"error: no such device:" after fresh install
gnome
installation
#1
Hi people,
I just tried a fresh install of the Gnome version from usbstick. The graphical installation run smoothly. I choose encrypted installation.
When starting after the installation I always get:
“error: no such device: 6636xxx-xxxx-…
error: unknown filesystem.
Entereing rescue mode…”
I tried searching but all the answers where for completely different situations.
Any help is appreciated.
Edit: I made a cmos reset because I though it might have to do with TPM, nothing.
Edit2: I have an nvme SSD
Edit3:
cryptsetup luksOpen /dev/nvme0n1p2 crypt
mount /dev/mapper/crypt /mnt
mount /dev/nvme0n1p1 /mnt/boot/efi
manjaro-chroot /mnt
pacman -S os-prober
grub-install /dev/nvme0n1
mkinitcpio -P
grub-mkconfig -o /boot/grub/grub.cfg
exit
reboot
results in:
Generating grub configuration file …
Found linux image: /boot/vmlinuz-4.19-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-4.19-x86_64.img
Found initrd fallback image: /boot/initramfs-4.19-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
/usr/grub/grub-probe: warning: unknown device type dm-0.
done
where /dev/sda is the installation USB-Stick
Manjaro will not boot after fresh install (KDE 18.0.3, Architect 18.0.2)
#2
And
$ inxi -Fxxxz
Work unencrypted?
#3
I will give the list of things needed to trouble shoot from another post here. System not booting after update: "ERROR: device UUID <ID> not found. Skipping fsck.", dropped into emergency shell
So in any case the fastest way to fix this situation is usually to boot from Manjaro live and chroot into the installed system and then update everything with sudo pacman -Syuu and then rebuild the kernel sudo mkinitcpio -P and finally sudo update-grub.
Reboot and see what happens, if it fails again please report back with the output of the list from the other post I linked.
#4
[manjaro@manjaro-gnome ~]$ inxi -D
Drives:    Local Storage: total: 525.38 GiB used: 5.87 GiB (1.1%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB
           ID-2: /dev/sda type: USB vendor: Lexar model: USB Flash Drive size: 59.62 GiB
[manjaro@manjaro-gnome ~]$ inxi -Fxz
System:    Host: manjaro-gnome Kernel: 4.19.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
           Desktop: Gnome 3.30.2 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: Micro-Star model: X470 GAMING PRO (MS-7B79) v: 1.0 serial: <filter>
           UEFI: American Megatrends v: 1.60 date: 12/17/2018
CPU:       Topology: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ rev: 2 L2 cache: 3072 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86421
           Speed: 1952 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 1805 2: 1982 3: 2563 4: 2882 5: 2189
           6: 2429 7: 1814 8: 1822 9: 1772 10: 1835 11: 2566 12: 2849
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Lexa PRO [Radeon RX 550/550X] vendor: ASRock driver: amdgpu
           v: kernel bus ID: 1d:00.0
           Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X]
           vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 1e:00.0
           Display: x11 server: X.org 1.20.3 driver: amdgpu resolution: <xdpyinfo missing>
           OpenGL: renderer: Radeon 550 Series (POLARIS12 DRM 3.27.0 4.19.23-1-MANJARO LLVM 7.0.1)
           v: 4.5 Mesa 18.3.3 direct render: Yes
Audio:     Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] vendor: ASRock
           driver: snd_hda_intel v: kernel bus ID: 1d:00.1
           Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX 580] vendor: ASUSTeK
           driver: snd_hda_intel v: kernel bus ID: 1e:00.1
           Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus ID: 20:00.3
           Device-4: Creative type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-4:2
           Sound Server: ALSA v: k4.19.23-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169
           v: kernel port: f000 bus ID: 18:00.0
           IF: enp24s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Partition: ID-1: / size: 11.76 GiB used: 97.2 MiB (0.8%) fs: overlay source: ERR-102
