Fresh install of Manjaro i3 Community Edition
I did the standard flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
without any errors, but when I try to do something like flatpak search simplenote
, I get:
$ flatpak search simplenote
(flatpak search:19164): GLib-GIO-ERROR **: 16:00:16.138: No GSettings schemas are installed on the system
Trace/breakpoint trap (core dumped)
Here’s my XDG variables:
$ set |grep ^XDG
XDG_CONFIG_HOME=/home/ram/.config
XDG_CURRENT_DESKTOP=i3
XDG_DATA_DIRS=/home/ram/.local/share/flatpak/exports/share:/var/lib/flatpak/exports/share:
XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/ram
XDG_RUNTIME_DIR=/run/user/1000
XDG_SEAT=seat0
XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
XDG_SESSION_CLASS=user
XDG_SESSION_DESKTOP=i3
XDG_SESSION_ID=8
XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session2
XDG_SESSION_TYPE=x11
XDG_VTNR=7
Here’s some basic system information:
inxi -Fxxxza --no-host
$ inxi -Fxxxza --no-host
System: Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64 root=UUID=954cf137-75f3-4e46-8682-9f013e1bd856 rw quiet
cryptdevice=UUID=4110f216-65f4-48f0-8bbe-81a930fc1c74:luks-4110f216-65f4-48f0-8bbe-81a930fc1c74
root=/dev/mapper/luks-4110f216-65f4-48f0-8bbe-81a930fc1c74 apparmor=1 security=apparmor
resume=/dev/mapper/luks-c6d6abb3-a33a-4e43-b48c-c6131a7cb028 udev.log_priority=3
Desktop: i3 4.19.1 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Portable System: Dell product: Inspiron 5720 v: N/A serial: <filter> Chassis: type: 8 v: 0.1 serial: <filter>
Mobo: Dell model: 023HTX v: FAB1 serial: <filter> UEFI [Legacy]: Dell v: A03 date: 05/04/2012
Battery: ID-1: BAT0 charge: 32.8 Wh condition: 32.8/48.8 Wh (67%) volts: 12.4/11.1 model: SANYO Dell type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325 serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: Discharging
CPU: Info: Quad Core model: Intel Core i7-3612QM bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 L2 cache: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33536
Speed: 1197 MHz min/max: 1200/3100 MHz Core speeds (MHz): 1: 1197 2: 1196 3: 1197 4: 1197 5: 1198 6: 1198 7: 1198
8: 1197
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0166 class ID: 0300
Device-2: Microdia Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-1.5:4 chip ID: 0c45:648d
class ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 930x285mm (36.6x11.2") s-diag: 973mm (38.3")
Monitor-1: LVDS1 res: 1600x900 hz: 60 dpi: 107 size: 380x220mm (15.0x8.7") diag: 439mm (17.3")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1e20 class ID: 0403
Sound Server: ALSA v: k5.11.2-1-MANJARO
Network: Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel port: efa0 bus ID: 01:00.0 chip ID: 8086:0887
class ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: 2000
