Cannot open chatty on the pinephone
I am unable to open chatty, when I click on the app there’s the animation before opening but then nothing happens, I try through the terminal and got this result:
[manjaro@manjaro ~]$ chatty
Failed to register: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Interfaccia «org.gtk.Actions» inesistente sull'oggetto nel percorso /sm/puri/Chatty
if someone knows how to help, thanks in advance.
I am running phosh stable, with stock firmware version 002
Try a daily build as we always update chatty as we go. beta15 it should work just fine. Also check what happens if you change your locales to English on your current install.
I am on beta 16 now, I was on a daily build and it it worked fine, then came bakc to beta 16 and had this problem, chatty works soon after a reboot, and when I receive a message I can open it clicking in the notification. I will go back to daily build.
Yes, I am on daily build now, and chatty works greatly! Things are getting so amazing and so fast on development!
