Here are more informations :
- inxi --admin --verbosity=7 --filter --width
Kernel 5.15.32-1-MANJARO
arch x86_64
bits 64
compiler gcc
v 11.2.0
parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=fr_FR keytable=fr
tz=Europe/Paris misobasedir=manjaro misolabel=MANJARO_GNOME_2126 quiet
systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Console N/A
wm gnome-shell
Distro Manjaro Linux
base Arch Linux
Type Desktop
System ASUS
product N/A
v N/A
serial N/A
Mobo ASUSTeK
model ROG STRIX B550-F GAMING
v Rev X.0x
serial <filter>
UEFI American Megatrends
v 2006
date 03/19/2021
Message No system battery data found. Is one present?
RAM
total 15.57 GiB
used 3.23 GiB (20.7%)
Array-1
capacity 128 GiB
slots 4
EC None
max-module-size 32 GiB
note est.
Device-1 DIMM_A1
type no module installed
Device-2 DIMM_A2
type DDR4
detail synchronous unbuffered (unregistered)
size 8 GiB
speed 3200 MT/s
volts
curr 1.2
min 1.2
max 1.2
width (bits)
data 64
total 64
manufacturer Corsair
part-no CMK16GX4M2B3200C16
serial N/A
Device-3 DIMM_B1
Device-4 DIMM_B2
type DDR4
size 8 GiB
speed 3200 MT/s
volts
curr 1.2
min 1.2
max 1.2
width (bits)
data 64
total 64
serial N/A
Info
model AMD Ryzen 5 5600X
socket AM4
bits 64
type MT MCP
arch Zen 3
gen 4
built 2021-22
process TSMC n7 (7nm)
family 0x19 (25)
model-id 0x21 (33)
stepping 2
microcode N/A
Topology
cpus 1x
cores 6
tpc 2
threads 12
smt enabled
cache
L1 384 KiB
desc d-6x32 KiB; i-6x32 KiB
L2 3 MiB
desc 6x512 KiB
L3 32 MiB
desc 1x32 MiB
Speed (MHz)
avg 2325
high 3700
min/max 2200/4650
boost enabled
base/boost 3700/4650
scaling
driver acpi-cpufreq
governor schedutil
volts 1.1 V
ext-clock 100 MHz
cores
1 3700
2 2200
3 2200
4 2200
5 2200
6 2200
7 2200
8 2200
9 2200
10 2200
11 2200
12 2200
bogomips 88826
Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
Vulnerabilities
Type itlb_multihit
status Not affected
Type l1tf
status Not affected
Type mds
status Not affected
Type meltdown
status Not affected
Type spec_store_bypass
mitigation Speculative Store Bypass disabled via prctl and seccomp
Type spectre_v1
mitigation usercopy/swapgs barriers and __user pointer sanitization
Type spectre_v2
mitigation Retpolines, IBPB: conditional, IBRS_FW, STIBP:
always-on, RSB filling
Type srbds
status Not affected
Type tsx_async_abort
status Not affected
Device-1 AMD Navi 23 [Radeon RX 6600/6600 XT/6600M]
vendor Sapphire
driver amdgpu
v kernel
arch RDNA 2
built 2020-22
pcie
gen 4
speed 16 GT/s
lanes 16
ports
active HDMI-A-1
empty DP-1,DP-2,DP-3
bus-ID 09:00.0
chip-ID 1002:73ff
class-ID 0300
Display
server X.org
v 1.21.1.3
with Xwayland
v 22.1.2
compositor gnome-shell
driver
gpu amdgpu
note X driver n/a
display-ID :0
Monitor-1 HDMI-A-1
model Philips 220BLP
serial <filter>
built 2012
res 1680x1050
dpi 90
gamma 1.2
size 474x296mm (18.66x11.65")
diag 559mm (22")
ratio 16:10
modes
max 1680x1050
min 720x400
Message GL data unavailable for root.
Device-1 AMD Navi 21/23 HDMI/DP Audio
driver snd_hda_intel
v kernel
pcie
gen 4
speed 16 GT/s
lanes 16
bus-ID 09:00.1
chip-ID 1002:ab28
class-ID 0403
Device-2 AMD Starship/Matisse HD Audio
vendor ASUSTeK
v kernel
pcie
gen 4
speed 16 GT/s
lanes 16
bus-ID 0b:00.4
chip-ID 1022:1487
class-ID 0403
Sound Server-1 ALSA
v k5.15.32-1-MANJARO
running yes
Sound Server-2 JACK
v 1.9.21
running no
Sound Server-3 PulseAudio
v 16.0
running yes
Sound Server-4 PipeWire
v 0.3.52
running yes
Device-1 Intel Ethernet I225-V
vendor ASUSTeK
driver igc
v kernel
pcie
gen 2
speed 5 GT/s
lanes 1
port N/A
bus-ID 06:00.0
chip-ID 8086:15f3
class-ID 0200
IF enp6s0
state up
speed 1000 Mbps
duplex full
mac <filter>
IP v4 <filter>
type dynamic noprefixroute
scope global
broadcast <filter>
IP v6 <filter>
type noprefixroute
scope link
WAN IP <filter>
Message No bluetooth data found.
Message No logical block device data found.
Message No RAID data found.
Local Storage
total 6.38 TiB
used 34.09 GiB (0.5%)
SMART Message Required tool smartctl not installed. Check --recommends
ID-1 /dev/nvme0n1
maj-min 259:0
vendor Crucial
model CT1000P2SSD8
size 931.51 GiB
block-size
physical 512 B
logical 512 B
speed 31.6 Gb/s
lanes 4
type SSD
serial <filter>
rev P2CR033
temp 29.9 C
ID-2 /dev/sda
maj-min 8:0
vendor Seagate
model ST2000DM008-2FR102
size 1.82 TiB
block-size
physical 4096 B
logical 512 B
speed 6.0 Gb/s
type N/A
serial <filter>
rev 0001
ID-3 /dev/sdb
maj-min 8:16
type USB
vendor Seagate
model M3 Portable
size 3.64 TiB
block-size
physical 4096 B
logical 512 B
type N/A
serial <filter>
rev 9300
ID-4 /dev/sdc
maj-min 8:32
type USB
vendor SMI (STMicroelectronics)
model USB
size 7.5 GiB
block-size
physical 512 B
logical 512 B
type N/A
serial <filter>
rev 1100
Message No optical or floppy data found.
ID-1 /
raw-size 465.76 GiB
size 457.37 GiB (98.20%)
used 34.06 GiB (7.4%)
fs ext4
block-size 4096 B
dev /dev/nvme0n1p3
maj-min 259:3
label N/A
uuid 83794e5a-2082-4277-a89e-9abe3e3975d5
ID-2 /boot/efi
raw-size 100 MiB
size 96 MiB (96.00%)
used 25.2 MiB (26.3%)
fs vfat
block-size 512 B
dev /dev/sda1
maj-min 8:1
label N/A
uuid C41D-8325
Alert No swap data was found.