Sensors:   System Temperatures: cpu: 40.1 C mobo: N/A
           GPU: device: amdgpu temp: 34 C fan: 1066 device: amdgpu temp: 43 C fan: 984
Info:      Processes: 336 Uptime: 7m Memory: 15.67 GiB used: 1.42 GiB (9.0%) Init: systemd Compilers: gcc: N/A
           Shell: bash v: 5.0.0 inxi: 3.0.30
[manjaro@manjaro-gnome ~]$ sudo inxi -apd
Drives:    Local Storage: total: 525.38 GiB used: 5.88 GiB (1.1%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB block size: physical: 512 B
           logical: 512 B
           ID-2: /dev/sda type: USB vendor: Lexar model: USB Flash Drive size: 59.62 GiB block size:
           physical: 512 B logical: 512 B
Partition: ID-1: / raw size: N/A size: 11.76 GiB used: 108.0 MiB (0.9%) fs: overlay source: ERR-102
           ID-2: /mnt raw size: 465.45 GiB size: 457.14 GiB (98.22%) used: 5.78 GiB (1.3%) fs: ext4
           block size: 4096 B dev: /dev/dm-0
           ID-3: /mnt/boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%) used: 280 KiB (0.1%) fs: vfat
           block size: 512 B dev: /dev/nvme0n1p1
           ID-4: /run/miso/bootmnt raw size: 1.89 GiB size: N/A (hidden?) used: N/A (hidden?) fs: iso9660
           dev: /dev/sda1
           ID-5: /run/miso/sfs/desktopfs raw size: 1008.3 MiB size: N/A (hidden?) used: N/A (hidden?) fs: squashfs
           dev: /dev/loop2
           ID-6: /run/miso/sfs/livefs raw size: 75.4 MiB size: N/A (hidden?) used: N/A (hidden?) fs: squashfs
           dev: /dev/loop0
           ID-7: /run/miso/sfs/mhwdfs raw size: 314.5 MiB size: N/A (hidden?) used: N/A (hidden?) fs: squashfs
           dev: /dev/loop1
           ID-8: /run/miso/sfs/rootfs raw size: 475.4 MiB size: N/A (hidden?) used: N/A (hidden?) fs: squashfs
           dev: /dev/loop3
[manjaro@manjaro-gnome ~]$ journalctl -b -p3 --no-hostname --no-pager
-- Logs begin at Thu 2019-02-21 17:14:28 CET, end at Thu 2019-02-21 17:23:15 CET. --
Feb 21 17:14:28 kernel: tpm_crb MSFT0101:00: can't request region for resource [mem 0xbd745000-0xbd745fff]
Feb 21 17:14:28 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Feb 21 17:14:54 colord-sane[2122]: io/hpmud/pp.c 627: unable to read device-id ret=-1
[manjaro@manjaro-gnome ~]$  inxi -Fxxxz
           Desktop: Gnome 3.30.2 wm: gnome-shell dm: GDM 3.30.2 Distro: Manjaro Linux
           Speed: 1874 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2130 2: 1752 3: 2566 4: 2888
           5: 1777 6: 1979 7: 3047 8: 3197 9: 1831 10: 1833 11: 2566 12: 2878
           v: kernel bus ID: 1d:00.0 chip ID: 1002:699f
           vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 1e:00.0 chip ID: 1002:67df
           Display: x11 server: X.org 1.20.3 driver: amdgpu compositor: gnome-shell resolution: <xdpyinfo missing>
           driver: snd_hda_intel v: kernel bus ID: 1d:00.1 chip ID: 1002:aae0
           driver: snd_hda_intel v: kernel bus ID: 1e:00.1 chip ID: 1002:aaf0
           v: kernel bus ID: 20:00.3 chip ID: 1022:1457
           Device-4: Creative type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 5-4:2 chip ID: 041e:3238
           serial: <filter>
           v: kernel port: f000 bus ID: 18:00.0 chip ID: 10ec:8168
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 500GB size: 465.76 GiB speed: 31.6 Gb/s lanes: 4
           serial: <filter> rev: 2B2QEXE7 scheme: GPT
           ID-2: /dev/sda type: USB vendor: Lexar model: USB Flash Drive size: 59.62 GiB serial: <filter> rev: 1100
           scheme: MBR
Partition: ID-1: / size: 11.76 GiB used: 108.0 MiB (0.9%) fs: overlay source: ERR-102
Sensors:   System Temperatures: cpu: 37.2 C mobo: N/A
           GPU: device: amdgpu temp: 33 C fan: 1104 device: amdgpu temp: 45 C fan: 986
Info:      Processes: 333 Uptime: 9m Memory: 15.67 GiB used: 1.44 GiB (9.2%) Init: systemd v: 241 Compilers:
           gcc: N/A Shell: bash v: 5.0.0 running in: gnome-terminal inxi: 3.0.30
#5
[manjaro-gnome manjaro]# cryptsetup luksOpen /dev/nvme0n1p2 crypt
Enter passphrase for /dev/nvme0n1p2:
No key available with this passphrase.
