I’m trying to install Visual Studio - Code on Manjaro using turorial in a web pake that second in search results of how to install vscode on manjaro
on Google ( I can’t put links. ). When time comes to execute makepkg -si
I get this error:
mad@MadLinux ~/Downloads/visual-studio-code-bin (git)-[master] % makepkg -si
==> ERROR: Cannot find the strip binary required for object file stripping.
And it returns 15
error code.
You mean the PKGBUILD of this one http://aur.archlinux.org/packages/visual-studio-code-bin
or what did you downloaded?
What happens if you run in terminal:
pamac build visual-studio-code-bin
or if you install it trough Pamac UI after you enabled AUR ?
I don’t use GUI, I use Linux consoles more often. I tried from another web page, as I said second in search results of how to install vscode on manjaro
on Google ( I can’t put links. ). I’m now trying pamac
, I hope it will work. Will report to you the results.
Do you have the base-devel group installed?
Already installed.
The open source build is in the community repo, no need for an AUR package:
pamac install code
or
sudo pacman -S code
Are you sure?
❯ pacman -F strip
core/binutils 2.35-2 (base-devel) [installed: 2.35.1-1]
usr/bin/strip
You’re missing the base-devel
group which is required for building AUR packages. See Arch User Repository - ArchWiki
pamac install code
installs the Code - OSS not Visual Studio Code.
This is because you are missing some common build packages.
Please run:
sudo pacman -Syu base-devel --needed
❯ pacman -Si code | grep Description
Description : The Open Source build of Visual Studio Code (vscode) editor
pamac install visual-studio-code-bin
worked! Thank guys!