bus ID: 02:00.0 chip ID: 10ec:8136 class ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB driver: btusb v: 0.8 bus ID: 2-1.5:3
chip ID: 8087:07da class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 931.51 GiB used: 299.05 GiB (32.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1 size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 030 scheme: MBR
Partition: ID-1: / raw size: 922.71 GiB size: 907.23 GiB (98.32%) used: 299.05 GiB (33.0%) fs: ext4 dev: /dev/dm-0
maj-min: 254:0 mapped: luks-4110f216-65f4-48f0-8bbe-81a930fc1c74
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-c6d6abb3-a33a-4e43-b48c-c6131a7cb028
Sensors: System Temperatures: cpu: 51.0 C mobo: 40.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Info: Processes: 242 Uptime: 3h 34m wakeups: 20 Memory: 7.64 GiB used: 2.67 GiB (34.9%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1135 lib: 325 flatpak: 0 Shell: Bash v: 5.1.0 running in: lxterminal inxi: 3.3.01
Full package list
$ pacman -Q
a52dec 0.7.4-11
aalib 1.4rc5-14
accountsservice 0.6.55-3
acl 2.2.53-3
acpi 1.7-3
acpid 2.0.32-2
adapta-maia-theme 3.94.0.149-2
adobe-source-code-pro-fonts 2.038ro+1.058it+1.018var-1
adwaita-icon-theme 3.38.0-1
alsa-card-profiles 1:0.3.22-2
alsa-firmware 1.2.4-2
alsa-lib 1.2.4-3
alsa-oss 1.1.8-3
alsa-plugins 1:1.2.2-2
alsa-topology-conf 1.2.4-2
alsa-ucm-conf 1.2.4-2
alsa-utils 1.2.4-2
aom 2.0.2-1
apparmor 3.0.1-1
appstream-glib 0.7.18-2
apr 1.7.0-3
apr-util 1.6.1-8
arandr 0.1.10-5
archlinux-appstream-data 20210218-1
archlinux-keyring 20210110-1
argon2 20190702-3
artwork-i3 20190912-1
asciidoc 9.1.0-1
at-spi2-atk 2.38.0-1
at-spi2-core 2.38.0-1
atk 2.36.0-1
atkmm 2.28.1-1
atool 0.39.0-7
attr 2.4.48-3
audit 3.0-1
autoconf 2.71-1
automake 1.16.3-1
avahi 0.8+15+ge8a3dd0-3
b43-fwcutter 019-3
babl 0.1.84-1
bash 5.1.0-2
bash-completion 2.11-1
bashrc-manjaro 5.1.0-2
bauh 0.9.14-1
bc 1.07.1-4
binutils 2.36.1-2
bison 3.7.3-1
blas 3.9.0-3
blueman 2.1.4-1
bluez 5.56-1
bluez-libs 5.56-1
bluez-utils 5.56-1
bmenu 0.14-1
bmon 4.0-4
boost-libs 1.75.0-2
brotli 1.0.9-4
btrfs-progs 5.10.1-2
bubblewrap 0.4.1-1
bzip2 1.0.8-4
ca-certificates 20181109-4
ca-certificates-mozilla 3.62-1
ca-certificates-utils 20181109-4
cairo 1.17.4-3
cairomm 1.12.2-4
cantarell-fonts 1:0.301-1
cdparanoia 10.2-8
chromaprint 1.5.0-3
cifs-utils 6.12-1
ckbcomp 1.194-1
clipit 1:1.4.3-2
clucene 2.3.3.4-11
cmus 2.8.0-5
colord 1.4.5-1
colord-sane 1.4.5-1
confuse 3.3-3
conky 1.11.6-1
conky-i3 20180507-1
coreutils 8.32-1
cpupower 5.11-1
crda 4.14-3
cronie 1.5.5-2
cryptsetup 2.3.4-2
cups 1:2.3.3op2-1
cups-filters 1.28.7-1
cups-pdf 3.0.1-5
cups-pk-helper 0.2.6-4
curl 7.75.0-1
dav1d 0.8.1-2
db 5.3.28-5
dbus 1.12.20-1
dbus-glib 0.110-2
dconf 0.38.0-1
deluge 2.0.4.dev38+g23a48dd01-3
desktop-file-utils 0.26-1
device-mapper 2.03.11-5
dfc 3.1.1-3
dhclient 4.4.2-2
