Hello guys!
Today I was updating my OS and during this I had to restart the computer (it just hung for more than 7 minutes). After that I see this error…
I tried to boot via Timeshift, it did not help me (I tried to boot kernels through settings and Pamac), but I found that the system only has vmliniz-5.13, I tried to boot from it, but it did not help.
I have also tried booting with livecd and trying to solve it with manjaro-chroot, first with the -a flag, then with partition mounts(both btrfs):
sudo -i
mount /dev/sda2 /mnt
mount /dev/sda1 /mnt/boot/efi
and run with the command manjaro-chroot /mnt /bin/bash, but this gave an error chroot failed to run command ‘/bin/bash’
I have scoured the internet, but have not found an answer. Please help me
you cannot use manjaro chroot on btrfs… you need to use ‘normal’ chroot… when youre chrooted, try running this command first: sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
Thanks for the quick reply!
I tried to do as you said and also did cp /etc/resolv.conf /mnt/etc, because guide said that this is necessary for the Internet to be available in the chroot. I tried chroot /mnt but it gave me an error chroot: failed to run command ‘/bin/bash’: Input/output error . I tried mount --bind proc /mnt/proc and then chroot /mnt/ but it gave the same error.
P.S. Also tried to wrap chroot in strace, but gave this error bash: strace: command not found...
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 71M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 583.3M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.8G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 743.3M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 1.8T 0 disk
├─sda1 8:1 0 300M 0 part
└─sda2 8:2 0 1.8T 0 part /mnt/home
/mnt
sdb 8:16 1 7.5G 0 disk /run/miso/bootmnt
├─sdb1 8:17 1 3.2G 0 part
└─sdb2 8:18 1 4M 0 part
sudo smartctl -a /dev/sda:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.13.19-2-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Toshiba P300
Device Model: TOSHIBA HDWD120
Serial Number: 998N153CS
LU WWN Device Id: 5 000039 fdbc91bcb
Firmware Version: MX4OACF0
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Apr 17 06:18:52 2022 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (14726) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 246) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 140 140 054 Pre-fail Offline - 67
3 Spin_Up_Time 0x0007 153 153 024 Pre-fail Always - 257 (Average 239)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 1112
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 124 124 020 Pre-fail Offline - 33
9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 5572
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1009
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1112
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 1112
194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 35 (Min/Max 19/59)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 5351 -
# 2 Short offline Completed without error 00% 5117 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
When i try to sudo umount /mnt it throws an error umount: /mnt: target is busy.
But i decided to run the last command without remounting /mnt and here is the result:
ID 258 gen 339572 top level 5 path @home
ID 259 gen 339539 top level 5 path @cache
ID 260 gen 339571 top level 5 path @log
ID 847 gen 339309 top level 5 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@
ID 1636 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/0d53d76ecbdb77c05423d5af9654563c0b2e7d34b1253f70c8ed3e5fcd6ed828
ID 1642 gen 207813 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9802d176ce614e2fc72505f6c7866b0976bdfb93dcca6c4c2faff4ce9bdfed4f
ID 1647 gen 207835 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b780690e659b1b6b357f23ce22eff001c34a405d59b059c81bddc34bc379c507
ID 1653 gen 207838 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6b77cc15de2bfa33d1c17e6405de44ade7efcadc50eb9036422e7dd55647f449
