Error: unknown filesystem. grub rescue
I take a bit of responisibility for that, I should have mentioned CSM too, not just call it efi, I just forgot tbh.
You can read up a little what it is here:
Yeah, select your own post as the solution (so this thread closes after a few days) and move on, start another thread if needed.
BUT, I can tell you this. You most likely will end up reinstalling anyway, 15 months of not updating is most likely NOT a situation you want to repair, that is a reinstall situation.
But keep your home so the settings transfer to your new install (or not, your choice)
All good, we are all human and in the end it was probably due to me causing this anyway.
In any case I really appreciate your time.
Thank’s for the extra info.
My intention is to learn to fix it, recover my random stuff and then move to a new install.
Thank you :smile:
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