ID-1 /dev/nvme0n1p1
maj-min 259:1
size 465.24 GiB
fs ntfs 12label N/A
uuid 2AA297640E2AA5A4
ID-2 /dev/nvme0n1p2
maj-min 259:2
size 522 MiB
fs ntfs
label N/A
uuid 22581961581934CF
ID-3 /dev/sda2
maj-min 8:2
size 931.46 GiB
fs ntfs
label N/A
uuid 4BA4C7AE12416E86
ID-4 /dev/sda3
maj-min 8:3
size 931.46 GiB
fs ext4
label N/A
uuid ec52ef2c-d01c-4642-ba5d-2187a205194b
ID-5 /dev/sdb1
maj-min 8:17
size 128 MiB
fs N/A
label N/A
uuid N/A
ID-6 /dev/sdb2
maj-min 8:18
size 3.64 TiB
fs N/A
label BackupS7
uuid 76F9-5300
ID-7 /dev/sdc1
maj-min 8:33
size 3.3 GiB
fs N/A
label MANJARO_GNOME_2126
uuid 2022-04-16-05-50-56-00
ID-8 /dev/sdc2
maj-min 8:34
size 4 MiB
fs N/A
label MISO_EFI
uuid 2B8A-6196
Hub-1 1-0:1
info Hi-speed hub with single TT
ports 10
rev 2.0
speed 480 Mb/s
chip-ID 1d6b:0002
class-ID 0900
Device-1 1-4:2
info Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type Mass Storage
driver usb-storage
interfaces 1
rev 2.0
speed 480 Mb/s
power 500mA
chip-ID 090c:1000
class-ID 0806
Device-2 1-6:3
info ASUSTek AURA LED Controller 12type HID
driver hid-generic,usbhid
interfaces 2
rev 2.0
speed 12 Mb/s
power 16mA
chip-ID 0b05:1939
class-ID 0300
serial <filter>
Hub-2 1-7:4
info Genesys Logic Hub
ports 4 12rev 2.0
speed 480 Mb/s
power 100mA
chip-ID 05e3:0608
class-ID 0900
Hub-3 2-0:1
info Super-speed hub
ports 4 12rev 3.1
speed 10 Gb/s
chip-ID 1d6b:0003
class-ID 0900
Device-1 2-3:2
info Seagate RSS LLC Maxtor M3 Portable
type Mass Storage
driver uas
interfaces 1
rev 3.0
speed 5 Gb/s
power 144mA
chip-ID 0bc2:61b7
class-ID 0806
serial <filter>
Hub-4 3-0:1
ports 4
rev 2.0
speed 480 Mb/s
chip-ID 1d6b:0002
class-ID 0900
Hub-5 3-4:2
info ASIX AX68004
ports 7
rev 1.0
speed 12 Mb/s
power 100mA
chip-ID 0b95:6804
class-ID 0900
Device-1 3-4.1:3
info Evision X-BOWS Ergonomic Keyboard
type Keyboard,Mouse
interfaces 2
rev 2.0
speed 12 Mb/s
power 100mA
chip-ID 320f:5055
class-ID 0301
Device-2 3-4.2:4
info Trust GXT 144 Gaming Mouse
type Mouse,Keyboard
interfaces 2
rev 1.1
speed 12 Mb/s
power 100mA
chip-ID 145f:026d
class-ID 0301
Hub-6 4-0:1
ports 4
rev 3.1
speed 10 Gb/s
chip-ID 1d6b:0003
class-ID 0900
System Temperatures
cpu N/A
mobo N/A
gpu amdgpu
temp 34.0 C
mem 32.0 C
Fan Speeds (RPM) N/A
gpu amdgpu
fan 0
Processes 353
Uptime 3m
wakeups 0
Init systemd
v 251
default graphical
tool systemctl
Compilers
gcc 12.1.0
clang 13.0.1
Packages 1607
pacman 1559
lib 428
flatpak 48
Client Unknown Client: systemd
inxi 3.3.17
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
Currently running: 5.15.32-1-MANJARO (linux515)
* linux515
- Pamac logs of the update :
[2022-06-12T20:16:28+0200] [PAMAC] synchronizing package lists
[2022-06-12T20:23:27+0200] [ALPM] running '00-timeshift-autosnap.hook'...
[2022-06-12T20:23:27+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2022-06-12T20:23:27+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2022-06-12T20:23:27+0200] [ALPM] running '71-dkms-remove.hook'...
[2022-06-12T20:23:27+0200] [ALPM-SCRIPTLET] Deprecated feature: REMAKE_INITRD
[2022-06-12T20:23:27+0200] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod akvcam/1.2.2 -k 5.15.41-1-MANJARO
[2022-06-12T20:23:27+0200] [ALPM-SCRIPTLET] ==> dkms remove --no-depmod v4l2loopback/0.12.5 -k 5.15.41-1-MANJARO
[2022-06-12T20:23:27+0200] [ALPM-SCRIPTLET] ==> depmod 5.15.41-1-MANJARO
[2022-06-12T20:23:34+0200] [ALPM] transaction started
[2022-06-12T20:23:34+0200] [ALPM] removed mangohud-wayland (0.6.7.1-4)
[2022-06-12T20:23:34+0200] [ALPM] removed mangohud-common-wayland (0.6.7.1-4)
[2022-06-12T20:23:34+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.51-1 -> 1:0.3.52-1)
[2022-06-12T20:23:34+0200] [ALPM] upgraded iana-etc (20220427-1 -> 20220603-1)
[2022-06-12T20:23:34+0200] [ALPM] warning: /etc/locale.conf saved as /etc/locale.conf.pacsave
[2022-06-12T20:23:34+0200] [ALPM] upgraded filesystem (2021.12.07-3 -> 2022.06.08-3)
[2022-06-12T20:23:34+0200] [ALPM-SCRIPTLET] Note: locale.conf is not longer tracked by
[2022-06-12T20:23:34+0200] [ALPM-SCRIPTLET] package management. Restoring /etc/locale.conf ...
[2022-06-12T20:23:34+0200] [ALPM] warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
[2022-06-12T20:23:34+0200] [ALPM] upgraded glibc (2.35-5 -> 2.35-6)
[2022-06-12T20:23:34+0200] [ALPM-SCRIPTLET] Generating locales...
[2022-06-12T20:23:35+0200] [ALPM-SCRIPTLET] en_US.UTF-8... done
[2022-06-12T20:23:36+0200] [ALPM-SCRIPTLET] fr_FR.UTF-8... done
[2022-06-12T20:23:36+0200] [ALPM-SCRIPTLET] Generation complete.
