Error updating manjaro-pacnew-checker
I just started using manjaro-pacnew-checker and received an error on this mornings update “command failed to execute correctly”
 sudo pacman -Syu
 core is up to date
 extra        8.6 MiB  16.0 MiB/s 00:01 [---------------------------------------------------------------------------------------] 100%
 multilib is up to date
resolving dependencies...
Packages (1) manjaro-pacnew-checker-0.4.0-1
Total Download Size:   0.01 MiB
Total Installed Size:  0.00 MiB
Net Upgrade Size:      0.00 MiB
:: Retrieving packages...
 manjaro-pacnew-checker-0.4.0-1-any        6.6 KiB  82.6 KiB/s 00:00 [---------------------------------------------------------------------------------------] 100%
(1/1) checking keys in keyring        [---------------------------------------------------------------------------------------] 100%
(1/1) checking package integrity        [---------------------------------------------------------------------------------------] 100%
(1/1) loading package files        [---------------------------------------------------------------------------------------] 100%
(1/1) checking for file conflicts        [---------------------------------------------------------------------------------------] 100%
(1/1) checking available disk space        [---------------------------------------------------------------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) upgrading manjaro-pacnew-checker        [---------------------------------------------------------------------------------------] 100%
Reboot the system to apply new systemd configuration
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
(3/3) Looking for Pacnew/Pacsave created.
error: command failed to execute correctlytype or paste code here
and if it helps my system info
inxi -v7azy
  Kernel: 6.1.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    root=UUID=cdec8c27-c94a-42bc-b791-7a921a36d97f rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
  Type: Desktop System: System76 product: Thelio v: thelio-b3
    serial: <superuser required> Chassis: type: 3 v: thelio-b3
  Mobo: System76 model: Thelio v: x.x serial: <superuser required>
    UEFI: System76 v: F5b Z5 date: 10/11/2022
  System RAM: total: 16 GiB note: est. available: 15.4 GiB
    used: 2.6 GiB (16.9%)
  Info: model: Intel Pentium Gold G7400 bits: 64 type: MT MCP arch: Alder Lake
    level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
    model-id: 0x97 (151) stepping: 5 microcode: 0x2E
    L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 2.5 MiB desc: 2x1.2 MiB
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3700 min/max: 800/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3700 2: 3700 3: 3700 4: 3700 bogomips: 29500
    de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
    waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Alder Lake-S GT1 [UHD Graphics 710] vendor: Gigabyte
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:4693 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.2.0
    compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 res: 1920x1080 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: Mesa Intel UHD Graphics 710
    (ADL-S GT1) direct-render: Yes
  Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
    class-ID: 0403
  API: ALSA v: k6.1.49-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.78 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0033 class-ID: e001
  Local Storage: total: 931.51 GiB used: 455.31 GiB (48.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 30.9 C
    scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 455.31 GiB (49.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: cdec8c27-c94a-42bc-b791-7a921a36d97f
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 8C5C-08EA
  Hub-2: 1-4:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
  Device-1: 1-4.1:5 info: Logitech USB Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 90mA chip-ID: 046d:c34b class-ID: 0300
  Device-2: 1-5:3 info: Generic Io type: abstract (modem),CDC-data
    driver: N/A interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 1209:1776 class-ID: 0a00 serial: <filter>
  Device-3: 1-8:4 info: Logitech Mouse type: mouse driver: hid-generic,usbhid
    interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 046d:c077 class-ID: 0301
  Device-4: 1-11:6 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-5: 1-14:7 info: Intel type: bluetooth driver: btusb interfaces: 2
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
  Hub-3: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  Hub-4: 2-4:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
  System Temperatures: cpu: 27.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 195 Uptime: 23m wakeups: 0 Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1237 libs: 376 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
It looks like it updated.
might help
I’ve done that. Guess it’s just a matter of waiting for a pacnew file to be created.
I just tested and could not reproduce. I had updates for chromium, m-p-c and i actually created a copy of a .conf.pacnew to simulate it and it worked.
There is a new update to manjaro-pacnew-checker to 0.4.1-1 this morning. Let’s see what happens…
I created a new .conf.pacnew, but didn’t get a notification. So I did the old uninstall-install trick and it found the .pacnew file I created and completed the task. So I’ll mark this solved, just wish I knew what went wrong.