dhcpcd 9.4.0-1
diffutils 3.7-3
ding-libs 0.6.1-3
dmenu-manjaro 5.0-2
dmidecode 3.3-1
dmraid 1.0.0.rc16.3-13
dnsmasq 2.84-1
dnssec-anchors 20190629-3
docbook-xml 4.5-9
docbook-xsl 1.79.2-7
dosfstools 4.1-3.0
double-conversion 3.1.5-2
downgrade 9.0.0-2
dropbox 116.4.368-1
dunst 1.5.0-1.0
dunstify 1.5.0-1.0
e2fsprogs 1.46.1-1
ecryptfs-utils 111-4
efibootmgr 17-2
efivar 37-4
elfutils 0.183-3
enchant 2.2.15-1
epdfview 0.1.8-11
evolution-data-server 3.38.4-1
exfat-utils 1.3.0-2
exiv2 0.27.3-1
exo 4.16.0-1
expac 10-2
expat 2.2.10-2
f2fs-tools 1.14.0-1
faac 1.30-2
faad2 2.10.0-1
fakeroot 1.25.3-2
ffmpeg 2:4.3.1-4
ffmpegthumbnailer 2.2.2-2
fftw 3.3.9-1
file 5.39-1
filesystem 2021.01.19-1
findutils 4.8.0-1
firefox 86.0-2
flac 1.3.3-2
flatpak 1.10.1-1
flex 2.6.4-3
fluidsynth 2.1.7-1
folks 0.14-2
fontconfig 2:2.13.91+48+gfcb0420-2
foomatic-db 3:20210222-1
foomatic-db-engine 4:20200206-1
foomatic-db-gutenprint-ppds 5.3.4-1
freeglut 3.2.1-2
freetype2 2.10.4-1
fribidi 1.0.10-1
fuse-common 3.10.2-1
fuse2 2.9.9-4
fuse3 3.10.2-1
fzf 0.25.1-2
gawk 5.1.0-1
gc 8.0.4-4
gcab 1.4-1
gcc 10.2.0-6
gcc-libs 10.2.0-6
gcolor2 0.4-9
gcr 3.38.1-1
gd 2.3.1-1
gdbm 1.19-2
gdk-pixbuf2 2.42.2-1
geary 1:3.38.1-1
gegl 0.4.28-2
gendesk 1.0.8-1
geoclue 2.5.7-2
geocode-glib 3.26.2-1
geoip 1.6.12-2
geoip-database 20210223-1
gettext 0.21-1
ghostscript 9.53.3-3
giblib 1.2.4-8
giflib 5.2.1-2
gimp 2.10.22-2
git 2.30.1-1
glew 2.2.0-2
glib-networking 2.66.0-1
glib2 2.66.7-1
glibc 2.33-4
glibmm 2.66.0-1
glslang 11.2.0-1
glu 9.0.1-2
gmime3 3.2.7-1
gmp 6.2.1-1
gnome-desktop 1:3.38.4-1
gnome-keyring 1:3.36.0-3
gnome-online-accounts 3.38.0-1
gnupg 2.2.27-1
gnutls 3.7.0-1
gobject-introspection-runtime 1.66.1-3
gparted 1.2.0-2
gpgme 1.15.1-1
gpick 0.2.6rc1-10
gpm 1.20.7.r38.ge82d1a6-3
gptfdisk 1.0.6-1
graphene 1.10.4-1
graphite 1:1.3.14-1
graphviz 2.46.0-1
grep 3.6-1
groff 1.22.4-4
grub 2.04-19
grub-theme-manjaro-dev 18.0-3
gsettings-desktop-schemas 3.38.0-1
gsfonts 20200910-1
gsm 1.0.19-1
gsound 1.0.2-5
gspell 1.8.4-1
gssdp 1.2.3-1
gssproxy 0.8.4-1
gst-libav 1.18.3-1
gst-plugins-bad 1.18.3-2
gst-plugins-bad-libs 1.18.3-2
gst-plugins-base 1.18.3-1
gst-plugins-base-libs 1.18.3-1
gst-plugins-good 1.18.3-1
gst-plugins-ugly 1.18.3-1
gstreamer 1.18.3-1
gtk-engine-murrine 0.98.2-4
gtk-engines 2.21.0-5
gtk-update-icon-cache 1:4.0.3-1
gtk2 2.24.33-1
gtk3 1:3.24.26-1
gtkmm 1:2.24.5-4
gtkmm3 3.24.4-1
gtksourceview-pkgbuild 4-2
gtksourceview3 3.24.11+28+g73e57b57-1
gts 0.7.6.121130-2
gufw 21.04.0-1
guile 2.2.6-2
gupnp 1.2.4-1
gupnp-igd 1.2.0-1
gutenprint 5.3.4-1
gvfs 1.46.2-1
gvfs-afc 1.46.2-1
gvfs-gphoto2 1.46.2-1
gvfs-mtp 1.46.2-1
gvfs-smb 1.46.2-1
gzip 1.10-3
harfbuzz 2.7.4-1
harfbuzz-icu 2.7.4-1
hdparm 9.60-1
hexchat 2.14.3-6
hicolor-icon-theme 0.17-2
hidapi 0.10.1-1
highlight 3.62-1
hplip 1:3.21.2-1
htop 3.0.5-1
hunspell 1.7.0-3