[2022-06-12T20:23:36+0200] [ALPM] upgraded alsa-ucm-conf (1.2.6.3-1 -> 1.2.7-1)
[2022-06-12T20:23:36+0200] [ALPM] upgraded alsa-lib (1.2.6.1-1 -> 1.2.7-2)
[2022-06-12T20:23:36+0200] [ALPM] upgraded hwdata (0.359-1 -> 0.360-1)
[2022-06-12T20:23:36+0200] [ALPM] upgraded zstd (1.5.2-3 -> 1.5.2-5)
[2022-06-12T20:23:36+0200] [ALPM] upgraded alsa-utils (1.2.6-1 -> 1.2.7-1)
[2022-06-12T20:23:36+0200] [ALPM] upgraded libldap (2.6.2-1 -> 2.6.2-2)
[2022-06-12T20:23:36+0200] [ALPM] installed libverto (0.3.2-4)
[2022-06-12T20:23:36+0200] [ALPM] upgraded krb5 (1.19.3-1 -> 1.19.3-3)
[2022-06-12T20:23:36+0200] [ALPM] upgraded python (3.10.4-1 -> 3.10.5-1)
[2022-06-12T20:23:36+0200] [ALPM] upgraded apparmor (3.0.4-1 -> 3.0.4-2)
[2022-06-12T20:23:36+0200] [ALPM] upgraded boost-libs (1.78.0-2 -> 1.78.0-3)
[2022-06-12T20:23:37+0200] [ALPM] upgraded boost (1.78.0-2 -> 1.78.0-3)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libgpg-error (1.45-1 -> 1.45-2)
[2022-06-12T20:23:37+0200] [ALPM] upgraded btrfs-progs (5.17-1 -> 5.18.1-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded systemd-libs (250.5-1 -> 251.2-3)
[2022-06-12T20:23:37+0200] [ALPM] upgraded gmp (6.2.1-1 -> 6.2.1-2)
[2022-06-12T20:23:37+0200] [ALPM] upgraded lib32-glibc (2.35-5 -> 2.35-6)
[2022-06-12T20:23:37+0200] [ALPM] upgraded ca-certificates-mozilla (3.78-1 -> 3.79-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded nspr (4.33-2 -> 4.34-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded nss (3.78-1 -> 3.79-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded re2 (1:20220401-1 -> 1:20220601-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded nettle (3.7.3-1 -> 3.8-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded gnutls (3.7.5-2 -> 3.7.6-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libtiff (4.3.0-2 -> 4.4.0-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded glib2 (2.72.1-1 -> 2.72.2-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libcups (1:2.4.1-1 -> 1:2.4.2-3)
[2022-06-12T20:23:37+0200] [ALPM] upgraded iso-codes (4.9.0-1 -> 4.10.0-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded xkeyboard-config (2.35.1-1 -> 2.36-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxkbcommon (1.4.0-1 -> 1.4.1-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libpciaccess (0.16-2 -> 0.16-3)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libdrm (2.4.110-1 -> 2.4.111-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxau (1.0.9-3 -> 1.0.9-4)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxdmcp (1.1.3-3 -> 1.1.3-4)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libx11 (1.8-1 -> 1.8.1-2)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxext (1.3.4-3 -> 1.3.4-4)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxxf86vm (1.1.4-4 -> 1.1.4-5)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxdamage (1.1.5-3 -> 1.1.5-4)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxshmfence (1.3-2 -> 1.3-3)
[2022-06-12T20:23:37+0200] [ALPM] upgraded llvm-libs (13.0.1-4 -> 13.0.1-6)
[2022-06-12T20:23:37+0200] [ALPM] upgraded mesa (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libproxy (0.4.17-6 -> 0.4.17-7)
[2022-06-12T20:23:37+0200] [ALPM] upgraded tracker3 (3.3.0-2 -> 3.3.1-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxrender (0.9.10-4 -> 0.9.10-5)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxrandr (1.5.2-3 -> 1.5.2-4)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxinerama (1.1.4-3 -> 1.1.4-4)
[2022-06-12T20:23:37+0200] [ALPM] upgraded graphite (1:1.3.14-1 -> 1:1.3.14-2)
[2022-06-12T20:23:37+0200] [ALPM] upgraded harfbuzz (4.2.1-1 -> 4.3.0-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded pixman (0.40.0-1 -> 0.40.0-2)
[2022-06-12T20:23:37+0200] [ALPM] upgraded gtk-update-icon-cache (1:4.6.4-1 -> 1:4.6.5-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libxcomposite (0.4.5-3 -> 0.4.5-4)
[2022-06-12T20:23:37+0200] [ALPM] upgraded kbd (2.4.0-2 -> 2.5.0-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded device-mapper (2.03.15-1 -> 2.03.16-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded libnftnl (1.2.1-1 -> 1.2.2-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded nftables (1:1.0.2-1 -> 1:1.0.4-1)
[2022-06-12T20:23:37+0200] [ALPM] upgraded systemd (250.5-1 -> 251.2-3)
[2022-06-12T20:23:38+0200] [ALPM] upgraded libxtst (1.2.3-4 -> 1.2.3-5)
[2022-06-12T20:23:38+0200] [ALPM] upgraded libxv (1.0.11-4 -> 1.0.11-5)
[2022-06-12T20:23:38+0200] [ALPM] upgraded hidapi (0.11.2-1 -> 0.12.0-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded sdl2 (2.0.22-1 -> 2.0.22-2)
[2022-06-12T20:23:38+0200] [ALPM] upgraded libice (1.0.10-3 -> 1.0.10-4)
[2022-06-12T20:23:38+0200] [ALPM] upgraded libsm (1.2.3-2 -> 1.2.3-3)
[2022-06-12T20:23:38+0200] [ALPM] upgraded libpulse (15.0-4 -> 16.0-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded libmfx (22.3.0-1 -> 22.4.2-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded caprine (2.55.4-1 -> 2.55.5-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded perl (5.34.1-1 -> 5.36.0-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded ckbcomp (1.207-1 -> 1.208-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded cmake (3.23.1-1 -> 3.23.2-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded cpupower (5.17-1 -> 5.18-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded libpaper (1.1.28-1 -> 1.1.28-2)
[2022-06-12T20:23:38+0200] [ALPM] upgraded poppler (22.05.0-2 -> 22.06.0-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded ijs (0.35-3 -> 0.35-4)
[2022-06-12T20:23:38+0200] [ALPM] upgraded imagemagick (7.1.0.35-1 -> 7.1.0.37-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded liblouis (3.21.0-1 -> 3.22.0-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded cups (1:2.4.1-1 -> 1:2.4.2-3)
[2022-06-12T20:23:38+0200] [ALPM] upgraded cups-pk-helper (0.2.6-4 -> 0.2.6-5)
[2022-06-12T20:23:38+0200] [ALPM] upgraded ding-libs (0.6.1-4 -> 0.6.2-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded dnsmasq (2.86-1 -> 2.86-2)
[2022-06-12T20:23:38+0200] [ALPM] upgraded edk2-ovmf (202202-2 -> 202205-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded poppler-glib (22.05.0-2 -> 22.06.0-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded gnome-desktop-common (1:42.1-1 -> 1:42.2-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded gnome-desktop (1:42.1-1 -> 1:42.2-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded gstreamer (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:38+0200] [ALPM] upgraded gst-plugins-base-libs (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:38+0200] [ALPM] upgraded lvm2 (2.03.15-1 -> 2.03.16-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded xfsprogs (5.16.0-1 -> 5.18.0-1)
[2022-06-12T20:23:38+0200] [ALPM] upgraded gvfs (1.50.1-1 -> 1.50.2-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded evince (42.2-1 -> 42.3-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded libphonenumber (1:8.12.48-1 -> 1:8.12.49-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded harfbuzz-icu (4.2.1-1 -> 4.3.0-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded hyphen (2.8.8-3 -> 2.8.8-4)
[2022-06-12T20:23:39+0200] [ALPM] upgraded webkit2gtk (2.36.2-1 -> 2.36.3-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded tdb (1.4.6-1 -> 1.4.7-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded sound-theme-freedesktop (0.8-4 -> 0.8-5)
[2022-06-12T20:23:39+0200] [ALPM] upgraded evolution-data-server (3.44.1-1 -> 3.44.2-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded f2fs-tools (1.14.0-3 -> 1.15.0-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded fakeroot (1.28-1 -> 1.29-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded gst-libav (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:39+0200] [ALPM] upgraded faudio (22.05-1 -> 22.06-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded libxmu (1.1.3-2 -> 1.1.3-3)
[2022-06-12T20:23:39+0200] [ALPM] upgraded xorg-xset (1.2.4-2 -> 1.2.4-3)
[2022-06-12T20:23:39+0200] [ALPM] upgraded xdg-utils (1.1.3+19+g9816ebb-1 -> 1.1.3+21+g1a58bc2-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded filezilla (3.59.0-1 -> 3.60.1-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-capture-tiny (0.48-5 -> 0.48-6)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-ffi-checklib (0.28-2 -> 0.28-3)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-file-which (1.27-1 -> 1.27-2)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-path-tiny (0.122-1 -> 0.122-2)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-alien-build (2.48-1 -> 2.48-3)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-alien-libxml2 (0.17-2 -> 0.17-3)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-xml-libxml (2.0207-2 -> 2.0207-3)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-clone (0.45-3 -> 0.45-4)