ID 1654 gen 207839 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9a5fb243aec74edb7cb503ac435b5733d91a44aec331ff465c0c0cfb33c1e6ee-init
ID 1655 gen 207843 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9a5fb243aec74edb7cb503ac435b5733d91a44aec331ff465c0c0cfb33c1e6ee
ID 1670 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/4b29bdbaa41606f2a92f9d14106ce240d48d3ee296f790cdefd3c93a0a3ebc89
ID 1672 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/4ce055ccde4cb1ac771b193752e5d595cccf9c3e51110408fc8e4a273626d0de
ID 1673 gen 216576 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a2657686c721aecbf9ea57c16942c515a21828b53e1e04a25f8ab098151f22b0
ID 1674 gen 216577 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/c07c90f4b045a501368098a674f39a90b57ef426e93a5ecbc6d891f979ad48d6
ID 1675 gen 216579 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/5b45c762855cebbb4aadf69430c68cce7ab578753578b2e3255af4ba69a30597
ID 1676 gen 216581 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/21858ba738e9e4f3cfff6879aa4836b68ad8605faf7ad15fb3f55970e674a9e2
ID 1677 gen 216733 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/fe3f25de0edfed2a5bb661b874d73a19af2723903556a1ee244683d5d117a7a7
ID 1678 gen 216584 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/90c8392d4edff97bad7cfa911f8867b27d621ad225275d30be47114bd38222bb
ID 1679 gen 216585 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/3320263850af8659e738f02045bf02f00bd6cfa196f0f8c23da5955d229cbe3a
ID 1680 gen 216586 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/d0ca6fb5d1033ad9e6fc990bd357e9a1fe4346f703d49b85e068dc2b0cd7830d
ID 1681 gen 216589 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/57a60fc67f2c98469c7889d4474af84baf296325abedfe60845c9b963c5c8961
ID 1682 gen 216590 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/22106cfc9be0bc70e16fb258aa2026e925bbfdfb357a74b7260f387eeea27676
ID 1683 gen 216591 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/0d5333930eacc1f67c4b9394f4e4ae059a875e5f784dfababeac687d07386972
ID 1684 gen 216731 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/f3082114864d7f8282411367227e0633b1c742ee4f0f18872437277128261b82
ID 1685 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/5cbf9ac6f90175fd16b07d6c576a0ba46da523d0e1524c3a2332151368279d12
ID 1688 gen 216705 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/4a9d0f5f4240fd0a2176f563c4bf9a6859060d6fc9606fe322b0872be7b96d30
ID 1689 gen 216598 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/478cf366be7e7c6f989069f9f511415f392f01c75ea7fd28b536755c63c22d88-init
ID 1690 gen 216599 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/478cf366be7e7c6f989069f9f511415f392f01c75ea7fd28b536755c63c22d88
ID 1691 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/405ae6a2b3444cc3584276df546d5212d147deef084e25e2c27a43fe6b1ec0c0
ID 1692 gen 216601 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/368e053984332638693f33cd79824d4e4f50b627df2c1e6daaccfbc18fbac539
ID 1693 gen 216602 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/98cbe3f3d99af8d6bf617b65eae190bf1b9ed0c5b1d1fa818643da76c0cc0a3b
ID 1694 gen 216605 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/c157ba3714c8f4265f225efaab6f97ff49b24bc69a84480946b706c70a0d56a3
ID 1697 gen 216610 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/62831fd8c692a43ab52c2dbae3c19472d0a62db0c75fd942daeb14328aa0ca3c
ID 1702 gen 216615 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/0e2b13786766ce26e2dd24cb41f9b291bed00a1021cf73df0e0e3f7e5caf9321
ID 1705 gen 216618 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/28a53e21798999153864ad51e1e83524b3ba2463c5817d898f7a4edbb9e4d364
ID 1707 gen 216739 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/94dd0606c7fd56a299f2ecf2d95512bf3cedd6e1dca4567da5c564d4f9f37920
ID 1711 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9a72f17dafcecbf440560627d92ff540ef5c94534c70d6668fdc769935d859aa