[manjaro-gnome manjaro]# mount /dev/mapper/crypt /mnt
[manjaro-gnome manjaro]# mount /dev/nvme0n1p1 /mnt/boot/efi
[manjaro-gnome manjaro]# manjaro-chroot /mnt
sh-5.0# pacman -S os-prober
warning: os-prober-1.76-2 is up to date -- reinstalling
resolving dependencies...
Packages (1) os-prober-1.76-2
Total Installed Size:  0.13 MiB
Net Upgrade Size:      0.00 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring                                               [############################################] 100%
(1/1) checking package integrity                                             [############################################] 100%
(1/1) loading package files                                                  [############################################] 100%
(1/1) checking for file conflicts                                            [############################################] 100%
(1/1) checking available disk space                                          [############################################] 100%
(1/1) reinstalling os-prober                                                 [############################################] 100%
(1/1) Arming ConditionNeedsUpdate...
sh-5.0# pacman -Syuu
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 there is nothing to do
sh-5.0# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'default'
  -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64.img
==> Starting build: 4.19.23-1-MANJARO
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [encrypt]
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux419.preset: 'fallback'
  -> -k /boot/vmlinuz-4.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-4.19-x86_64-fallback.img
sh-5.0# update-grub
/usr/bin/grub-probe: warning: unknown device type dm-0.
done
sh-5.0#
Did not work. BTW /dev/sda ist the install usbstick.
#6
Bummer, is the device mapper module loading.
Stolen from another thread,
First is it there?
> modinfo dm-mod
Then load it if it is
modprobe dm-mod
Then update grub again.
#7
BTW I posted you the wront info I think, here is the output from you Link.
[manjaro-gnome manjaro]# fsck /dev/nvme0n1p1
fsck from util-linux 2.33.1
#fsck.fat 4.1 (2017-01-24)
/dev/nvme0n1p1: 6 files, 70/76646 clusters
[manjaro-gnome manjaro]# fsck /dev/nvme0n1p2
[manjaro-gnome manjaro]# fsck /dev/mapper/crypt
e2fsck 1.44.5 (15-Dec-2018)
/dev/mapper/crypt: clean, 286590/30507008 files, 3691814/122014600 blocks
[manjaro-gnome manjaro]# parted -l
Model: Lexar USB Flash Drive (scsi)
Disk /dev/sda: 64.0GB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 2      2026MB  2030MB  4194kB  primary               esp
Model: Unknown (unknown)
Disk /dev/nvme0n1: 500GB
Partition Table: gpt
Disk Flags:
Number  Start   End    Size   File system  Name  Flags
 1      2097kB  317MB  315MB  fat32              boot, esp
 2      317MB   500GB  500GB
[manjaro-gnome manjaro]# blkid
/dev/nvme0n1: PTUUID="582c5d8b-f652-4d04-a3b8-24365bf9b2da" PTTYPE="gpt"
/dev/nvme0n1p1: UUID="2FBB-ED3B" TYPE="vfat" PARTUUID="0e10cc54-d875-4bb8-a9d7-c22050863a50"
/dev/nvme0n1p2: UUID="b4cb221a-cbf8-432c-80b8-22f9c1445172" TYPE="crypto_LUKS" PARTUUID="28e8dbb2-d4d4-486c-bf09-cf228f34ba18"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/sda1: UUID="2019-02-19-13-43-43-00" LABEL="M1803" TYPE="iso9660"
/dev/sda2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="6A17-49FC" TYPE="vfat"
/dev/mapper/crypt: UUID="ddcb11d9-34bb-4f1c-b3b1-63c3266be82e" TYPE="ext4"
[manjaro-gnome manjaro]# efibootmgr -v
BootCurrent: 0006
Timeout: 1 seconds
BootOrder: 0000,0003,0006,0005,0001,0004
Boot0000* manjaro	HD(1,GPT,0e10cc54-d875-4bb8-a9d7-c22050863a50,0x1000,0x96000)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot0001  Hard Drive	BBS(HD,,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0200)..GO..NO..........S.a.m.s.u.n.g. .S.S.D. .9.7.0. .E.V.O. .5.0.0.G.B...................\.,.@.r.d.=.X..........A...........................%8[..f[.....4..Gd-.;.A..MQ..L.S.4.6.6.N.X.0.K.B.6.3.3.9.7.F........BO