hwids 20201207-1
hwinfo 21.72-1
hwloc 2.4.0-1
hyphen 2.8.8-3
i3-default-artwork 20190912-1
i3-gaps 4.19.1-1
i3-help 20180110-1
i3-scripts 20200804-1
i3-scrot 2.1-1
i3exit 20201126-1
i3lock 2.13-1
i3status-manjaro 2.13-3
iana-etc 20210202-1
icu 68.2-1
iftop 1.0pre4-4
ijs 0.35-3
imagemagick 7.0.11.2-1
imlib2 1.7.1-1
inetutils 1.9.4-8
intel-ucode 20210216-1
inxi 3.3.01.1-1
iproute2 5.11.0-1
iptables 1:1.8.7-1
iputils 20200821-1
iso-codes 4.5.0-1
iw 5.9-1
jack 0.125.0-9
jansson 2.13.1-1
jasper 2.0.25-1
jbig2dec 0.19-1
jfsutils 1.1.15-7
js78 78.8.0-1
json-c 0.15-1
json-glib 1.6.2-1
kauth 5.79.0-1
kbd 2.4.0-2
kcoreaddons 5.79.0-1
keepassxc 2.6.4-1
keyutils 1.6.3-1
kitemmodels 5.79.0-1
kmod 28-1
krb5 1.18.3-1
kvantum-manjaro 0.13.5-1
kvantum-qt5 0.18.0-1
kwindowsystem 5.79.0-1
l-smash 2.14.5-2
lame 3.100-3
lapack 3.9.0-3
lcms2 2.12-1
ldb 1:2.2.0-3
ldns 1.7.1-2
lensfun 0.3.95-4
less 563-1
lib32-alsa-lib 1.2.4-2
lib32-alsa-oss 1.1.8-2
lib32-alsa-plugins 1.2.2-1
lib32-bzip2 1.0.8-2
lib32-curl 7.75.0-1
lib32-e2fsprogs 1.46.1-1
lib32-expat 2.2.10-1
lib32-flex 2.6.4-2
lib32-gcc-libs 10.2.0-6
lib32-glew 2.2.0-1
lib32-glibc 2.33-4
lib32-glu 9.0.1-1
lib32-icu 68.2-1
lib32-keyutils 1.6.3-1
lib32-krb5 1.18.3-1
lib32-libdrm 2.4.104-1
lib32-libelf 0.183-3
lib32-libffi 3.3-2
lib32-libglvnd 1.3.2-1
lib32-libice 1.0.10-1
lib32-libidn2 2.3.0-1
lib32-libldap 2.4.57-1
lib32-libpciaccess 0.16-1
lib32-libpsl 0.21.1-1
lib32-libsm 1.2.3-1
lib32-libssh2 1.9.0-1
lib32-libunistring 0.9.10-1
lib32-libunwind 1.5.0-1
lib32-libva 2.10.0-1
lib32-libva-vdpau-driver 0.7.4-6
lib32-libvdpau 1.4-1
lib32-libx11 1.7.0-1
lib32-libxau 1.0.9-1
lib32-libxcb 1.14-1
lib32-libxcrypt 4.4.18-1
lib32-libxdamage 1.1.5-1
lib32-libxdmcp 1.1.3-1
lib32-libxext 1.3.4-1
lib32-libxfixes 5.0.3-2
lib32-libxi 1.7.10-2
lib32-libxml2 2.9.10-3
lib32-libxmu 1.1.3-1
lib32-libxshmfence 1.3-2
lib32-libxt 1.2.1-1
lib32-libxxf86vm 1.1.4-2
lib32-llvm-libs 11.1.0-1
lib32-lm_sensors 1:3.6.0.r41.g31d1f125-1
lib32-lz4 1.9.3-1
lib32-mesa 20.3.4-3
lib32-mesa-demos 8.4.0-2
lib32-mesa-vdpau 20.3.4-3
lib32-ncurses 6.2-1
lib32-openssl 1:1.1.1.j-1
lib32-readline 8.1.0-2
lib32-util-linux 2.36.2-1
lib32-vulkan-intel 20.3.4-3
lib32-vulkan-radeon 20.3.4-3
lib32-wayland 1.19.0-1
lib32-xz 5.2.5-2
lib32-zlib 1.2.11-3
lib32-zstd 1.4.8-1
libabw 0.1.3-2
libaio 0.3.112-2
libappindicator-gtk2 12.10.0.r296-1
libappindicator-gtk3 12.10.0.r296-1
libarchive 3.5.1-1
libass 0.15.0-2
libassuan 2.5.4-2
libasyncns 0.8+3+g68cd5af-3
libatasmart 0.19-5
libatomic_ops 7.6.10-2
libavc1394 0.5.4-4
libavtp 0.1.0-2
libblockdev 2.25-2
libbluray 1.2.1-1
libbs2b 3.1.0-7
libbsd 0.10.0-2
libburn 1.5.4-1
libbytesize 2.5-1
libcaca 0.99.beta19-3
libcanberra 0.30+2+gc0620e4-3
libcap 2.48-1
libcap-ng 0.8.2-1
libcddb 1.3.2-6
libcdio 2.1.0-2
libcdio-paranoia 10.2+2.0.1-2
libcdr 0.1.6-3