[2022-06-12T20:23:39+0200] [ALPM] upgraded perl-dbi (1.643-3 -> 1.643-4)
[2022-06-12T20:23:39+0200] [ALPM] upgraded foomatic-db-engine (4:20200206-1 -> 4:20220521-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded frei0r-plugins (1.7.0-2 -> 1.8.0-2)
[2022-06-12T20:23:39+0200] [ALPM] upgraded libxmlb (0.3.8-1 -> 0.3.9-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded fwupd (1.8.0-1 -> 1.8.1-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded fzf (0.30.0-2 -> 0.30.0-3)
[2022-06-12T20:23:39+0200] [ALPM] upgraded gedit (42.0-1 -> 42.1-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded glib2-docs (2.72.1-1 -> 2.72.2-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded python-pyxdg (0.27-4 -> 0.28-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded gnome-appfolders-manager (0.4.4-1 -> 0.4.5-1)
[2022-06-12T20:23:39+0200] [ALPM] installed openpmix (4.1.2-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded openmpi (4.1.2-1 -> 4.1.4-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded pulseaudio (15.0-4 -> 16.0-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded pulseaudio-bluetooth (15.0-4 -> 16.0-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded gnome-bluetooth (3.34.5-3 -> 3.34.5-4)
[2022-06-12T20:23:39+0200] [ALPM] upgraded libxkbcommon-x11 (1.4.0-1 -> 1.4.1-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded gst-plugins-bad-libs (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:39+0200] [ALPM] upgraded gtk4 (1:4.6.4-1 -> 1:4.6.5-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded libadwaita (1:1.1.1-1 -> 1:1.1.2-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded upower (0.99.18-1 -> 0.99.19-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded gnome-bluetooth-3.0 (42.0-1 -> 42.1-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded mtools (1:4.0.39-1 -> 1:4.0.40-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded osinfo-db (20220214-1 -> 20220516-1)
[2022-06-12T20:23:39+0200] [ALPM] upgraded numactl (2.0.14-2 -> 2.0.14-3)
[2022-06-12T20:23:39+0200] [ALPM] warning: directory permissions differ on /etc/libvirt/secrets/
filesystem: 755 package: 700
[2022-06-12T20:23:40+0200] [ALPM] upgraded libvirt (1:8.3.0-1 -> 1:8.4.0-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded libbpf (0.7.0-1 -> 0.8.0-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gst-plugins-base (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gst-plugins-good (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-boxes (42.0.1-2 -> 42.1-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-calculator (42.0-1 -> 42.1-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-desktop-4 (1:42.1-1 -> 1:42.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-settings-daemon (42.1-1 -> 42.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded talloc (2.3.3-3 -> 2.3.4-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded tevent (1:0.11.0-3 -> 1:0.12.1-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded ldb (2:2.5.0-1 -> 2:2.5.1-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded smbclient (4.16.1-3 -> 4.16.1-4)
[2022-06-12T20:23:40+0200] [ALPM] upgraded libxkbfile (1.1.0-2 -> 1.1.0-3)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-control-center (42.1-5 -> 42.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-firmware (42.1-1 -> 42.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-keyring (1:40.0-1.1 -> 1:42.1-1)
[2022-06-12T20:23:40+0200] [ALPM-SCRIPTLET] Created symlink /etc/systemd/user/sockets.target.wants/gnome-keyring-daemon.socket → /usr/lib/systemd/user/gnome-keyring-daemon.socket.
[2022-06-12T20:23:40+0200] [ALPM] upgraded lv2 (1.18.2-1 -> 1.18.4-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded serd (0.30.10-1 -> 0.30.12-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded sord (0.16.8-1 -> 0.16.10-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded sratom (0.6.8-3 -> 0.6.10-3)
[2022-06-12T20:23:40+0200] [ALPM] upgraded lilv (0.24.12-4 -> 0.24.14-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded pipewire (1:0.3.51-1 -> 1:0.3.52-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded xorg-server-common (21.1.3-4 -> 21.1.3-5)
[2022-06-12T20:23:40+0200] [ALPM] upgraded xorg-xwayland (22.1.1-1 -> 22.1.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded mtdev (1.1.6-1 -> 1.1.6-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded xcb-util (0.4.0-3 -> 0.4.0-4)
[2022-06-12T20:23:40+0200] [ALPM] upgraded mutter (42.1-1 -> 42.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded js91 (91.9.0-1 -> 91.10.0-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded libdvdread (6.1.2-1 -> 6.1.3-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-shell (1:42.1-1 -> 1:42.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gnome-shell-extensions (42.1-1 -> 42.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded libxpm (3.5.13-2 -> 3.5.13-3)
[2022-06-12T20:23:40+0200] [ALPM] upgraded graphviz (3.0.0-1 -> 4.0.0-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded grub (2.06-6 -> 2.06.r261.g2f4430cc0-1)
[2022-06-12T20:23:40+0200] [ALPM-SCRIPTLET] :: Grub does no longer support side-loading modules when secure boot is
[2022-06-12T20:23:40+0200] [ALPM-SCRIPTLET] enabled. Thus booting will fail, unless you have an efi executable
[2022-06-12T20:23:40+0200] [ALPM-SCRIPTLET] 'grubx64.efi' with bundled modules.
[2022-06-12T20:23:40+0200] [ALPM] upgraded gssproxy (0.8.4-1 -> 0.9.1-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gst-editing-services (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gst-plugin-gtk (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded lib32-alsa-lib (1.2.6.1-1 -> 1.2.7-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gst-plugin-pipewire (1:0.3.51-1 -> 1:0.3.52-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gst-plugins-bad (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gst-plugins-ugly (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gst-python (1.20.2-1 -> 1.20.2-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gtest (1.11.0-3 -> 1.11.0-4)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gupnp-av (0.14.0-1 -> 0.14.1-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gvfs-afc (1.50.1-1 -> 1.50.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gvfs-goa (1.50.1-1 -> 1.50.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gvfs-google (1.50.1-1 -> 1.50.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gvfs-gphoto2 (1.50.1-1 -> 1.50.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gvfs-mtp (1.50.1-1 -> 1.50.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gvfs-nfs (1.50.1-1 -> 1.50.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded gvfs-smb (1.50.1-1 -> 1.50.2-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded net-snmp (5.9.1-3 -> 5.9.1-4)
[2022-06-12T20:23:40+0200] [ALPM] upgraded hplip (1:3.22.4-1 -> 1:3.22.4-2)
[2022-06-12T20:23:40+0200] [ALPM] upgraded htop (3.2.0-1 -> 3.2.1-1)
[2022-06-12T20:23:40+0200] [ALPM] upgraded hunspell (1.7.0-3 -> 1.7.0-4)
[2022-06-12T20:23:41+0200] [ALPM] upgraded iproute2 (5.17.0-3 -> 5.18.0-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded iw (5.16-1 -> 5.19-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded jasper (3.0.3-1 -> 3.0.4-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded jemalloc (1:5.2.1-6 -> 1:5.3.0-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded xcb-util-keysyms (0.4.0-3 -> 0.4.0-4)
[2022-06-12T20:23:41+0200] [ALPM] upgraded xcb-util-renderutil (0.3.9-3 -> 0.3.9-4)
[2022-06-12T20:23:41+0200] [ALPM] upgraded xcb-util-wm (0.4.1-3 -> 0.4.1-4)
[2022-06-12T20:23:41+0200] [ALPM] upgraded xcb-util-image (0.4.0-3 -> 0.4.0-4)
