Using kernel 5.15.7-1-MANJARO
iotop shows an error
CONFIG_TASK_DELAY_ACCT not enabled in kernel, cannot determine SWAPIN and IO %
now showing SWAPIN column unavailable.
The iotop admin fixed the issue here: CONFIG_TASK_DELAY_ACCT error in “iotop” kernel 5.14 · Issue #21 · Tomas-M/iotop · GitHub
But package in official Manjare repository is one year outdated:
Version : 0.6-8
Description : View I/O usage of processes
URL : Iotop's homepage
Licenses : GPL
Repository : community
Installed Size : 159,8 kB
Depends On : python
Packager : Evangelos Foutras
Build Date : 12.11.2020
Install Date : 2.1.2021
Install Reason : Explicitly installed
Signatures : Yes
@foutrelis
There is same topic which suggest some workaround that i do not know if is good idea to apply. https://superuser.com/questions/610581/iotop-complains-config-task-delay-acct-not-enabled-in-kernel-only-for-specific possibly better to wait for udpated iotop in MJ repo?