ID 1712 gen 216629 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/64855a5d64c566493ddd66249ecc51f150d5c97d965052aaffe3caa969da65bb
ID 1713 gen 216630 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/651d04a16ef18d9d98025d5f091cdfff4cd4f91be409abe68f6039990da1c266
ID 1714 gen 216631 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/296ca0cccac3e652a3f621519aac925916ccf5d14bad791266749eb723aaee36
ID 1715 gen 216634 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/7c5348bb209696cab406f69801a8d020a3093bc060363a5f5469d8812828ae1f
ID 1718 gen 216636 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/8b5bc37d3952004e0aad7fe3040efff3d9c4e8e8f210097e831da30efbca947d
ID 1720 gen 216640 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/eaa5c77bf0ad7d37876fbf1167319c9acbe553b62c345e753bdbb4711212d577
ID 1723 gen 216643 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/2de90a154721f486cfe92e76cfdaad7a492858e813469a3dbfbe015dc59fe991
ID 1726 gen 216646 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a18dd1ed53cba90b5b1f19578c481dc389a73a41cfdfbe4d0fef5a94c6983f12
ID 1729 gen 216651 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9c95b68b956b9ab5be1c11c77b684c53cba3773966782091bebd2fba094ec7d6
ID 1734 gen 216734 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/7ce8d11c6de57d58ccf1f6d431716cd1a83457caaf1c73f54e92fe37c429110a
ID 1738 gen 216656 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a7756761d72d5601b4c9e2952db16da900d035c191e3c5d85ef9f2a9e5c1d4fe-init
ID 1739 gen 216657 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a7756761d72d5601b4c9e2952db16da900d035c191e3c5d85ef9f2a9e5c1d4fe
ID 1740 gen 216666 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/893640b4024d6d834b522f965accb85aa0a007533a2c1c89ce6d919970c1f333-init
ID 1741 gen 216668 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/893640b4024d6d834b522f965accb85aa0a007533a2c1c89ce6d919970c1f333
ID 1744 gen 216721 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/22d25cf26a7e9eafc3a7db573cb05c02f9cf2e7dbc0c1df5d106bac2b9778ad6
ID 1748 gen 216737 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/d7a4a3f3997bf97128583eccac033914171ad831d2e51ab6910fc99b641ad794
ID 1758 gen 216732 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6e6291b56fef138b96dd6f442ec8ade5e62937573cea957164d44d97253a3dfa-init
ID 1759 gen 216742 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6e6291b56fef138b96dd6f442ec8ade5e62937573cea957164d44d97253a3dfa
ID 1760 gen 216735 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/e17b0f14288f0f1d353655d12443957b6bc89ee856562b2f51836afed131c562-init
ID 1761 gen 216736 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/101f2944fca614ab8aa70ec656a758f4d5187e5fcaabc14b0e8acee76a1a2aa9-init
ID 1762 gen 216741 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/e17b0f14288f0f1d353655d12443957b6bc89ee856562b2f51836afed131c562
ID 1763 gen 216755 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/101f2944fca614ab8aa70ec656a758f4d5187e5fcaabc14b0e8acee76a1a2aa9
ID 1764 gen 216738 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/df137ce2b756c27b2c25710dee5a54ff80dc636ba0244528d5cb34b32b21706b-init
ID 1765 gen 216746 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/df137ce2b756c27b2c25710dee5a54ff80dc636ba0244528d5cb34b32b21706b
ID 1766 gen 216740 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/486a614052c50f52be9cf873cdc0b7762ba24d1b9d8915d91fefa7077e3297c6-init
ID 1767 gen 216749 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/486a614052c50f52be9cf873cdc0b7762ba24d1b9d8915d91fefa7077e3297c6
ID 1883 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/ec57048d9b453cc114e844798feb6056e20545371e5b9072f54ab9377963ded6
ID 1884 gen 242144 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/c25c4ef1adab5ce22802ef9b931d45dd6ca334b98fbb557aa6bddc798b464d2b
