Error uninstalling Flatpak?
I uninstalled Flatpack with:
sudo rm -r /var/lib/flatpak
rm -r ~/.local/share/flatpak
But whenever I was once in the settings of Pamac, ~/.local/share/flatpak is created again. Does this mean that everything is not yet uninstalled from Flatpak?
Why not removing it by
sudo pacman -Rsn flatpak
Removing local files in ~/.local/share/flatpak is a good idea but just in addition.
This will probably not work now, since Flatpack is already gone.
I doubt it. Removing files to remove a package is, let’s say sub-optimal. :rofl:
Fehler: Ziel nicht gefunden: flatpak
For exact this reason. I’m sure you still have residues of flatpak causing the issue why you opened this topic. You could re-install it and remove it again (this time both by pacman).
So I should install Flatpak again before to be able to uninstall it properly?
sudo pacman -S flatpak ?
thx :ok_hand:t2:
Don’t forget: Installing only after updating your system. :wink:
Can I do the same with snapd? Have so far only removed it with pamac remove snapd.
Yes, of course.
Nevertheless, the folder ~/.local/share/flatpak is now back.
I am not interested in this empty folder, but in the mystery of its appearance … :thinking:
Maybe it never disappeared, try sudo
sudo rm -r ~/.local/share/flatpak
OK, that brings the desired result. I would never have thought of doing something with sudo in the home-folder … THANKS!
After a few restarts: YES, the folder is back … the ghost in the shell … :ghost:
There are also plugins for pamac
pamac-flatpak-plugin
pamac-snap-plugin
Could be that creates the folder? :thinking: :crossed_fingers:
with
sudo pacman -R pamac-flatpak-plugin
I got an error: Fehler: Ziel nicht gefunden: pamac-flatpak-plugin
In addition, there is nothing more to be found in the settings of pamac from Flatpak.
Just a thought: after I uninstalled snap and flatpak on the current Manjaro (KDE), ostree appeared in the orphaned files. I was not sure and marked it as “Explicitly installed”. But now I read that ostree is also used by flatpack. Could this be a connection?
