Errors messages while restarting and shutting down
There are some error messages that show up for a split second before rebooting/shutting down whenever I try to restart or shutdown my computer, I’ve actually looked them up, but most people who have these errors seem to have issues getting certain things to work, but in my case I have not noticed anything like that, everything seem to work fine on my laptop, here are the messages:
These show up when I try to reboot:
[ 151.193820] watchdog: watchdog0: watchdog did not stop!
[ 151.332061] rmi4_physical rmi4_00: Failed to read irqs, code=6
[ 151.389974] reboot: Restarting system
and these show up when I try to shutdown:
[ 88.123756] rmi4_physical rmi4_00: Failed to read irqs, code=6
[ 88.465334] reboot: Power down
and journalctl -x -p3 -b1 returns this:
-- Logs begin at Sun 2020-08-30 03:15:53 +06, end at Sun 2020-08-30 13:55:29 +06. --
Aug 30 03:15:56 HOST kernel: nouveau 0000:04:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
Aug 30 03:15:59 HOST kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Aug 30 03:16:09 HOST kernel: nouveau 0000:04:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
Aug 30 03:16:28 HOST lightdm[1181]: gkr-pam: unable to locate daemon control file
Aug 30 03:16:38 HOST lightdm[1198]: gkr-pam: unable to locate daemon control file
Aug 30 03:29:56 HOST kernel: nouveau 0000:04:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
Aug 30 03:29:57 HOST kernel: watchdog: watchdog0: watchdog did not stop!
Any Idea what’s going on or what should I do?
inxi:
  Kernel: 5.4.60-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=b9361f3f-b9aa-4a7b-8f2a-c2c8ee2602ab rw quiet apparmor=1
  security=apparmor resume=UUID=b169a4c9-a72c-4447-bec0-ee60387ed32f
  udev.log_priority=3
  Desktop: Cinnamon 4.6.7 tk: GTK 3.24.22 dm: LightDM 1.30.0
  Distro: Manjaro Linux
  Type: Laptop System: LENOVO product: 20DM000VUS v: ThinkPad S3 Yoga 14
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20DM000VUS v: SDK0E50512 STD serial: <filter>
  UEFI: LENOVO v: JGET34WW (1.20 ) date: 12/04/2018
  ID-1: BAT0 charge: N/A condition: N/A volts: N/A model: N/A type: Li-ion
  serial: <filter> status: Charging
  Topology: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26
  L2 cache: 3072 KiB
  bogomips: 19161
  Speed: 1401 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 1252 2: 1268
  3: 1355 4: 1254
  Type: l1tf
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:0a16
  Device-2: NVIDIA GM108M [GeForce 840M] vendor: Lenovo driver: nouveau
  v: kernel bus ID: 04:00.0 chip ID: 10de:1341
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-7:4
  chip ID: 04f2:b46a serial: <filter>
  Display: x11 server: X.Org 1.20.8 driver: intel,nouveau
  unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
  diag: 354mm (13.9")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
  v: 4.5 Mesa 20.1.6 compat-v: 3.0 direct render: Yes
  Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 00:03.0 chip ID: 8086:0a0c
  Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus ID: 00:1b.0 chip ID: 8086:9c20
  Sound Server: ALSA v: k5.4.60-2-MANJARO
  Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel port: efa0
  bus ID: 02:00.0 chip ID: 8086:08b2
  Local Storage: total: 480.68 GiB used: 12.35 GiB (2.6%)
  ID-1: /dev/sda vendor: SanDisk model: SSD U110 16GB size: 14.91 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
  rev: 001 scheme: MBR
  ID-2: /dev/sdb vendor: Seagate model: ST500LT012-9WS142 size: 465.76 GiB
  block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
  ID-1: / raw size: 147.95 GiB size: 144.63 GiB (97.75%)
  used: 12.35 GiB (8.5%) fs: ext4 dev: /dev/sdb8
  Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sdb7
  System Temperatures: cpu: 59.0 C mobo: 41.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 198 Uptime: 20m Memory: 7.69 GiB used: 1.43 GiB (18.6%)
  Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1092 lib: 288
  flatpak: 0 Shell: Bash v: 5.0.18 running in: gnome-terminal inxi: 3.1.05
As long as you have no other issues - you are safe to ignore it.