ID 1885 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9546633369bb29901f6e8d535cf2e5e388cca16deb9d95e965474f7bf4461130
ID 1886 gen 242146 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/67d331fb79576d1bf846bf88a6c726194594ec69f491890ab9207a9c0d08954a
ID 1887 gen 242148 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/43d4e7cfced7acddb28d8f689fc55a3fa4291bc0b82077d6f1f10e01ba34ddc4
ID 1888 gen 242155 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/c02bb5d2bb85d59b7b003105ec3ed968b8a990aab1a1aaf526e9c05bafed7a3c
ID 1889 gen 242156 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/dc2ae910b85e400e75cf4cc9607ad31663b6202a70f4c2dd8f92e529d537c6c9
ID 1890 gen 244114 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9f893a470b770d0e5647077dbb57ca2222a88e8d12966a1c04eaf035f36565cb
ID 1902 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/cc95ba90751ed9f0c99a25c815d92482c6af0acbc0b5876c9fdc54ddf11ab8e2
ID 1903 gen 243910 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/d1821fd0b6b428c158afcc34076abd05227d9a1fb23ced36703dc91a899c88e5
ID 1904 gen 243911 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/2a6564d690fe38927c8d5c0502588b00ce15c58d22cbdc30a7a59b71be777824
ID 1905 gen 244059 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/db8d659e03f276001e8715689693df18493ff891d4650b7bf511038816d83399
ID 1906 gen 243954 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/3628b0fd8c8ea10331acf3cf006bbed05be1fc55c28a4a412cb3a56e98c9d8e5
ID 1907 gen 243955 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/564e623fc5c99b2473415a36b9465969419d716031e933b28dcda4ae6a7771f2
ID 1908 gen 243956 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/30a9e8dc7a304aef68bc365d77b8ad72a7df8aaf34c20cdc73da61bc5a96830a
ID 1909 gen 243957 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/d73ef7c637059cbfd193dbacb0b52a50684d313cfb3968a9a2f4f669b21f95ac
ID 1910 gen 243958 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a388b7067494e273cd08dc66aa8e786d1ef0a1745579cfcc0eaeca9ce576c2fb
ID 1911 gen 243993 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/15c74a1c769a4a03d74336f67d63a57b8039e2963e2e0fbdf737819546e66797
ID 1912 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/0a9ef5ff24a99e71cf796495d57edc600d51f0f3d424df42694c53f3b849a11d
ID 1913 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/dd75c4febe502b77df3c01b23c60b55ae5f7250d772866b0b4187c276ed3e076
ID 1914 gen 243999 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/e0e59847e123c4b878e6603088fe618c22f61cec9f2d612b76d4162fc5d2da9b
ID 1917 gen 244666 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/52863e30446817892ddd3b00b6c60af05568294422e4df3bffd95cba646e5654
ID 1918 gen 244063 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/f8a037406ecb3f66d5684a47d97ce9b0a1c573e559c264aea8788b57f969f6d4
ID 1919 gen 244064 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/828b1a7af203e1b745858377230f7a5952fa4a4c497c7b51f5c7b98f522598e2
ID 1920 gen 244065 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/510d78bf8a9e00db557864429123b47f7056088fc2fa680c49c5bd8ef98784e8
ID 1921 gen 244066 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a35a61e352a8272000386da6dc89a72fd464fb7a2231c788282e0f4ab1f2a0b7
ID 1922 gen 244070 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/66d0188d12219dba073bf2345dc7b0004d9c9be98bf263e1f08da8c70aa03f2c
ID 1923 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/aea0f139a88b8e6645410438ea217b785a1e5495bd7501828af1bf37355fae48
ID 1925 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b042bf6c41bc76afdc176a916b40c60a1c64683bb11f4459aa92ae3cd8637904
ID 1926 gen 244103 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/4998ece71e18e44136be2c9171a227e2ffbe70b54ab3818ab38be0491c11069b
ID 1933 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/51fe4affdf3ef2ca86685f544e7a2faef5dbc919fd7b874b01b43071597811b2
ID 1934 gen 244141 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/38ee9131b8b1e9a347c5f6eb4568940d9ab517c373623ab756dca6d7f6eb1417