[2022-06-12T20:23:41+0200] [ALPM] upgraded qt5-base (5.15.4+kde+r144-1 -> 5.15.4+kde+r164-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded qt5-multimedia (5.15.4+kde+r0-1 -> 5.15.4+kde+r1-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded knewstuff (5.94.0-1 -> 5.94.0-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded krita (5.0.6-2 -> 5.0.8-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-systemd (250.5-1 -> 251.1-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxau (1.0.9-1 -> 1.0.9-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxext (1.3.4-1 -> 1.3.4-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libdrm (2.4.110-1 -> 2.4.111-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxxf86vm (1.1.4-2 -> 1.1.4-3)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxdamage (1.1.5-1 -> 1.1.5-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-mesa (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-faudio (22.05-1 -> 22.06-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-glib2 (2.72.1-1 -> 2.72.2-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-gnutls (3.7.4-1 -> 3.7.6-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libtiff (4.3.0-2 -> 4.4.0-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libcups (2.4.1-1 -> 2.4.2-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxcomposite (0.4.5-1 -> 0.4.5-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxinerama (1.1.4-1 -> 1.1.4-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxkbcommon (1.4.0-1 -> 1.4.1-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxrandr (1.5.2-1 -> 1.5.2-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libpulse (15.0-2 -> 16.0-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-harfbuzz (4.2.1-1 -> 4.3.0-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-sqlite (3.38.3-1 -> 3.38.5-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-gtk3 (3.24.33-1 -> 3.24.34-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxmu (1.1.3-1 -> 1.1.3-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded libxss (1.2.3-3 -> 1.2.3-4)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-libxss (1.2.3-1 -> 1.2.3-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-mesa-vdpau (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-nspr (4.33-2 -> 4.34-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-nss (3.78-1 -> 3.79-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-vulkan-intel (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded lib32-vulkan-radeon (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:41+0200] [ALPM] upgraded libfprint (1.94.3-1 -> 1.94.4-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded libmediaart (1.9.5-1 -> 1.9.6-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded libnautilus-extension (42.1.1-1 -> 42.2-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded sgml-common (0.6.3-7 -> 0.6.3-8)
[2022-06-12T20:23:41+0200] [ALPM] upgraded libofx (0.10.3-1 -> 0.10.5-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded pacman (6.0.1-7 -> 6.0.1-9)
[2022-06-12T20:23:41+0200] [ALPM] upgraded perl-error (0.17029-3 -> 0.17029-4)
[2022-06-12T20:23:41+0200] [ALPM] upgraded perl-timedate (2.33-3 -> 2.33-4)
[2022-06-12T20:23:41+0200] [ALPM] upgraded perl-mailtools (2.21-5 -> 2.21-6)
[2022-06-12T20:23:41+0200] [ALPM] upgraded libpamac (11.3.0-1 -> 11.3.1-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded ostree (2022.3-1 -> 2022.4-1)
[2022-06-12T20:23:41+0200] [ALPM] upgraded libpamac-flatpak-plugin (11.3.0-1 -> 11.3.1-1)
[2022-06-12T20:23:42+0200] [ALPM] upgraded snapd (2.55.5-1 -> 2.56-1)
[2022-06-12T20:23:42+0200] [ALPM] upgraded libpamac-snap-plugin (11.3.0-1 -> 11.3.1-1)
[2022-06-12T20:23:42+0200] [ALPM] upgraded libva-mesa-driver (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:42+0200] [ALPM] upgraded libvirt-python (1:8.2.0-1 -> 1:8.4.0-1)
[2022-06-12T20:23:42+0200] [ALPM] upgraded linux515 (5.15.41-1 -> 5.15.46-1)
[2022-06-12T20:23:43+0200] [ALPM] upgraded linux515-headers (5.15.41-1 -> 5.15.46-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded llvm (13.0.1-4 -> 13.0.1-6)
[2022-06-12T20:23:44+0200] [ALPM] upgraded lrzip (0.641-2 -> 0.651-2)
[2022-06-12T20:23:44+0200] [ALPM] upgraded luajit (2.1.0.beta3.r404.g3ee3c9cf-1 -> 2.1.0.beta3.r411.g68bb1140-1)
[2022-06-12T20:23:44+0200] [ALPM] installed mangohud-common (0.6.7.1-5)
[2022-06-12T20:23:44+0200] [ALPM] installed mangohud (0.6.7.1-5)
[2022-06-12T20:23:44+0200] [ALPM] upgraded mesa-utils (8.4.0-8 -> 8.5.0-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded mesa-vdpau (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:44+0200] [ALPM] upgraded ninja (1.10.2-1 -> 1.11.0-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded meson (0.62.1-1 -> 0.62.2-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded mhwd-nvidia (510.73.05-1 -> 515.48.07-2)
[2022-06-12T20:23:44+0200] [ALPM] upgraded mhwd-nvidia-390xx (390.151-1 -> 390.151-2)
[2022-06-12T20:23:44+0200] [ALPM] upgraded nano-syntax-highlighting (2020.10.10+r10-1 -> 2020.10.10+10+g1aa64a8-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded tracker3-miners (3.3.0-2 -> 3.3.1-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded nautilus (42.1.1-1 -> 42.2-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded network-manager-sstp (1.2.6-4 -> 1.3.0-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded nm-connection-editor (1.26.0-1 -> 1.28.0-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded noto-fonts (20220502-2 -> 20220502-3)
[2022-06-12T20:23:44+0200] [ALPM] upgraded ntfs-3g (2021.8.22-1 -> 2022.5.17-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded openjade (1.3.2-6 -> 1.3.2-7)
[2022-06-12T20:23:44+0200] [ALPM] upgraded openvpn (2.5.6-1 -> 2.5.7-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded pamac-cli (10.4.0-2 -> 10.4.1-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded pamac-gtk (10.4.0-2 -> 10.4.1-1)
[2022-06-12T20:23:44+0200] [ALPM] upgraded pamac-gnome-integration (10.4.0-2 -> 10.4.1-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded papirus-icon-theme (20220508-1 -> 20220606-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-encode-locale (1.05-8 -> 1.05-9)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-http-date (6.05-4 -> 6.05-5)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-file-listing (6.15-1 -> 6.15-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-html-tagset (3.20-11 -> 3.20-12)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-io-html (1.004-2 -> 1.004-3)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-lwp-mediatypes (6.04-1 -> 6.04-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-uri (5.10-1 -> 5.10-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-http-message (6.36-1 -> 6.36-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-html-parser (3.78-1 -> 3.78-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-http-cookies (6.10-2 -> 6.10-3)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-http-daemon (6.14-1 -> 6.14-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-http-negotiate (6.01-9 -> 6.01-10)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-net-http (6.22-1 -> 6.22-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-try-tiny (0.31-1 -> 0.31-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-www-robotrules (6.02-9 -> 6.02-10)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-libwww (6.60-1 -> 6.60-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-parse-yapp (1.21-4 -> 1.21-5)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-sgmls (1:1.1-8 -> 1:1.1-9)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-xml-parser (2.46-3 -> 2.46-4)
[2022-06-12T20:23:48+0200] [ALPM] upgraded perl-xml-writer (0.625-7 -> 0.900-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded poppler-qt5 (22.05.0-2 -> 22.06.0-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded pulseaudio-equalizer (15.0-4 -> 16.0-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded pulseaudio-jack (15.0-4 -> 16.0-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded pulseaudio-lirc (15.0-4 -> 16.0-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded pulseaudio-rtp (15.0-4 -> 16.0-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded pulseaudio-zeroconf (15.0-4 -> 16.0-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded python-cryptography (37.0.0-1 -> 37.0.2-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded python-filelock (3.5.0-1 -> 3.5.1-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded python-pillow (9.1.0-1 -> 9.1.1-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded python-platformdirs (2.5.0-1 -> 2.5.1-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded python-zipp (3.8.0-1 -> 3.8.0-2)
[2022-06-12T20:23:48+0200] [ALPM] upgraded qt5-script (5.15.9-2 -> 5.15.10-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded qt5-webengine (5.15.9-3 -> 5.15.10-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded rygel (1:0.40.3-1 -> 1:0.40.4-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded s-nail (14.9.23-1 -> 14.9.24-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded samba (4.16.1-3 -> 4.16.1-4)
[2022-06-12T20:23:48+0200] [ALPM] upgraded seahorse (1:41.0-2 -> 1:42.0-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded subversion (1.14.1-5 -> 1.14.1-6)
[2022-06-12T20:23:48+0200] [ALPM] upgraded sudo (1.9.10-1 -> 1.9.11.p1-1)
[2022-06-12T20:23:48+0200] [ALPM] upgraded systemd-sysvcompat (250.5-1 -> 251.2-3)
[2022-06-12T20:23:48+0200] [ALPM] upgraded xorg-xhost (1.0.8-2 -> 1.0.8-3)
[2022-06-12T20:23:48+0200] [ALPM] upgraded timeshift (21.09.1-4 -> 22.06.1-1)
[2022-06-12T20:23:48+0200] [ALPM-SCRIPTLET] TimeShift automatic backups require the cronie.service to be running.