libcloudproviders 0.3.1-2
libcmis 0.5.2-6
libconfig 1.7.2-3
libcroco 0.6.13-2
libcups 1:2.3.3op2-1
libdaemon 0.14-5
libdatrie 0.2.13-1
libdbusmenu-glib 16.04.0-4
libdbusmenu-gtk2 16.04.0-4
libdbusmenu-gtk3 16.04.0-4
libdc1394 2.2.6-2
libdca 0.0.7-1
libde265 1.0.8-1
libdiscid 0.6.2-3
libdrm 2.4.104-1
libdv 1.0.0-9
libdvbpsi 1:1.3.3-2
libdvdcss 1.4.2-2
libdvdnav 6.1.0-2
libdvdread 6.1.1-1
libe-book 0.1.3-8
libebml 1.4.1-1
libedit 20191231_3.1-3
libelf 0.183-3
libepoxy 1.5.5-1
libepubgen 0.1.1-2
libetonyek 0.1.9-2
libev 4.33-1
libevdev 1.11.0-1
libevent 2.1.12-1
libexif 0.6.22-1
libexttextcat 3.4.5-2
libfdk-aac 2.0.1-2
libffi 3.3-4
libfm 1.3.2-1
libfm-extra 1.3.2-1
libfm-gtk2 1.3.2-1
libfontenc 1.1.4-3
libfreehand 0.1.2-3
libgcrypt 1.9.2-1
libgdata 0.18.0-1
libgee 0.20.3-2
libgexiv2 0.12.2-1
libglvnd 1.3.2-1
libgme 0.6.3-1
libgpg-error 1.41-1
libgphoto2 2.5.27-1
libgpod 0.8.3-11
libgtop 2.40.0+2+g31db82ef-2
libgudev 234-1
libgusb 0.3.5-1
libgweather 3.36.1-1.1
libhandy 1.0.3-1
libheif 1.11.0-1
libibus 1.5.24-1
libical 3.0.9-1
libice 1.0.10-3
libid3tag 0.15.1b-11
libidn 1.36-1
libidn2 2.3.0-1
libiec61883 1.2.0-6
libieee1284 0.2.11-11
libimagequant 2.14.1-1
libimobiledevice 1.3.0-3
libindicator-gtk2 12.10.1-9
libindicator-gtk3 12.10.1-9
libinih 52-2
libinput 1.17.0-1
libinstpatch 1.1.6-1
libisofs 1.5.4-1
libixion 0.16.1-5
libjpeg-turbo 2.0.6-1
libkate 0.4.1-7
libksba 1.4.0-2
liblangtag 0.6.3-2
libldac 2.0.2.3-1
libldap 2.4.57-1
liblouis 3.16.0-1
liblqr 0.4.2-3
liblrdf 0.6.1-4
libmad 0.15.1b-9
libmatroska 1.6.2-1
libmbim 1.24.6-1
libmediainfo 20.09-1
libmfx 20.5.1-1
libmicrodns 0.2.0-1
libmicrohttpd 0.9.72-1
libmm-glib 1.16.0-1
libmms 0.6.4-3
libmng 2.0.3-3
libmnl 1.0.4-3
libmodplug 0.8.9.0-3
libmpc 1.2.1-1
libmpcdec 1:0.1+r475-3
libmpeg2 0.5.1-7
libmspub 0.1.4-9
libmtp 1.1.18-1
libmwaw 0.3.17-1
libmypaint 1.5.1-2
libndp 1.7-2
libnet 1:1.1.6-1
libnetfilter_conntrack 1.0.8-1
libnewt 0.52.21-5
libnfnetlink 1.0.1-4
libnftnl 1.1.9-1
libnghttp2 1.41.0-1
libnice 0.1.18-1
libnl 3.5.0-2
libnm 1.30.0-2
libnma 1.8.30-1
libnotify 0.7.9-1
libnsl 1.3.0-1
libnumbertext 1.0.7-1
libodfgen 0.1.8-1
libofa 0.9.3-9
libogg 1.3.4-2
libomxil-bellagio 0.9.3-3
libopenaptx 0.2.0-1
liborcus 0.16.1-5
libp11-kit 0.23.22-1
libpagemaker 0.0.4-2
libpaper 1.1.28-1
libpcap 1.10.0-1
libpciaccess 0.16-2
libpeas 1.28.0-3
libpgm 5.3.128-1
libphonenumber 8.12.14-3
libpipeline 1.5.3-1
libplacebo 3.104.0-2
libplist 2.2.0-3
libpng 1.6.37-3
libproxy 0.4.17-1
libpsl 0.21.1-1
libpulse 14.2-2
libqmi 1.28.0-1
libqrtr-glib 1.0.0-1
libqxp 0.0.2-5
libraqm 0.7.1-1
libraw 0.20.2-1
libraw1394 2.1.2-3
libreoffice-still 7.0.4-2
librevenge 0.0.4-3
librsvg 2:2.50.3-1
libsamplerate 0.2.1-1
libsasl 2.1.27-3
libseccomp 2.5.1-2
libsecret 0.20.4-1
libshout 1:2.4.5-1
libsidplay 1.36.59-10
libsigc++ 2.10.6-1
libsigsegv 2.13-1
libsm 1.2.3-2
libsndfile 1.0.31-1