ID 1935 gen 244142 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/5e6feb55721af8b7df0b2e54cd44932fc0d1a8d05821a2cf5edfe563eecee00a
ID 1936 gen 244143 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a597d0d9bbbb1ec13158fb14b551894c7521e108f789ac0835897f204847b1c5
ID 1937 gen 244144 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/270895d6b368f3439bdf7cc78825dab5731c6ba00f9f7afff36b6b86c13e40ec
ID 1938 gen 244145 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/1b35818cd94fcbc4b645d7203c852d2280d194cb6879b8b4ab23d0b6a6fd0741
ID 1939 gen 244146 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/545214c56a205f8d21a304062eb0b3c19b4387591dcec4749eaf28e365f1b927
ID 1940 gen 244154 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/641c5bb886705ccee345fd1dcf471827aaac804f2b0f876e1f38b9adb02ca605
ID 1941 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/836bae414dff792ea83cafb85881a14e6432155201bbc3bdf4008202258aec94
ID 1942 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/746ef7e2cb7a34e7a071bfb63bd3276c150f6b973493c7e6c27149494fe13e1c
ID 1943 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/1517b9bb24c020852022e95b3cad9dd772da52cfb2de4e8cf9bcbfc778c2e865
ID 1944 gen 244161 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/30c018645bb47a93cf4c7268737f54ee6c25d3c0b109273118852a71afafa094
ID 1945 gen 244176 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/76adf71caa616011a83e37fc70853c3d08c6ec85a67657dbd4e67031d97c68b2
ID 1946 gen 244162 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/e0dcfaa3fc7e7447961fb1346dadad2519196d115121382f8a171b2a854bb2bc
ID 1947 gen 244164 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/d19703e9262a17284973286e67eaf1e63cc77caf995ad0b8031de8132c6bf912
ID 1948 gen 244181 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/463a91528cc94feaf78b079c251e744df3aa797f5a580acea8f51e683b463f96
ID 1949 gen 244165 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6fa5af46e7945d23be1d441791f3e46fe1e230a69928204f23fc224e5c74bbe1
ID 1950 gen 244166 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/25793b25d7922ddde962ace8324ce53a12f12bf44166738edfb00fdb53e27ca7
ID 1951 gen 244172 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/c3cb780a007489522a18fcc957a816a272310c132b93bd25b844e35665066b93
ID 1952 gen 244168 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/5dbe45da832976b8fe1e36b184dc7e989a2ba5c9038bd3752f1764890ad55563
ID 1953 gen 244169 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/526499e6d641ee28b8804bd05a5413b3985a5704d5d69f6934fe50268df1401d
ID 1954 gen 244170 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6ffa42f45750ab08c7b21ced2c5a6602f00cd5de6d29b0f0eb06553a6c726a4c
ID 1955 gen 244171 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/38f2349901cc0d982eca4d835807fb59573170414bbe8285c799aa97e80c458e
ID 1956 gen 244173 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b76aac33464eae1b2f32b09bf39a7c42b75c29c5930da9d82707de4932dda7ad
ID 1957 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6d009295911c80ed6932af94f7de367bf7a4c239b9b74992409ad52b883373a9
ID 1958 gen 244175 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/421dde6787d0e245cadad35fc274d731668a040a7942422adfbe39818c70fe75
ID 1959 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/bff0a90239a87134a61862f35a1058b187e54ae1e9d9a56c81827ee75c77ce49
ID 1960 gen 244672 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/3d7d2b1cea05bf82a73f715ff4ad530b686a828abd01a15816a43b0dc54e2501
ID 1961 gen 244180 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/7e68d3bbc729af574c3b9d89ac8fea0df1576c413196e5752a9b1fedab72e593
ID 1962 gen 246871 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6f239c34ec25ca7830ee5e138ec9ef8a1115fdfa604b088a13ffb9d042912ec6
ID 1963 gen 244184 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/f6cc260bfdf94d43f64868310a110240f1cc5923df670e21b07b565c1f37e518-init