[2022-06-12T20:23:48+0200] [ALPM-SCRIPTLET] Try:
[2022-06-12T20:23:48+0200] [ALPM-SCRIPTLET] systemctl enable --now cronie.service
[2022-06-12T20:23:49+0200] [ALPM] upgraded vim-runtime (8.2.4827-1 -> 8.2.5046-2)
[2022-06-12T20:23:49+0200] [ALPM] upgraded vim (8.2.4827-1 -> 8.2.5046-2)
[2022-06-12T20:23:49+0200] [ALPM] upgraded vulkan-intel (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:49+0200] [ALPM] upgraded vulkan-radeon (22.0.4-1 -> 22.1.1-2)
[2022-06-12T20:23:49+0200] [ALPM] upgraded webkit2gtk-4.1 (2.36.2-1 -> 2.36.3-1)
[2022-06-12T20:23:49+0200] [ALPM] upgraded wine (7.7-1 -> 7.10-1)
[2022-06-12T20:23:49+0200] [ALPM] upgraded wireless-regdb (2022.04.08-1 -> 2022.06.06-1)
[2022-06-12T20:23:49+0200] [ALPM] upgraded xcb-util-cursor (0.1.3-3 -> 0.1.3-4)
[2022-06-12T20:23:49+0200] [ALPM] upgraded xorg-server (21.1.3-4 -> 21.1.3-5)
[2022-06-12T20:23:49+0200] [ALPM] upgraded xorg-xinput (1.6.3-2 -> 1.6.3-3)
[2022-06-12T20:23:49+0200] [ALPM] upgraded xorg-xmessage (1.0.5-2 -> 1.0.5-3)
[2022-06-12T20:23:49+0200] [ALPM] upgraded xorg-xmodmap (1.0.10-2 -> 1.0.10-3)
[2022-06-12T20:23:49+0200] [ALPM] transaction completed
[2022-06-12T20:23:53+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2022-06-12T20:23:53+0200] [ALPM] running '30-systemd-binfmt.hook'...
[2022-06-12T20:23:53+0200] [ALPM] running '30-systemd-catalog.hook'...
[2022-06-12T20:23:53+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2022-06-12T20:23:53+0200] [ALPM] running '30-systemd-hwdb.hook'...
[2022-06-12T20:23:53+0200] [ALPM] running '30-systemd-sysctl.hook'...
[2022-06-12T20:23:53+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2022-06-12T20:23:54+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2022-06-12T20:23:54+0200] [ALPM] running '30-systemd-update.hook'...
[2022-06-12T20:23:54+0200] [ALPM] running '30-update-mime-database.hook'...
[2022-06-12T20:23:54+0200] [ALPM] running '40-update-ca-trust.hook'...
[2022-06-12T20:23:54+0200] [ALPM] running '60-depmod.hook'...
[2022-06-12T20:23:58+0200] [ALPM] running '60-glibc-locales.hook'...
[2022-06-12T20:24:02+0200] [ALPM] running '70-dkms-install.hook'...
[2022-06-12T20:24:02+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod v4l2loopback/0.12.5 -k 5.15.46-1-MANJARO
[2022-06-12T20:24:03+0200] [ALPM-SCRIPTLET] Deprecated feature: REMAKE_INITRD
[2022-06-12T20:24:04+0200] [ALPM-SCRIPTLET] ==> dkms install --no-depmod akvcam/1.2.2 -k 5.15.46-1-MANJARO
[2022-06-12T20:24:04+0200] [ALPM-SCRIPTLET] Deprecated feature: REMAKE_INITRD
[2022-06-12T20:24:06+0200] [ALPM-SCRIPTLET] ==> depmod 5.15.46-1-MANJARO
[2022-06-12T20:24:10+0200] [ALPM] running '80-cronie.hook'...
[2022-06-12T20:24:10+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2022-06-12T20:24:10+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
[2022-06-12T20:24:10+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
[2022-06-12T20:24:10+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.15.46-1-MANJARO
[2022-06-12T20:24:10+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-06-12T20:24:10+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-06-12T20:24:10+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2022-06-12T20:24:10+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-06-12T20:24:10+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-06-12T20:24:11+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
[2022-06-12T20:24:12+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-06-12T20:24:12+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
[2022-06-12T20:24:12+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
[2022-06-12T20:24:12+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.15.46-1-MANJARO
[2022-06-12T20:24:12+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2022-06-12T20:24:12+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2022-06-12T20:24:12+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2022-06-12T20:24:12+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2022-06-12T20:24:13+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qed
[2022-06-12T20:24:13+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla1280
[2022-06-12T20:24:13+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: qla2xxx
[2022-06-12T20:24:13+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: bfa
[2022-06-12T20:24:14+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2022-06-12T20:24:14+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2022-06-12T20:24:14+0200] [ALPM-SCRIPTLET] -> Running build hook: [consolefont]
[2022-06-12T20:24:14+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2022-06-12T20:24:14+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2022-06-12T20:24:14+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2022-06-12T20:24:15+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2022-06-12T20:24:16+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2022-06-12T20:24:16+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-06-12T20:24:20+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2022-06-12T20:24:20+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2022-06-12T20:24:20+0200] [ALPM] running '99-grub.hook'...
[2022-06-12T20:24:20+0200] [ALPM-SCRIPTLET] Création du fichier de configuration GRUB…
[2022-06-12T20:24:20+0200] [ALPM-SCRIPTLET] Thème trouvé : /usr/share/grub/themes/manjaro/theme.txt
[2022-06-12T20:24:20+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-5.15-x86_64
[2022-06-12T20:24:20+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
[2022-06-12T20:24:21+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
[2022-06-12T20:24:21+0200] [ALPM-SCRIPTLET] Attention : le sondeur de systèmes d'exploitation sera exécuté pour détecter d'autres partitions amorçables.
[2022-06-12T20:24:21+0200] [ALPM-SCRIPTLET] Sa sortie sera utilisée pour détecter les binaires amorçables qu'elles contiennent et créer de nouvelles entrées d'amorçage.
[2022-06-12T20:24:23+0200] [ALPM-SCRIPTLET] Windows Boot Manager trouvé sur /dev/sda1@/EFI/Microsoft/Boot/bootmgfw.efi
[2022-06-12T20:24:23+0200] [ALPM-SCRIPTLET] Ajout de l'entrée du menu d'amorçage pour les paramètres du firmware UEFI …
[2022-06-12T20:24:23+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2022-06-12T20:24:23+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe : attention : type de périphérique nvme0n1 inconnu.
[2022-06-12T20:24:23+0200] [ALPM-SCRIPTLET] fait
[2022-06-12T20:24:23+0200] [ALPM] running 'dbus-reload.hook'...
[2022-06-12T20:24:23+0200] [ALPM] running 'detect-old-perl-modules.hook'...