libsodium 1.0.18-2
libsoup 2.72.0+5+g0b094bff-3
libsoxr 0.1.3-2
libspiro 1:20200505-2
libsrtp 1:2.3.0-1
libssh 0.9.5-1
libssh2 1.9.0-2
libstaroffice 0.0.7-1
libstemmer 0+713-2
libsynctex 2020.54586-11
libtar 1.2.20-5
libtasn1 4.16.0-1
libteam 1.31-2
libthai 0.1.28-2
libtheora 1.1.1-5
libtiff 4.2.0-1
libtirpc 1.3.1-1
libtommath 1.2.0-3
libtool 2.4.6+42+gb88cebd5-14
libtorrent-rasterbar 1:1.2.11-1
libunistring 0.9.10-3
libunwind 1.5.0-1
libupnp 1.14.2-1
libusb 1.0.24-2
libusbmuxd 2.0.2-1
libutempter 1.2.1-1
libutf8proc 2.6.1-1
libva 2.10.0-1
libva-mesa-driver 20.3.4-3
libva-vdpau-driver 0.7.4-5
libvdpau 1.4-1
libvisio 0.1.7-4
libvisual 0.4.0-8
libvncserver 0.9.13-1
libvorbis 1.3.7-2
libvpx 1.9.0-1
libwacom 1.9-1
libwebp 1.2.0-1
libwmf 0.2.12-2
libwpd 0.10.3-2
libwpe 1.8.0-1
libwpg 0.3.3-2
libwps 0.4.12-1
libx11 1.7.0-3
libx86emu 3.1-1
libxau 1.0.9-3
libxaw 1.0.13-3
libxcb 1.14-1
libxcomposite 0.4.5-3
libxcrypt 4.4.18-1
libxcursor 1.2.0-2
libxdamage 1.1.5-3
libxdg-basedir 1.2.0-5
libxdmcp 1.1.3-3
libxext 1.3.4-3
libxfce4ui 4.16.0-1
libxfce4util 4.16.0-1
libxfixes 5.0.3-4
libxfont2 2.0.4-3
libxft 2.3.3-2
libxi 1.7.10-3
libxinerama 1.1.4-3
libxkbcommon 1.1.0-1
libxkbcommon-x11 1.1.0-1
libxkbfile 1.1.0-2
libxklavier 5.4-3
libxml2 2.9.10-8
libxmu 1.1.3-2
libxnvctrl 460.56-1
libxpm 3.5.13-2
libxrandr 1.5.2-3
libxrender 0.9.10-4
libxshmfence 1.3-2
libxslt 1.1.34-5
libxss 1.2.3-3
libxt 1.2.1-1
libxtst 1.2.3-4
libxv 1.0.11-4
libxvmc 1.0.12-3
libxxf86vm 1.1.4-4
libyaml 0.2.5-1
libytnef 1.9.3+7+g24fe30e-2
libzen 0.4.38-2
libzip 1.7.3-2
libzmf 0.0.2-9
licenses 20200427-1
lightdm 1:1.30.0-4
lightdm-settings 1.5.2-1
lightdm-slick-greeter 1.5.2-1
lilv 0.24.12-1
links 2.21-1
linux-api-headers 5.10.13-1
linux-firmware 20210211.r1830.f7915a0-1
linux511 5.11.2-1
linux59 5.9.16-1
llvm-libs 11.1.0-1
lmdb 0.9.28-1
logrotate 3.18.0-1
lpsolve 5.5.2.5-4
lsb-release 1.4-13
lshw B.02.19.2-1
lsof 4.94.0-1
lua 5.4.2-1
lua52 5.2.4-5
luajit 2.0.5-3
luit 20201003-1
lvm2 2.03.11-5
lxappearance 0.6.3-4
lxinput 0.3.5-3
lxmenu-data 0.1.5-3
lxterminal 0.4.0-1
lz4 1:1.9.3-1
lzo 2.10-3
m4 1.4.18-3
maia-console 1.2-6
mailcap 2.1.49-1
make 4.3-3
man-db 2.9.4-1
man-pages 5.10-1
manjaro-alsa 20210109-1
manjaro-application-utility 1.3.3-4.1
manjaro-base-skel 20171029-3
manjaro-browser-settings 20201114-1
manjaro-firmware 20160419-1
manjaro-hello 0.6.6-4
manjaro-hotfixes 2018.08-6
manjaro-i3-settings 20200919-1
manjaro-icons 20191015-1
manjaro-keyring 20201216-1
manjaro-printer 20200215-2
manjaro-ranger-settings 20190513-2
manjaro-release 20.2.1-1
manjaro-settings-manager 0.5.6-11
manjaro-settings-manager-notifier 0.5.6-11
manjaro-system 20210302-1
manjaro-zsh-config 0.20-3
markdown_previewer 0.r6.64ad4d7-1
matcha-gtk-theme 20210204-1
md4c 0.4.7-1
mdadm 4.1-2
mediainfo 20.09-1
memtest86+ 5.01-4
menu-cache 1.1.0-2