ID 1965 gen 244186 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b83ab802aec57e107e3f2f34527744ef40b69c32b5bef4339fb2352937086ddf-init
ID 1966 gen 244187 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/f6cc260bfdf94d43f64868310a110240f1cc5923df670e21b07b565c1f37e518
ID 1968 gen 244187 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b83ab802aec57e107e3f2f34527744ef40b69c32b5bef4339fb2352937086ddf
ID 1977 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/1b070dfb3d64a36015c4747a3230b4c093a496d8d0a57d230bd1c810953a6eb6
ID 1978 gen 246886 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/65e1e9646cd5bd01a490dd49c14b723c75f5c972ac385c757ed10e7ace60d821
ID 1979 gen 246887 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/7e8c8259eee92d71f5b01647626b7e3bdbe5e2bd66a63c2e463f12ab794512b3
ID 1980 gen 246890 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/ed77ef8bd6471040afbbe70e1546b9c322b67de90801e3fab8cc10e8dc9a8f01
ID 1981 gen 250550 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/2ffd06f7e9aa8a35cba7f83d42abb3e06fd7fbdf1f5306727beac4d92038bbba
ID 1982 gen 246982 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/bde17d567c258812d4f364d5cb839eb87ceece71f234c57d026e18703a71fc99
ID 1983 gen 247138 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/0da7ecc527acefc83866dee9a13c0c5d1caa762d80bc7ace41affe501a6d628a
ID 1992 gen 250944 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/508790d44c125f4141479bc88fa946cac97c15e88e25ec18bf04ab7e03d0f479
ID 1999 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b3c8ae9d8d24a7f768f375803a88d1663456ba4d4c9cb529173155cc4f71ddc6
ID 2000 gen 251292 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/d187d485b79721010902ce0ffae9da1eda4e19b0c767f94495b0f2cc60d127ee
ID 2001 gen 251293 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/eef23da2d519c0b28ad0f607799118dc9ef260b2512bd8a66f4b78f3840a01f6
ID 2002 gen 251296 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/015f12ba75125383e28e434ad38f4092e9558c99ddb07b1220618b99862126ac
ID 2003 gen 252822 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/64d45c6a16707203e22ab63ebee191b66b59761bedbb8f3a98175ab44936444c
ID 2004 gen 251298 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9b0e79c8ab06d59fba623feb517bfe47d5d2bb25286604d5bf3c197169cafa60
ID 2005 gen 251299 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/1d1c97c24bffec31081f9d60d9e3391457316c679db37048d9b5357301d7c285
ID 2006 gen 251300 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/7b77e46a7a00129a26798905b83fa8107898d3364129cffd7f1262460720d4f8
ID 2007 gen 251301 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b0dafcc9fdfa3ee8108fe3a63f62e3a4fb410684cccabe4237fb2228317a748b
ID 2008 gen 251302 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/98801884c5a908a8db47a6eb5261ced3cbc228c24ee108387597652e80b53685
ID 2009 gen 251303 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/90226b66cfd4f14880d10fc55bb8b6c4f9c15858c3cede75af8bbec82107aaa2
ID 2010 gen 251304 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/ee2e9a705baf8e1ef3bc13b723a5181fb312c0194821062ae7df7afd8b216c35
ID 2011 gen 251305 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b5a577cb89b34554c164d2b0d8ef0bdfb045566d67aa909e5d11b9434134cf70
ID 2012 gen 268231 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/13fb33a63124e78cee75d74731b5b0b8ed992a2f6bac2f139227263e8c6d0e63
ID 2033 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/3d1ac7787db3c07a7402725a1df1a7bf6401ab5c6569fb4a0f8df3ab24732395
ID 2034 gen 253956 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/04b8290973b004c71153ced88a648f10866975a8f9834a6a99ff5769e410c507
ID 2035 gen 253957 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/33e6df5ef2eeb3f9e46a96442f2331f13c0eae67a901d647454ee2c0b8bfeef8
ID 2036 gen 253958 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/728b334b13839da02f8536e8d8bdad93f7a77758aa6fedf98563f2fd07cd8b88