Boot0003* UEFI OS	HD(1,GPT,0e10cc54-d875-4bb8-a9d7-c22050863a50,0x1000,0x96000)/File(\EFI\BOOT\BOOTX64.EFI)..BO
Boot0004  USB HDD	BBS(HD,,0x0)/VenHw(5ce8128b-2cec-40f0-8372-80640e3dc858,0900)..GO..NO.........L.e.x.a.r. .U.S.B. .F.l.a.s.h. .D.r.i.v.e. .1.1.0.0...................\.,.@.r.d.=.X..........A.............................6..Gd-.;.A..MQ..L.A.A.S.K.W.P.A.F.S.2.Y.F.Z.5.Y.S........BO
Boot0005* UEFI: Lexar USB Flash Drive 1100	PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(2,0)/CDROM(1,0x3c6144,0x8000)..BO
Boot0006* UEFI: Lexar USB Flash Drive 1100, Partition 2	PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(2,0)/HD(2,MBR,0x0,0x3c6144,0x2000)..BO
and /etc/fstab:
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=2FBB-ED3B                            /boot/efi      vfat    defaults,noatime 0 2
/dev/mapper/luks-b4cb221a-cbf8-432c-80b8-22f9c1445172 /              ext4    defaults,noatime 0 1
and /boot/grub/grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod ext2
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root  ddcb11d9-34bb-4f1c-b3b1-63c3266be82e
else
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
fi
terminal_input console
terminal_output gfxterm
insmod ext2
else
fi
insmod gfxmenu
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-18.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b12.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b14.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b16.pf2
loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b18.pf2
insmod png
set theme=($root)/usr/share/grub/themes/manjaro/theme.txt
export theme
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=menu
  set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
  set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/01_menu_auto_hide ###
if [ "${boot_success}" = "1" -o "${boot_indeterminate}" = "1" ]; then
  set last_boot_ok=1
else
  set last_boot_ok=0
fi
# Reset boot_indeterminate after a successful boot
if [ "${boot_success}" = "1" ] ; then
  set boot_indeterminate=0
# Avoid boot_indeterminate causing the menu to be hidden more then once
elif [ "${boot_indeterminate}" = "1" ]; then
  set boot_indeterminate=2
fi
set boot_success=0
save_env boot_success boot_indeterminate
  if [ "${menu_show_once}" ]; then
    unset menu_show_once
    save_env menu_show_once
    set timeout=60
  elif [ "${menu_auto_hide}" -a "${last_boot_ok}" = "1" ]; then
    set orig_timeout_style=${timeout_style}
    set orig_timeout=${timeout}
    if [ "${fastboot}" = "1" ]; then
      # timeout_style=menu + timeout=0 avoids the countdown code keypress check
      set timeout=0
    else
      set timeout_style=hidden
      set timeout=1
    fi
  fi
fi
### END /etc/grub.d/01_menu_auto_hide ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-ddcb11d9-34bb-4f1c-b3b1-63c3266be82e' {
	savedefault
	load_video
	set gfxpayload=keep
	insmod gzio
	insmod ext2
	else
	fi
	linux	/boot/vmlinuz-4.19-x86_64 root=UUID=ddcb11d9-34bb-4f1c-b3b1-63c3266be82e rw  quiet cryptdevice=UUID=b4cb221a-cbf8-432c-80b8-22f9c1445172:luks-b4cb221a-cbf8-432c-80b8-22f9c1445172 root=/dev/mapper/luks-b4cb221a-cbf8-432c-80b8-22f9c1445172 resume=/dev/mapper/luks-b4cb221a-cbf8-432c-80b8-22f9c1445172
	initrd	/boot/amd-ucode.img /boot/initramfs-4.19-x86_64.img
submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-ddcb11d9-34bb-4f1c-b3b1-63c3266be82e' {
	menuentry 'Manjaro Linux (Kernel: 4.19.23-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.19.23-1-MANJARO x64-advanced-ddcb11d9-34bb-4f1c-b3b1-63c3266be82e' {
	savedefault
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod ext2