mesa 20.3.4-3
mesa-demos 8.4.0-4
mesa-vdpau 20.3.4-3
metis 5.1.0.p10-1
mhwd 0.6.5-2
mhwd-amdgpu 19.1.0-1
mhwd-ati 19.1.0-1
mhwd-db 0.6.5-7
mhwd-nvidia 460.56-1
mhwd-nvidia-340xx 340.108-1
mhwd-nvidia-390xx 390.141-1
mjpegtools 2.2.0beta-1
mkinitcpio 29-1.0
mkinitcpio-busybox 1.32.1-2
mkinitcpio-openswap 0.1.0-3
mlocate 0.26.git.20170220-5
mobile-broadband-provider-info 20201225-1
moc 1:2.5.2-3
modemmanager 1.16.0-1
morc_menu 1.0-2
mousepad 0.5.3-1
mpfr 4.1.0-1
mpg123 1.26.3-2
mtdev 1.1.6-1
mypaint-brushes1 1.3.1-1
ncdu 1.15.1-2
ncurses 6.2-1
ndctl 71.1-1
neon 0.31.2-1
nerd-fonts-noto-sans-mono 2.0.0-1
nerd-fonts-terminus 2.1.0-4
net-snmp 5.9-3
netctl 1.24-1
nethogs 0.8.6-1
netpbm 10.73.33-1
nettle 3.7.1-1
network-manager-applet 1.20.0-2
networkmanager 1.30.0-2
networkmanager-openconnect 1.2.7dev+49+gc512d5a-1
networkmanager-openvpn 1.8.12-1
networkmanager-pptp 1.2.9dev+10+gb41b0d0-3
networkmanager-vpnc 1.2.7dev+20+gdca3aea-2
nfs-utils 2.5.3-1
nfsidmap 2.5.3-1
nitrogen 1.6.1-3
nm-connection-editor 1.20.0-2
noto-fonts 20201226-1
npth 1.6-3
nspr 4.29-1
nss 3.62-1
nss-mdns 0.14.1-3
ntfs-3g 2017.3.23-5
ntp 4.2.8.p15-1
oniguruma 6.9.6-1
openal 1.21.1-1
openconnect 1:8.10-1
opencore-amr 0.1.5-5
openexr 2.5.5-1
openjpeg2 2.4.0-1
openmpi 4.0.5-2
openresolv 3.12.0-1
openssh 8.4p1-2
openssl 1.1.1.j-1
openvpn 2.5.1-1
opus 1.3.1-2
orc 0.4.32-1
os-prober 1.77-1
ostree 2020.8-1
p11-kit 0.23.22-1
p7zip 17.03-2
pacman 5.2.2-4
pacman-mirrors 4.19.1-1
pacui 1.14-1
pam 1.5.1-1
pamac-cli 10.0.5-0.2
pamac-common 10.0.5-0.2
pamac-gtk 10.0.5-0.2
pambase 20200721.1-2
pango 1:1.48.2-1
pangomm 2.46.0-1
papirus-icon-theme 20210302-1
papirus-maia-icon-theme 20200702-1
parted 3.4-2
patch 2.7.6-8
patchutils 0.4.2-1
pciutils 3.7.0-1
pcmanfm 1.3.1-2.1
pcre 8.44-1
pcre2 10.36-1
pcsclite 1.9.0-1
perl 5.32.1-1
perl-alien-build 2.38-1
perl-alien-libxml2 0.17-1
perl-capture-tiny 0.48-4
perl-clone 0.45-2
perl-dbi 1.643-2
perl-encode-locale 1.05-7
perl-error 0.17029-2
perl-ffi-checklib 0.27-2
perl-file-basedir 0.08-5
perl-file-chdir 0.1011-4
perl-file-desktopentry 0.22-7
perl-file-listing 6.14-1
perl-file-mimeinfo 0.30-1
perl-file-which 1.23-4
perl-html-parser 3.75-1
perl-html-tagset 3.20-10
perl-http-cookies 6.10-1
perl-http-daemon 6.06-2
perl-http-date 6.05-3
perl-http-message 6.28-1
perl-http-negotiate 6.01-8
perl-image-exiftool 12.16-1
perl-io-html 1.004-1
perl-ipc-system-simple 1.30-2
perl-libwww 6.52-1
perl-lwp-mediatypes 6.02-8
perl-mailtools 2.21-4
perl-net-http 6.20-1
perl-path-tiny 0.118-1
perl-timedate 2.33-2
perl-try-tiny 0.30-5
perl-uri 5.08-1
perl-www-robotrules 6.02-8
perl-xml-libxml 2.0206-1
perl-xml-namespacesupport 1.12-4
perl-xml-parser 2.46-2
perl-xml-sax 1.02-1
perl-xml-sax-base 1.09-4
perl-xml-writer 0.625-6
php 8.0.2-1
picom 8.2-1
pinentry 1.1.0-5
pipewire 1:0.3.22-2
pixman 0.40.0-1
