This box pops up on startup. All I can do is click ok.
Configuration file “/var/lib/sddm/.config/sddm-greeterrc” not writable.
Please contact your system administrator.
Thanks. After I posted this I google it and found that answer:
https://unix.stackexchange.com/questions/555936/configuration-file-var-lib-sddm-config-sddm-greeterrc-not-writable-is-displa
sorry I should have done that first. Hopefully this will help others with the same problem.
Thanks
Dan
Done for you.
