Hello,
So I just installed Manjaro KDE. I typed the command sudo journalctl -p 3 -xb in terminal to check if there were any errors and I got greeted by a ton of them.
Should I be worried ?
Errors:
Thanks for the response
Hello,
Errors:
You should not be concerned about this error.
Can you post inxi -Fza ?
