Error in Lutris when downloading Divinity Original Sin 2
  Kernel: 6.6.47-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=40809886-d17c-433b-876f-89a03d053b64 rw quiet splash apparmor=1
  Desktop: GNOME v: 46.4 tk: GTK v: 3.24.43 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.2 Distro: Manjaro base: Arch Linux
  Type: Desktop System: Gigabyte product: AB350-Gaming v: N/A
    serial: <superuser required>
  Mobo: Gigabyte model: AB350-Gaming-CF v: x.x serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: F21 date: 02/08/2018
  System RAM: total: 16 GiB available: 15.57 GiB used: 5.8 GiB (37.2%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD4-3000 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001129
    smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
    desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1625 min/max: 1550/3200 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1625 2: 1625 3: 1625
    4: 1625 5: 1625 6: 1625 7: 1625 8: 1625 9: 1625 10: 1625 11: 1625 12: 1625
    bogomips: 76672
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate irperf lahf_lm
    lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
    popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sha_ni skinit
    smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Micro-Star MSI
    driver: nvidia v: 550.107.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 08:00.0 chip-ID: 10de:1c02
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 3840x1215 s-dpi: 96 s-size: 1016x321mm (40.00x12.64")
    s-diag: 1066mm (41.95")
  Monitor-1: DVI-D-0 pos: primary,top-left res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  Monitor-2: HDMI-0 pos: bottom-r res: 1920x1080 hz: 75 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.107.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
    memory: 2.93 GiB
  API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1060 3GB driver: nvidia v: 550.107.02 device-ID: 10de:1c02
    surfaces: xcb,xlib
  Device-1: NVIDIA GP106 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 08:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte
    bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
  API: ALSA v: k6.6.47-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off with: 1: a2jmidid status: off 2: nsmd
    status: off tools: cadence,jack_control,jack_mixer,qjackctl
  Server-3: PipeWire v: 1.2.3 status: active with: 1: pipewire-media-session
    status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
  Server-4: PulseAudio v: 17.0 status: active with: pulseaudio-jack
    type: module tools: pacat,pactl,pavucontrol
    lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter
    driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 07:00.0 chip-ID: 14e4:43a0 class-ID: 0280
  IF: wlp7s0 state: down mac: <filter>
  Device-1: ASUSTek driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e class-ID: e001
    serial: <filter>
  Report: hciconfig ID: hci0 rfk-id: 1 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter>
  Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
    link-mode: peripheral accept
  Local Storage: total: 3.41 TiB used: 1.11 TiB (32.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EZAZ-00L9GB0
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A80
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500312CS
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CA12 scheme: MBR
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 870 EVO 1TB
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH30N rev: A201
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 211.43 GiB (92.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 40809886-d17c-433b-876f-89a03d053b64
    used: 80.3 MiB (26.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
    uuid: E832-7B45
  ID-3: /run/media/nicholas/fourth-disk raw-size: 931.51 GiB
    size: 915.82 GiB (98.31%) used: 745.83 GiB (81.4%) fs: ext4 dev: /dev/sdd
    maj-min: 8:48 label: fourth-disk uuid: 1be4d25b-4ff6-40b0-a5c7-dfe6cc409b83
  ID-4: /run/media/nicholas/second disk raw-size: 434.51 GiB
    size: 426.62 GiB (98.18%) used: 104.4 GiB (24.5%) fs: ext4 dev: /dev/sdc2
    maj-min: 8:34 label: second disk uuid: 1ec047b4-ec64-4d28-8893-f16ad7899256
  ID-5: /run/media/nicholas/third-disk raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 78.51 GiB (4.3%) fs: ext4 dev: /dev/sda
    maj-min: 8:0 label: third-disk uuid: 31f2d06a-293c-46c3-9216-27dc993cfb4e
  ID-1: /dev/sdc1 maj-min: 8:33 size: 31.25 GiB fs: swap label: N/A
    uuid: 14863704-322a-453c-b7a5-87bba34bb094
  Device-1: 1-1:2 info: ASUSTek type: bluetooth driver: btusb interfaces: 2
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
    chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Device-1: 3-3:2 info: Logitech G502 Proteus Spectrum Optical Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c332 class-ID: 0300 serial: <filter>
  Device-2: 3-4:3 info: Ducky One 3̠ type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1011 class-ID: 0300
    serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 40.6 C mobo: 29.0 C
  Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-3: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.27
  Processes: 370 Power: uptime: 13h 25m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.22 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: 2554 pm: pacman pkgs: 2540 libs: 626 tools: gnome-software,pamac
    pm: flatpak pkgs: 5 pm: snap pkgs: 9 Compilers: clang: 18.1.8 gcc: 14.2.1
    Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.36
I have tried downloading and installing Divinity Original Sin 2 through Lutris twice and have received the same error partway through the download process.
1 parameters needed for signal error; 0 given
  File "/usr/lib/python3.12/site-packages/lutris/exception_backstops.py", line 108, in error_wrapper
    return handler(*args, **kwargs)
  File "/usr/lib/python3.12/site-packages/lutris/gui/widgets/download_collection_progress_box.py", line 161, in _progress
    self.emit("error")
TypeError: 1 parameters needed for signal error; 0 given
Any insight would be helpfu, thank you.
These both come the regular lutris repo package.
Unless you used something else?
Have you made any changes with python? sudo pip .. or similar?
Just throwing some things out there.
Might as well make sure you are up to date (and not in a partial-upgrade state);
sudo pacman-mirrors -f && sudo pacman -Syu
I haven’t messed with anything. Just did a refresh like you suggested and there was nothing to update.
Managed to install the game after downloading the files manually from GOG. No idea how to fix the error, though!
