Error: physical layout false, rawOrder false and an area does not work well together
I had baloo file indexer disabled for hibernation reasons, but I just enabled it again for testing with balooctl6 enable and got the following errors displayed in the terminal window (after the command had completed). I can’t seem to find any info on them. Anyone know what this is about?
qt.qpa.services: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.baloo'")
"Error: physical layout false, rawOrder false and an area does not work well together"
It’s possible your identical KDE Discuss question will generate better responses than the forum, currently.
Although with the type of error, it might be prudent to report a possible bug directly to KDE:
Otherwise, please provide your system information as described (below) and take the gamble that a Community member may have a clue: :point_down:
inxi -zv8 (short-form)
Your privacy is respected
They don’t accept bug reports for old versions which is why I posted here (and in the official KDE forum). Especially because extensive searching provided no hits for the displayed error:
— Comment #1 from Bug Janitor Service <bug-janitor@kde.org> —
Thank you for the bug report!
However Plasma 6.5.5 no longer receives updates or maintenance from KDE; active
versions are 6.6 or newer. Please upgrade to an active version as soon as your
distribution makes it available to you. Plasma is a fast-moving project, and
bugs in one version are often fixed in the next one.
If you need help with Plasma 6.5.5, please contact your distribution, who bears
the responsibility of providing help for older releases that are no longer
receiving updates from KDE.
If you can reproduce the issue after upgrading to an active version, feel free
to re-open this bug report.
inxi -zv8
  Kernel: 6.19.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.19-x86_64
    root=UUID=ca0fb9dc-ae10-46f2-a467-6c788f67cecc rw rootflags=subvol=@
    quiet splash resume=UUID=a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
    udev.log_priority=3 sysrq_always_enabled=1
  Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.23.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Convertible System: Dell product: XPS 15 9575 v: N/A
    serial: <superuser required> Chassis: type: 31 serial: <superuser required>
  Mobo: Dell model: 0C32VW v: A00 serial: <superuser required> part-nu: 080D
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: 1.28.0
    date: 07/11/2023
  ID-1: BAT0 charge: 44.4 Wh (100%) condition: 44.4/75 Wh (59.2%) volts: 12.74
    min: 11.4 model: BYD DELL TMFYT8C type: Li-poly serial: <filter> charging:
    status: full type: custom avail: adaptive,custom,fast,standard,trickle
    cycles: N/A
  System RAM: total: 16 GiB available: 15.46 GiB used: 5.43 GiB (35.1%)
  Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
  Device-1: Motherboard type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: SK Hynix
    part-no: HMAA51S6AMR6N-UH serial: N/A
  Info: model: Intel Core i7-8705G bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3562 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3562 2: 3562 3: 3562 4: 3562 5: 3562 6: 3562
    7: 3562 8: 3562 bogomips: 49599
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel Kaby Lake-H GT2 [HD Graphics 630] vendor: Dell driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0 chip-ID: 8086:591b
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Polaris 22 XL [Radeon RX Vega
    M GL] vendor: Dell driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 01:00.0 chip-ID: 1002:694e class-ID: 0380
    temp: 51.0 C
  Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0bda:58f4
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    alternate: fbdev,vesa dri: iris,radeonsi gpu: i915 display-ID: 0
  Monitor-1: eDP-1 model: Sharp 0x148d built: 2018 res: mode: 2560x1440
    hz: 60 scale: 125% (1.25) to: 2048x1152 dpi: 284 gamma: 1.2 chroma: red:
    x: 0.667 y: 0.325 green: x: 0.208 y: 0.737 blue: x: 0.145 y: 0.047 white:
    x: 0.318 y: 0.337 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 3840x2160
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    device-ID: 8086:591b memory: 15.1 GiB unified: yes display-ID: :0.0
  API: Vulkan v: 1.4.341 layers: 13 device: 0 type: integrated-gpu
    name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 25.3.5-arch1.1
    device-ID: 8086:591b surfaces: N/A device: 1 type: discrete-gpu name: AMD
    Radeon RX Vega M GL Graphics (RADV VEGAM) driver: mesa radv
    v: 25.3.5-arch1.1 device-ID: 1002:694e surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel HM175/QM175/CM238 HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a171 class-ID: 0403
  API: ALSA v: k6.19.2-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer 1435 Wireless-AC driver: ath10k_pci v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e
    class-ID: 0280 temp: 45.0 C
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.2:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s20f0u2u2 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0489:e0a2
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 110.86 GiB (6.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T710SSD8
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: PBCR5103 temp: 37.9 C
    scheme: GPT
  ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 110.84 GiB (6.0%)
    fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: Manjaro
    uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
    used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: FF0B-6823
  ID-3: /home raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
    used: 110.84 GiB (6.0%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
    label: Manjaro uuid: ca0fb9dc-ae10-46f2-a467-6c788f67cecc
  ID-4: /home/<filter>/mnt/Dropbox raw-size: N/A size: 2.01 TiB
    used: 338.63 GiB (16.5%) fs: fuse.rclone remote: Dropbox:
  ID-5: /home/<filter>/mnt/GDrive raw-size: N/A size: 102 GiB
    used: 24.39 GiB (23.9%) fs: fuse.rclone remote: GDrive:
  ID-6: /home/<filter>/mnt/OneDrive raw-size: N/A size: 205 GiB
    used: 143.4 GiB (70.0%) fs: fuse.rclone remote: OneDrive:
  ID-7: /var/cache raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  ID-8: /var/log raw-size: 1.8 TiB size: 1.8 TiB (100.00%)
  ID-1: swap-1 type: partition size: 17.58 GiB used: 14.2 MiB (0.1%)
    priority: -1 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: a044a1dc-dfd0-493a-b7d8-18cbe3abe8c1
  Device-1: 1-1:2 info: Realtek Integrated_Webcam_HD type: video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:58f4 class-ID: 0e02
    serial: <filter>
  Hub-2: 1-2:3 info: VIA Labs VL820 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2820
  Device-1: 1-2.1:6 info: Bizlink DELL DA300 type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 06c4:c412 class-ID: 0300
    serial: <filter>
  Device-2: 1-2.3:9 info: Lite-On USB Multimedia Keyboard type: keyboard,HID
    chip-ID: 04ca:0027 class-ID: 0300
  Device-3: 1-6:4 info: Foxconn / Hon Hai type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0489:e0a2 class-ID: e001
  Device-4: 1-10:5 info: Shenzhen Goodix Fingerprint Reader
    type: abstract (modem),CDC-data driver: N/A interfaces: 2 rev: 2.0
    chip-ID: 27c6:5395 class-ID: 0a00 serial: <filter>
  Device-5: 1-11:7 info: Logitech G502 Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c07d class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  Hub-4: 2-2:2 info: VIA Labs VL820 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0820
  Device-1: 2-2.2:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 51.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1771 libs: 464 tools: pamac pm: flatpak pkgs: 0
    1: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    3: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    4: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    5: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    6: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    7: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    8: https://mirror.easyname.at/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 302
  1: cpu: 11.8% command: librewolf pid: 91357 mem: 355.6 MiB (2.2%)
  2: cpu: 8.9% command: librewolf pid: 84974 mem: 800.5 MiB (5.0%)
  3: cpu: 8.6% command: librewolf pid: 90830 mem: 602.2 MiB (3.8%)
  4: cpu: 3.2% command: librewolf pid: 85275 mem: 640.6 MiB (4.0%)
  5: cpu: 1.8% command: konsole pid: 91756 mem: 236.4 MiB (1.4%)
  Memory top: 5 of 302
  1: mem: 800.5 MiB (5.0%) command: librewolf pid: 84974 cpu: 8.9%
  2: mem: 640.6 MiB (4.0%) command: librewolf pid: 85275 cpu: 3.2%
  3: mem: 602.2 MiB (3.8%) command: librewolf pid: 90830 cpu: 8.6%
  4: mem: 501.9 MiB (3.1%) command: plasmashell pid: 1556 cpu: 0.2%
  5: mem: 416.8 MiB (2.6%) command: baloo_file_extractor pid: 6190 cpu: 1.2%
  Processes: 302 Power: uptime: 1d 1h 29m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 fails: 18 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.16 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 259 default: graphical tool: systemctl
  Compilers: clang: 21.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
    inxi: 3.3.40
Your system is out-of-date, as Stable branch is currently on kernel 6.19.8-1. So, try updating your system first, and see if the issue persists after rebooting.
If it does, then purging the baloo database may fix the issue. If you have not had baloo running for a while, then maybe the database format or layout has changed since then, and the newer version of baloo is having issues with the older database.
balooctl6 purge
will clear the database, and baloo will then create a new one & re-index your files.
balooctl6 --help
balooctl6 --help
Usage: balooctl6 [options] command status enable disable purge suspend resume check index clear config monitor indexSize failed
Options:
  -f, --format <format>  Output format <multiline|json|simple>.
                         The default format is "multiline".
                         Only applies to "balooctl status <file>"
  -v, --version          Displays version information.
  -h, --help             Displays help on commandline options.
  --help-all             Displays help, including generic Qt options.
Arguments:
  command                The command to execute
  status                 Print the status of the indexer
  enable                 Enable the file indexer
  disable                Disable the file indexer
  purge                  Remove the index database
  suspend                Suspend the file indexer
  resume                 Resume the file indexer
  check                  Check for any unindexed files and index them
  index                  Index the specified files
  clear                  Forget the specified files
  config                 Modify the Baloo configuration
  monitor                Monitor the file indexer
  indexSize              Display the disk space used by index
  failed                 Display files which could not be indexed
I reported the issue prior to that version becoming available.
I also can’t reproduce the issue and cannot track down exactly what caused it. I don’t know if the repeating errors following the first error are related to the first or if they were coincidental. I presume they’re related as they all appeared within a few seconds of each other.
I’m trying to get an idea of what caused the errors so I can go investigate further and report it to the right place.
The first error is a common error appearing in system logs recently which most people have said to just ignore.
Thanks for the reminder: I had tried purging the database, rebuilding the database, enabling and disabling baloo numerous times trying to get the error to appear again but have had no luck in reproducing it. The fact the errors displayed in a terminal at all is a problem that should have been caught and sent to the system or other log. The command had finished and a prompt had been displayed for perhaps a minute before these errors appeared.