[2022-06-12T20:24:23+0200] [ALPM] running 'extract-libadwaita-theme.hook'...
[2022-06-12T20:24:23+0200] [ALPM] running 'fontconfig.hook'...
[2022-06-12T20:24:23+0200] [ALPM] running 'fontconfig-32.hook'...
[2022-06-12T20:24:23+0200] [ALPM] running 'gio-querymodules.hook'...
[2022-06-12T20:24:23+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2022-06-12T20:24:23+0200] [ALPM] running 'gtk-query-immodules-3.0-32.hook'...
[2022-06-12T20:24:23+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2022-06-12T20:24:27+0200] [ALPM] running 'gtk4-querymodules.hook'...
[2022-06-12T20:24:27+0200] [ALPM] running 'gvfsd.hook'...
[2022-06-12T20:24:27+0200] [ALPM] running 'locale-gen.hook'...
[2022-06-12T20:24:27+0200] [ALPM] running 'manjaro-printer.hook'...
[2022-06-12T20:24:27+0200] [ALPM] running 'texinfo-install.hook'...
[2022-06-12T20:24:28+0200] [ALPM] running 'update-desktop-database.hook'...
[2022-06-12T20:24:28+0200] [ALPM] running 'vimdoc.hook'...
[2022-06-12T20:24:28+0200] [ALPM] running 'xorg-mkfontscale.hook'...
------------ Sun Jun 12 18:35:08 CEST 2022 ------------
%G/dev/nvme0n1p3: clean, 661516/30531584 files, 10733205/122095104 blocks
[[0;32m OK [0m] Finished [0;1;39mTell Plymouth To Write Out Runtime Data[0m.
[[0;32m OK [0m] Finished [0;1;39mLoad/Save Random Seed[0m.
[[0;32m OK [0m] Finished [0;1;39mCreate Volatile Files and Directories[0m.
Starting [0;1;39mRebuild Journal Catalog[0m...
Starting [0;1;39mRecord System Boot/Shutdown in UTMP[0m...
[[0;32m OK [0m] Finished [0;1;39mRecord System Boot/Shutdown in UTMP[0m.
[[0;32m OK [0m] Finished [0;1;39mRebuild Journal Catalog[0m.
[[0;32m OK [0m] Finished [0;1;39mRebuild Dynamic Linker Cache[0m.
Starting [0;1;39mUpdate is Completed[0m...
[[0;32m OK [0m] Finished [0;1;39mUpdate is Completed[0m.
[[0;32m OK [0m] Reached target [0;1;39mSystem Initialization[0m.
[[0;32m OK [0m] Started [0;1;39mCUPS Scheduler[0m.
[[0;32m OK [0m] Started [0;1;39mDaily rotation of log files[0m.
[[0;32m OK [0m] Started [0;1;39mDaily man-db regeneration[0m.
[[0;32m OK [0m] Started [0;1;39mMonthly clean packages cache[0m.
[[0;32m OK [0m] Started [0;1;39mGenerate mirrorlist weekly[0m.
[[0;32m OK [0m] Started [0;1;39mpkgfile database update timer[0m.
[[0;32m OK [0m] Started [0;1;39mDaily verification of password and group files[0m.
[[0;32m OK [0m] Started [0;1;39mDaily Cleanup of Temporary Directories[0m.
[[0;32m OK [0m] Reached target [0;1;39mPath Units[0m.
[[0;32m OK [0m] Reached target [0;1;39mTimer Units[0m.
[[0;32m OK [0m] Listening on [0;1;39mCUPS Scheduler[0m.
[[0;32m OK [0m] Listening on [0;1;39mD-Bus System Message Bus Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mLibvirt local socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mLibvirt admin socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mLibvirt local read-only socket[0m.
Starting [0;1;39mSocket activation for snappy daemon[0m...
[[0;32m OK [0m] Listening on [0;1;39mVirtual machine lock manager socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mVirtual machine log manager socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mSocket activation for snappy daemon[0m.
[[0;32m OK [0m] Reached target [0;1;39mSocket Units[0m.
[[0;32m OK [0m] Reached target [0;1;39mBasic System[0m.
Starting [0;1;39mSave/Restore Sound Card State[0m...
Starting [0;1;39mD-Bus System Message Bus[0m...
Starting [0;1;39mAuthorization Manager[0m...
Starting [0;1;39mSnap Daemon[0m...
Starting [0;1;39mUser Login Management[0m...
Starting [0;1;39mVirtual Machine a…tainer Registration Service[0m...
[[0;32m OK [0m] Finished [0;1;39mSave/Restore Sound Card State[0m.
[[0;32m OK [0m] Reached target [0;1;39mSound Card[0m.
[[0;32m OK [0m] Started [0;1;39mD-Bus System Message Bus[0m.
Starting [0;1;39mNetwork Manager[0m...
[[0;32m OK [0m] Started [0;1;39mUser Login Management[0m.
[[0;32m OK [0m] Started [0;1;39mVirtual Machine an…ontainer Registration Service[0m.
[[0;32m OK [0m] Started [0;1;39mAuthorization Manager[0m.
Starting [0;1;39mModem Manager[0m...
[[0;32m OK [0m] Started [0;1;39mNetwork Manager[0m.
[[0;32m OK [0m] Reached target [0;1;39mNetwork[0m.
Starting [0;1;39mCUPS Scheduler[0m...
Starting [0;1;39mVirtualization daemon[0m...
Starting [0;1;39mPermit User Sessions[0m...
[[0;32m OK [0m] Finished [0;1;39mPermit User Sessions[0m.
Starting [0;1;39mGNOME Display Manager[0m...
Starting [0;1;39mHold until boot process finishes up[0m...
Starting [0;1;39mHostname Service[0m...
[[0;32m OK [0m] Started [0;1;39mGNOME Display Manager[0m.
[[0;32m OK [0m] Started [0;1;39mHostname Service[0m.
------------ Sun Jun 12 19:22:49 CEST 2022 ------------
%G/dev/nvme0n1p3: clean, 661516/30531584 files, 10737303/122095104 blocks
------------ Sun Jun 12 20:26:59 CEST 2022 ------------
%G/dev/nvme0n1p3: clean, 662484/30531584 files, 10992442/122095104 blocks
------------ Sun Jun 12 20:32:41 CEST 2022 ------------
%G/dev/nvme0n1p3: recovering journal
/dev/nvme0n1p3: clean, 662498/30531584 files, 11002055/122095104 blocks
------------ Sun Jun 12 20:41:53 CEST 2022 ------------
%G/dev/nvme0n1p3: clean, 662498/30531584 files, 11021899/122095104 blocks
------------ Sun Jun 12 20:43:49 CEST 2022 ------------
/dev/nvme0n1p3: clean, 662514/30531584 files, 11027423/122095104 blocks
Mounting [0;1;39mArbitrary Executable File Formats File System[0m...
[[0;32m OK [0m] Mounted [0;1;39mArbitrary Executable File Formats File System[0m.
[[0;32m OK [0m] Finished [0;1;39mSet Up Additional Binary Formats[0m.
------------ Sun Jun 12 20:50:40 CEST 2022 ------------
/dev/nvme0n1p3: clean, 662520/30531584 files, 11039080/122095104 blocks
------------ Sun Jun 12 20:59:22 CEST 2022 ------------
%G/dev/nvme0n1p3: clean, 662528/30531584 files, 11050740/122095104 blocks
------------ Sun Jun 12 21:04:43 CEST 2022 ------------
:: running hook [udev]
:: Triggering uevents...
:: running hook [keymap]
:: Loading keymap...%Gdone.
:: running hook [plymouth]
:: performing fsck on '/dev/nvme0n1p3'
/dev/nvme0n1p3: clean, 662536/30531584 files, 11064449/122095104 blocks
:: mounting '/dev/nvme0n1p3' on real root
:: running late hook [plymouth]
:: running cleanup hook [udev]
Welcome to [32;1;24;144;200mManjaro Linux[0m!