ID 2037 gen 253961 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/7257a5f593661bf8f80ce0ebd5bf6593d44136a36f1dcb1712733d31d3da81c4
ID 2038 gen 253960 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/851aa28935daaf878aad0d49631e38d70fcf8bd7ff76563748962b98ce4cab97
ID 2039 gen 253961 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/c86f90a5a34e93ac6dc9b5a9123edc2b12ca4d2561384978e92d67eb9df3e8fb
ID 2040 gen 254212 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/8146fcd52322e8b426d10a89957f4c484de02370f9db4c7b807f4bc62dca45c7
ID 2041 gen 254212 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/1d8626c5aee82d37dff5086264664b2cd501295ce3c889a249c7e32d85007449
ID 2042 gen 254210 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/87614225bc37d3bd5d0613e6316421bf32a208e9de76a33d711b2cd057426cff
ID 2044 gen 253978 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/dc2c918ded915d6937bf3a56a20cd58a6738a7cd04535dc974caf25414a573f8
ID 2045 gen 254212 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/e8b1e8b33a05607aecde3b560cfcd3a3906852d0c074acd202dc5b788096c3fe
ID 2046 gen 254212 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/4b192903abd620d0957113af18ece3f0755b2bf4de368ede140089b896e6ccec
ID 2048 gen 254212 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/0e0727ea7641b47efda03eff526685c8ae96614270785bfe2776f98e4a9b53a6
ID 2049 gen 253989 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9909650d6629644b41d4590e1cea0c3d2c5cc798d16f9c7a88c62565e45c978c
ID 2050 gen 253990 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/335f1527cf26e653ddcaca5ad08d878e0d19ddaff95865c177759af59ed6d48d
ID 2051 gen 254212 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/5c946702522e7f09ebf56f4d5c13537b5c6348a3ecc5744c8a3589f42f33a8b1
ID 2052 gen 286445 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/aff39ff0b72cc39becf5bf1bc1d31062574b5e8f8df9c67c3827640b91021264
ID 2053 gen 253993 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/fd90d9d7c44c0b8ea1d441dccd8b5382f02e04249e82bdfa58be021a48a73e0c-init
ID 2054 gen 253994 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/fd90d9d7c44c0b8ea1d441dccd8b5382f02e04249e82bdfa58be021a48a73e0c
ID 2055 gen 253998 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/0077672080c9352dbd1b0dbdc3f58b83c7305cdd6537f538cbd98b3d7ae2fd1f-init
ID 2056 gen 253999 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/0077672080c9352dbd1b0dbdc3f58b83c7305cdd6537f538cbd98b3d7ae2fd1f
ID 2057 gen 254024 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b4ff14eebedfa9c7a1c65665e184c8a81b8e9fc96d09637ed6830514d631872d-init
ID 2058 gen 254025 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/b4ff14eebedfa9c7a1c65665e184c8a81b8e9fc96d09637ed6830514d631872d
ID 2067 gen 254186 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/220e3cd90b9595d318d194a920877be46afc58b72e3483d74a6025bb2beb7ee4-init
ID 2068 gen 254212 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/220e3cd90b9595d318d194a920877be46afc58b72e3483d74a6025bb2beb7ee4
ID 2069 gen 254228 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a9cf3717b60ea590392ec37bb89e73b476154ae7335129d2ca22f604a261a3c7-init
ID 2070 gen 254229 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/a9cf3717b60ea590392ec37bb89e73b476154ae7335129d2ca22f604a261a3c7
ID 2071 gen 254231 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/e2e5776c0a44dcebdfa733e39207b25b92040bae5bff051f9938e81c3981ab0d-init
ID 2072 gen 254434 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/e2e5776c0a44dcebdfa733e39207b25b92040bae5bff051f9938e81c3981ab0d
ID 2073 gen 338972 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/5f479351a2bae6d8439fbd620382d640bdc3efeb35950ad4af13214d2c0470e9
ID 2077 gen 254631 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/9fd746f31c29755957a5b4c85524338221973c1f7c181f3a6207ebbde351e75a
ID 2080 gen 254631 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/138b75e4e81b8352fbe806540bf45a5b29f27f6230da3c65b432dd3a3ca23ad9
