Hi guys, i need your help. After disabling the Bluetooth headphones, my system stopped seeing the bluetooth adapter. I’m tried to solve this problem using existing topics, but it didn’t work!
That’s what I was doing
- installed a new version of kernel 6.5.13-1 → 6.6.3-1
- reset BIOS to default settings
- updated packages (bluez bluez-utils)
- checked rfkill, bluetooth is not lock
- loaded module to kernel manually. bluetooth.service was turned on, but it didn’t work in the UI
- also, there is no bluetooth reboot function in the bios
- did rollback with timeshift, is not worked
- output
systemctl status bluetooth
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
Dec 11 19:43:45 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 12 13:31:12 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 12 13:34:18 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 12 13:34:51 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 12 13:36:10 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 12 15:20:27 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 12 15:38:24 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 13 01:35:00 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 13 01:41:46 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Dec 13 01:42:29 chidaruma systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
- output
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
- output
journalctl -xe | grep -i bluetooth
is empty
- output ‘neofetch’
OS: Manjaro Linux x86_64
██████████████████ ████████ Host: MaiBook X series Standard
████████ ████████ Kernel: 6.6.3-1-MANJARO
████████ ████████ ████████ Uptime: 1 day, 20 hours, 15 mins
████████ ████████ ████████ Packages: 1355 (pacman)
████████ ████████ ████████ Shell: zsh 5.9
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: GNOME 45.2
████████ ████████ ████████ WM: Mutter
████████ ████████ ████████ WM Theme: Tokyonight-Dark-BL
████████ ████████ ████████ Theme: Tokyonight-Dark-BL [GTK2/3]
████████ ████████ ████████ Icons: Tokyonight-Dark [GTK2/3]
Terminal: tmux
CPU: AMD Ryzen 7 5800H with Radeon Graphics (16) @ 4.463GHz
GPU: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
GPU: NVIDIA GeForce RTX 3060 Mobile / Max-Q
Memory: 6354MiB / 15392MiB
- output
lsmod | grep blue
is empty
- output ’ lspci’
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GA106 High Definition Audio Controller (rev a1)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
03:00.0 Non-Volatile memory controller: Intel Corporation SSD 670p Series [Keystone Harbor] (rev 03)
04:00.0 Network controller: MEDIATEK Corp. MT7921K (RZ608) Wi-Fi 6E 80MHz
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev c5)
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
- output ’ lsusb ’
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 04f2:b711 Chicony Electronics Co., Ltd HD Webcam
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 0bda:0316 Realtek Semiconductor Corp. Card Reader
Bus 002 Device 003: ID 05e3:0620 Genesys Logic, Inc. GL3523 Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