[[0;32m OK [0m] Created slice [0;1;39mVirtual Machine and Container Slice[0m.
[[0;32m OK [0m] Created slice [0;1;39mSlice /system/getty[0m.
[[0;32m OK [0m] Created slice [0;1;39mSlice /system/modprobe[0m.
[[0;32m OK [0m] Created slice [0;1;39mSlice /system/systemd-fsck[0m.
[[0;32m OK [0m] Created slice [0;1;39mUser and Session Slice[0m.
[[0;32m OK [0m] Started [0;1;39mForward Password Requests to Wall Directory Watch[0m.
[[0;32m OK [0m] Set up automount [0;1;39mArbitrary Executable File Formats File System Automount Point[0m.
[[0;32m OK [0m] Reached target [0;1;39mLogin Prompts[0m.
[[0;32m OK [0m] Reached target [0;1;39mLocal Integrity Protected Volumes[0m.
[[0;32m OK [0m] Reached target [0;1;39mRemote File Systems[0m.
[[0;32m OK [0m] Reached target [0;1;39mSlice Units[0m.
[[0;32m OK [0m] Reached target [0;1;39mSwaps[0m.
[[0;32m OK [0m] Reached target [0;1;39mLocal Verity Protected Volumes[0m.
[[0;32m OK [0m] Listening on [0;1;39mDevice-mapper event daemon FIFOs[0m.
[[0;32m OK [0m] Listening on [0;1;39mLVM2 poll daemon socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mProcess Core Dump Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mJournal Audit Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mJournal Socket (/dev/log)[0m.
[[0;32m OK [0m] Listening on [0;1;39mJournal Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mudev Control Socket[0m.
[[0;32m OK [0m] Listening on [0;1;39mudev Kernel Socket[0m.
Mounting [0;1;39mHuge Pages File System[0m...
Mounting [0;1;39mPOSIX Message Queue File System[0m...
Mounting [0;1;39mKernel Debug File System[0m...
Mounting [0;1;39mKernel Trace File System[0m...
Mounting [0;1;39mTemporary Directory /tmp[0m...
Starting [0;1;39mLoad AppArmor profiles[0m...
Starting [0;1;39mCreate List of Static Device Nodes[0m...
Starting [0;1;39mMonitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling[0m...
Starting [0;1;39mLoad Kernel Module configfs[0m...
Starting [0;1;39mLoad Kernel Module drm[0m...
Starting [0;1;39mLoad Kernel Module fuse[0m...
Starting [0;1;39mLoad Kernel Modules[0m...
Starting [0;1;39mRemount Root and Kernel File Systems[0m...
Starting [0;1;39mColdplug All udev Devices[0m...
[[0;32m OK [0m] Mounted [0;1;39mHuge Pages File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mPOSIX Message Queue File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mKernel Debug File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mKernel Trace File System[0m.
[[0;32m OK [0m] Mounted [0;1;39mTemporary Directory /tmp[0m.
[[0;32m OK [0m] Finished [0;1;39mCreate List of Static Device Nodes[0m.
[[0;32m OK [0m] Finished [0;1;39mLoad Kernel Module configfs[0m.
[[0;32m OK [0m] Finished [0;1;39mLoad Kernel Module drm[0m.
Mounting [0;1;39mKernel Configuration File System[0m...
[[0;32m OK [0m] Mounted [0;1;39mKernel Configuration File System[0m.
[[0;32m OK [0m] Finished [0;1;39mRemount Root and Kernel File Systems[0m.
Starting [0;1;39mLoad/Save Random Seed[0m...
Starting [0;1;39mCreate Static Device Nodes in /dev[0m...
Starting [0;1;39mSetup Virtual Console[0m...
[[0;32m OK [0m] Finished [0;1;39mLoad Kernel Module fuse[0m.
Mounting [0;1;39mFUSE Control File System[0m...
[[0;32m OK [0m] Mounted [0;1;39mFUSE Control File System[0m.
[[0;32m OK [0m] Finished [0;1;39mSetup Virtual Console[0m.
[[0;32m OK [0m] Finished [0;1;39mCreate Static Device Nodes in /dev[0m.
Starting [0;1;39mJournal Service[0m...
Starting [0;1;39mRule-based Manager for Device Events and Files[0m...
[[0;32m OK [0m] Finished [0;1;39mLoad Kernel Modules[0m.
Starting [0;1;39mApply Kernel Variables[0m...
[[0;32m OK [0m] Finished [0;1;39mColdplug All udev Devices[0m.
[[0;32m OK [0m] Finished [0;1;39mApply Kernel Variables[0m.
Starting [0;1;39mCLI Netfilter Manager[0m...
[[0;32m OK [0m] Finished [0;1;39mCLI Netfilter Manager[0m.
[[0;32m OK [0m] Started [0;1;39mJournal Service[0m.
Starting [0;1;39mFlush Journal to Persistent Storage[0m...
[[0;32m OK [0m] Finished [0;1;39mMonitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling[0m.
[[0;32m OK [0m] Reached target [0;1;39mPreparation for Local File Systems[0m.
[[0;32m OK [0m] Started [0;1;39mRule-based Manager for Device Events and Files[0m.
Starting [0;1;39mShow Plymouth Boot Screen[0m...
[[0;32m OK [0m] Started [0;1;39mShow Plymouth Boot Screen[0m.
[[0;32m OK [0m] Started [0;1;39mForward Password Requests to Plymouth Directory Watch[0m.
[[0;32m OK [0m] Reached target [0;1;39mLocal Encrypted Volumes[0m.
[[0;32m OK [0m] Finished [0;1;39mFlush Journal to Persistent Storage[0m.
[[0;32m OK [0m] Finished [0;1;39mLoad AppArmor profiles[0m.
Starting [0;1;39mLoad AppArmor profiles managed internally by snapd[0m...
[[0;32m OK [0m] Finished [0;1;39mLoad AppArmor profiles managed internally by snapd[0m.
[[0;32m OK [0m] Found device [0;1;39mST2000DM008-2FR102 EFI\x20system\x20partition[0m.
Starting [0;1;39mFile System Check on /dev/disk/by-uuid/C41D-8325[0m...
[[0;32m OK [0m] Found device [0;1;39mST2000DM008-2FR102 Linux[0m.
Mounting [0;1;39m/mnt/hdd[0m...
[[0;32m OK [0m] Mounted [0;1;39m/mnt/hdd[0m.
[[0;32m OK [0m] Finished [0;1;39mFile System Check on /dev/disk/by-uuid/C41D-8325[0m.
[[0;32m OK [0m] Listening on [0;1;39mLoad/Save RF …itch Status /dev/rfkill Watch[0m.
Mounting [0;1;39m/boot/efi[0m...
[[0;32m OK [0m] Mounted [0;1;39m/boot/efi[0m.
[[0;32m OK [0m] Reached target [0;1;39mLocal File Systems[0m.
Starting [0;1;39mTell Plymouth To Write Out Runtime Data[0m...
Starting [0;1;39mSet Up Additional Binary Formats[0m...
Starting [0;1;39mCreate Volatile Files and Directories[0m...
------------ Sun Jun 12 21:07:58 CEST 2022 ------------
/dev/nvme0n1p3: clean, 662546/30531584 files, 11074062/122095104 blocks
------------ Sun Jun 12 21:37:48 CEST 2022 ------------
%G/dev/nvme0n1p3: clean, 662552/30531584 files, 11087767/122095104 blocks
------------ Sun Jun 12 23:05:25 CEST 2022 ------------
/dev/nvme0n1p3: clean, 662562/30531584 files, 11097378/122095104 blocks