ID 2088 gen 254814 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/c343daa3dd01cab19861caa4c69aceb0776f0da49ac530ec1d04d6b469742a89-init
ID 2089 gen 254815 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/c343daa3dd01cab19861caa4c69aceb0776f0da49ac530ec1d04d6b469742a89
ID 2090 gen 254817 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6133755b09748a8ec7e37ec8ea2cf1c93d475199643391cfdb564bc1fa505e52-init
ID 2091 gen 254820 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/6133755b09748a8ec7e37ec8ea2cf1c93d475199643391cfdb564bc1fa505e52
ID 2092 gen 254822 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/715b5eb8d770888e755f7e37a1e8770ee111fc744213d411a9f47674346e0c61-init
ID 2093 gen 254954 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/715b5eb8d770888e755f7e37a1e8770ee111fc744213d411a9f47674346e0c61
ID 2104 gen 267173 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/d3e96252c7f6283edabaf3926df2f124d52bb11d010daa624626184a734da782-init
ID 2105 gen 268416 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/d3e96252c7f6283edabaf3926df2f124d52bb11d010daa624626184a734da782
ID 2107 gen 267868 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/2f81c48fa5a4cf0f55da4446e39a54cde212e7345504b98d769985416d320b57-init
ID 2108 gen 267870 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/2f81c48fa5a4cf0f55da4446e39a54cde212e7345504b98d769985416d320b57
ID 2114 gen 268232 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/98c4e2de3391598fbe8cdc226b95ef184af0d191e65f82d4445320333f22a757-init
ID 2115 gen 268409 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/98c4e2de3391598fbe8cdc226b95ef184af0d191e65f82d4445320333f22a757
ID 2222 gen 286446 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/2f696ecfe55448521387bd8db382756b0e19700f4003bf1fbddc55f1cb0d07b1-init
ID 2223 gen 286538 top level 847 path timeshift-btrfs/snapshots/2022-04-16_18-31-29/@/var/lib/docker/btrfs/subvolumes/2f696ecfe55448521387bd8db382756b0e19700f4003bf1fbddc55f1cb0d07b1
ID 2565 gen 339571 top level 5 path timeshift-btrfs/snapshots/2022-04-16_14-39-21/@
ID 2566 gen 339043 top level 5 path timeshift-btrfs/snapshots/2022-04-16_16-00-27/@
ID 2567 gen 339169 top level 5 path timeshift-btrfs/snapshots/2022-04-16_16-53-48/@
ID 2568 gen 339310 top level 5 path timeshift-btrfs/snapshots/2022-04-16_17-35-37/@
ID 2569 gen 339332 top level 5 path timeshift-btrfs/snapshots/2022-04-16_18-44-53/@
ID 2570 gen 339361 top level 5 path timeshift-btrfs/snapshots/2022-04-16_18-40-12/@
ID 2572 gen 339518 top level 5 path timeshift-btrfs/snapshots/2022-04-17_00-18-02/@
ID 2573 gen 339540 top level 5 path timeshift-btrfs/snapshots/2022-04-16_19-01-33/@
ID 2574 gen 339386 top level 5 path timeshift-btrfs/snapshots/2022-04-16_19-11-30/@
ID 2575 gen 339399 top level 5 path timeshift-btrfs/snapshots/2022-04-16_19-17-15/@
ID 2576 gen 339520 top level 5 path timeshift-btrfs/snapshots/2022-04-17_00-12-47/@
ID 2577 gen 339579 top level 5 path @
ID 2578 gen 339544 top level 5 path timeshift-btrfs/snapshots/2022-04-17_00-30-43/@
I ran all these commands (and the last one I applied to all folders, there are 13 of them), tried to run sudo manjaro-chroot /mnt /bin/bash but again gave an error as in the message above. Here is the output of the command sudo btrfs filesystem df -h /mnt:
I decided to run manjaro-chroot -a, but again it didn’t work:
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> ERROR: No Linux partitions detected!
this command manjaro-chroot -a dont work on btrfs, as mentioned above…it looks like your filesystem is damaged … try using gnome disks app and select there repair filesystem
I have no errors on the disk, the command sudo btrfs filesystem df -h /mnt proved it.
After browsing through the folders with Dolphin, I found that there was a snapshot that was almost 30 gigabytes in size. Now I’m trying to remove it with sudo rm -rf @ (ran from its folder)
