0        0                      *:1716                 *:*      users:(("kdeconnectd",pid=1215,fd=13))
udp     UNCONN   0        0                   [::]:34816             [::]:*      users:(("avahi-daemon",pid=631,fd=15))
tcp     LISTEN   0        128            127.0.0.1:631            0.0.0.0:*      users:(("cupsd",pid=690,fd=9))
tcp     LISTEN   0        4096             0.0.0.0:80             0.0.0.0:*      users:(("docker-proxy",pid=1903,fd=4))
tcp     LISTEN   0        128                [::1]:631               [::]:*      users:(("cupsd",pid=690,fd=8))
tcp     LISTEN   0        512                    *:9117                 *:*      users:(("jackett",pid=691,fd=205))
tcp     LISTEN   0        4096                [::]:80                [::]:*      users:(("docker-proxy",pid=1909,fd=4))
tcp     LISTEN   0        4096                   *:53                   *:*      users:(("nextdns",pid=694,fd=10))
tcp     LISTEN   0        50                     *:1716                 *:*      users:(("kdeconnectd",pid=1215,fd=14))
tcp     LISTEN   0        511                    *:3051                 *:*      users:(("dat-fox-helper",pid=8783,fd=27))
tcp     LISTEN   0        511                    *:3282                 *:*      users:(("dat-fox-helper",pid=8783,fd=24))
configuring programs you want to use is not the job of a developer. It is the job of the user or the admin that maintains your systems.
You can’t configure two programs to listens on the same port.
Looks like it.
You’ll have to create lokinet conf and use some alternative port. :man_shrugging: (This is also mentioned in your logs: that there is no lokinet configuration detected)
@ this stage, i didn’t configure anything !
Just happens their conf uses this 53 port.
I’ll check how to amend one or the other :wink:
Your are responsible for software you installed.
Port 53 is a standardized port by IANA for the Domain Name System. There is probably a reason why port 53 is used.
This is exactly what I mean as being a “user exploring” : to a user anything should be plug’n play.
I get the 53 stuff. I’ll test a new. conf and I’ll stock Lokinet in the “remind it exists” slot.