		else
		fi
	menuentry 'Manjaro Linux (Kernel: 4.19.23-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.19.23-1-MANJARO x64-fallback-ddcb11d9-34bb-4f1c-b3b1-63c3266be82e' {
		load_video
		set gfxpayload=keep
		insmod gzio
		insmod ext2
		else
		fi
		initrd	/boot/initramfs-4.19-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
    menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
        search --fs-uuid --no-floppy --set=root  ddcb11d9-34bb-4f1c-b3b1-63c3266be82e
        linux16 /boot/memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
modinfo dm-mod gives output, I didnt post it here since it seems it contains keys or signatures.
#8
Hmmm, seems like it should be working. Maybe some other eyes can find something I am missing. There was a kernel bug a long time ago that gave some problems with nvme drives but that seems like a long shot.
Did you use the uefi install from the live usb I hope and your bios is set to boot uefi etc…
#9
Yes, my Bios runs in UEFI only mode, not lagacy and the Installer from the usb stick showed “EFI and GPT” in the partition window.
#10
check mkinitcpio hooks and make sure encrypt is in hooks, and nvme is in modules?
cat /etc/mkinitcpio.conf | grep -E 'HOOKS=|MODULES' (those should be included in the uncommented line of each section)
if not, add them and sudo mkinitcpio -P
another thing, adding the following kernel parameter will prevent nvme from going into its lowest power state, possibly why its not seen?
nvme_core.default_ps_max_latency_us=5500
#11
HOOKS contains encrypt, however MODULES="" is empty.
#12
Did you try loading the module like in my previous post? I guess it needs loader early.
#13
Thanks for the help everyone, it seems something is wrong with the installer.
I just downloaded Manjaro Gnome 18.0.2 from the Archive under: https://osdn.net/projects/manjaro/storage/z_release_archive/ installed 18.0.2. successfully and upgraded with “pacman -Syyu” and am now on a working 18.0.3.
#14
Yes I did, didn’t work.
#15
Oh good, I was going to ask you to try that next. :grin:
#16
Is there any place I could report this so that at least in the next release the problem does not occur?
#17
There is Manjaro Gitlab which has an issue tracker But what are you going to report??? We have not tracked the issue to any one thing and have no evidence of what the problem was exactly.
Was it a bad iso download, probably and will probably happen again to someone but that is why we have the checksum.
I guess it could be bad from the start, is that what we have? If that were the case there should be many more reports of failures.
#18
I also have this same failure. I experienced it on 3 separate machines when trying to install Manjaro Gnome Edition 18.0.3. I am able to install using the 18.0.2 media without issue. I redownloaded the iso file 3 separate times and verified the checksum each time. I also burned the iso to 2 different USB sticks multiple times using several different tools, and the installed system failed to boot each time. I was using full disk encryption which Machine seems to have been doing as well. Maybe the limited reports are due to the low number of people installing Gnome 18.0.3 and using encryption simultaneously.
#19
I seem to have hit this issue trying to do a new install of XFCE Edition 18.0.3. I’m in the process of trying 18.0.2 and will report back what happens
Edit: This has resolved the issue
#20
I have done further testing and verified that this only happens on 18.0.3 with Full Disk Encryption. I was able to successfully install a working system without encryption using the same Gnome 18.0.3 media that had previously failed with encryption. I also verified that the issue does not seem to exist with the Gnome 18.0.4 Developer Preview installer when using encryption.
