Hi, when I try to install manjaro the installation programm throws an error:
<class 'OSError'>
[Errno 30] Read-only file system: '/tmp/calamares-root-hn3xad2b/etc/locale.conf'
Traceback:
File "/usr/lib/calamares/modules/localecfg/main.py", line 158, in run
with open(target_locale_conf_path, "w") as lcf
I also tried to run the installation from cli with root permissons and this was the output:
~ sudo calamares ✔ 4m 58s
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
chcon: failed to get security context of '/': Operation not supported
chcon: failed to get security context of '/boot/efi': Operation not supported
chcon: failed to get security context of '/dev': Operation not supported
chcon: failed to get security context of '/proc': Operation not supported
chcon: failed to get security context of '/run': Operation not supported
chcon: failed to get security context of '/run/udev': Operation not supported
chcon: failed to get security context of '/sys': Operation not supported
chcon: failed to get security context of '/sys/firmware/efi/efivars': Operation not supported
20:10:24 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
ERROR: Installation failed: "Boost.Python-Fehler in Job \"localecfg\"."
That’s my inxi output:
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2121 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B450 AORUS PRO v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B450 AORUS PRO-CF serial: <superuser required>
UEFI: American Megatrends v: F60c date: 10/29/2020
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1925 high: 2584 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1928 2: 2032
3: 1717 4: 1714 5: 1887 6: 1884 7: 2201 8: 1977 9: 2584 10: 1720 11: 1788
12: 1785 13: 1886 14: 1886 15: 1927 16: 1886 bogomips: 118219
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
STIBP: disabled, RSB filling
Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:687f class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
v: kernel bus-ID: 0a:00.1 chip-ID: 1002:aaf8 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media MAXTER 7.1 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:4 chip-ID: 0d8c:0012
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter
driver: bcma-pci-bridge v: N/A modules: bcma bus-ID: 06:00.0
chip-ID: 14e4:43a0 class-ID: 0280
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-2:2 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 2.16 TiB used: 21.94 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 023 scheme: MBR
ID-2: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A02 scheme: GPT
ID-3: /dev/sdd maj-min: 8:48 type: USB vendor: Intenso model: Ultra Line
size: 115.23 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1100 scheme: MBR
ID-4: /dev/sde maj-min: 8:64 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 030 scheme: GPT
System Temperatures: cpu: 41.4 C mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1
Processes: 377 Uptime: 24m wakeups: 0 Memory: 15.61 GiB
used: 3.02 GiB (19.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1228 lib: 331 flatpak: 0 Shell: Zsh v: 5.8
default: Bash v: 5.1.12 running-in: yakuake inxi: 3.3.11
