Error in keyring - Jonas Strassel signature
FYI
I also had this problem but with another name.
I am on Manjaro Sway v1.7 (x86 NOT Arm).
sudo pamac update         ✔
Preparing...
Refreshing manjaro-sway.db...
Error: manjaro-sway.db: manjaro-sway: key "Jonas Strassel <info@jonas-strassel.de>" is disabled
invalid or corrupted database (PGP signature)
Failed to synchronize databases
I enabled info@jonas-strassel.de, refreshed mirrors and then ran the update again.
   ~  sudo pamac update         ✔
Preparing...
Warning: lib32-mesa: local (22.0.0-1) is newer than multilib (21.3.8-2)
Resolving dependencies...
Checking inter-conflicts...
To upgrade (2):
  firefox          100.0-0.1   (99.0.1-1)    extra  84.8 MB
  manjaro-keyring  20220504-2  (20220503-1)  core   112.4 kB
Total download size: 84.9 MB
Total installed size: 1.0 MB
Apply transaction ? [y/N] y
Download of manjaro-keyring (20220504-2) started
Download of manjaro-keyring (20220504-2) finished
Checking keyring...        [1/1]
Checking integrity...        [1/1]
Loading package files...        [1/1]
Checking file conflicts...        [1/1]
Checking available disc space...        [1/1]
Upgrading manjaro-keyring (20220503-1 -> 20220504-2)...                                                           [1/1]
==> Appending keys from manjaro.gpg...
==> Disabling revoked keys in keyring...
  -> Disabled 1 keys.
==> Updating trust database...
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:  27  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  27  signed:  96  trust: 0-, 0q, 0n, 27m, 0f, 0u
gpg: depth: 2  valid:  89  signed:  33  trust: 89-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2022-05-06
Download of firefox (100.0-0.1) started
Download of firefox (100.0-0.1) finished
Upgrading firefox (99.0.1-1 -> 100.0-0.1)...        [1/1]
Arming ConditionNeedsUpdate...        [1/3]
Updating icon theme caches...        [2/3]
Updating the desktop file MIME type cache...        [3/3]
So it worked and I got Firefox 100 as a bonus ???
I ran the update again and the key has disabled itself.
    ~  sudo pamac update         ✔  34s 
[sudo] password for shamfer:
Preparing...
Nothing to do.
Everything seems to work fine, but I am left feeling confused.
Understand… I guess one maintainer has disabled the key, but did not re-sign the packages, which were signed with this key, with a new key. Therefore you get this error. Hopefully they solve it soon.
@philm not sure if this is helpful, but Jonas’ key has been re-added to “trusted” in manjaro-keyring-20220504-1, but not removed from “revoked”.
This is now “mended”.