pkcs11-helper 1.27.0-1
pkgconf 1.7.3-1
pkgfile 21-2
polkit 0.118-1
polkit-gnome 0.105-5
polkit-qt5 0.113.0-2
poppler 21.03.0-1
poppler-data 0.4.10-1
poppler-glib 21.03.0-1
poppler-qt5 21.03.0-1
popt 1.18-1
portaudio 1:19.6.0-7
potrace 1.16-2
powertop 2.13-1
ppp 2.4.8-1
pptpclient 1.10.0-2
procps-ng 3.3.17-1
protobuf 3.12.4-3
psmisc 23.4-1
python 3.9.2-1
python-appdirs 1.4.4-3
python-asn1crypto 1.4.0-3
python-attrs 20.3.0-3
python-automat 20.2.0-5
python-beaker 1.11.0-6
python-cachecontrol 0.12.6-3
python-cairo 1.20.0-3
python-cffi 1.14.5-1
python-chardet 3.0.4-7
python-click 7.1.2-3
python-colorama 0.4.4-3
python-configargparse 1.2.3-3
python-constantly 15.1.0-8
python-contextlib2 0.6.0.post1-3
python-cryptography 3.4.6-1
python-dateutil 2.8.1-5
python-dbus 1.2.16-3
python-dbus-common 1.2.16-3
python-distlib 0.3.1-2
python-distro 1.5.0-3
python-docopt 0.6.2-9
python-geoip 1.3.2-10
python-gobject 3.38.0-3
python-html5lib 1.1-5
python-hyperlink 21.0.0-1
python-idna 2.10-3
python-incremental 17.5.0-6
python-mako 1.1.4-1
python-markupsafe 1.1.1-7
python-msgpack 1.0.2-2
python-npyscreen 4.10.5-5
python-ordered-set 4.0.2-3
python-packaging 20.9-1
python-pep517 0.9.1-3
python-pillow 8.1.0-1
python-pip 20.3.1-1
python-ply 3.11-7
python-progress 1.5-5
python-psutil 5.8.0-1
python-pyaml 20.4.0-4
python-pyasn1 0.4.8-4
python-pyasn1-modules 0.2.8-3
python-pycparser 2.20-3
python-pyhamcrest 1.9.0-7
python-pyopenssl 20.0.1-1
python-pyparsing 2.4.7-3
python-pyqt5 5.15.3-2
python-pyqt5-sip 12.8.1-3
python-pysmbc 1.0.23-2
python-pyxdg 0.26-8
python-rencode 1.0.6-5
python-reportlab 3.5.60-1
python-requests 2.25.1-1
python-resolvelib 0.5.4-1
python-retrying 1.3.3-9
python-service-identity 18.1.0-6
python-setproctitle 1.2.2-1
python-setuptools 1:53.1.0-1
python-six 1.15.0-3
python-toml 0.10.2-3
python-twisted 20.3.0-3
python-urllib3 1.26.3-1
python-webencodings 0.5.1-6
python-xapp 2.0.2-2
python-xlib 0.29-1
python-yaml 5.3.1-4
python-zope-interface 5.2.0-3
qpdf 10.2.0-1
qpdfview 0.4.18-2
qrencode 4.1.1-1
qt5-base 5.15.2-3
qt5-styleplugins 5.0.0.20170311-25
qt5-svg 5.15.2-1
qt5-x11extras 5.15.2-1
qt5ct 1.1-1
quazip 1.1-1
ranger 1.9.3.143.g5047d9e5-1
raptor 2.0.15-15
rasqal 1:0.9.33-4
rav1e 0.4.0-1
readline 8.1.0-2
redland 1:1.0.17-8
reiserfsprogs 3.6.27-3
remmina 1:1.4.12-1
rest 0.8.1-3
rofi 1.6.1-1
rofimoji 5.0.0-1
rpcbind 1.2.5-3
rsync 3.2.3-3
rtkit 0.13-1
rtmpdump 1:2.4.r96.fa8646d-6
run-parts 4.8.6.1-2
rxvt-unicode 9.22-10
rxvt-unicode-terminfo 9.22-10
s-nail 14.9.21-1
sane 1.0.32-3
sbc 1.5-2
sbxkb 0.7.6-5
screenfetch 3.9.1-1
scrot 1.5-1
sdl 1.2.15-14
sdl2 2.0.14-1
sed 4.8-1
serd 0.30.10-1
serf 1.3.9-5
sg3_utils 1.45-1
shaderc 2020.3-2
shadow 4.8.1-4
shared-mime-info 2.0+57+gc1d1c70-1
slang 2.3.2-2
smbclient 4.13.4-1
sord 0.16.8-1
sound-theme-freedesktop 0.8-4
soundtouch 2.2-1
spandsp 0.0.6-3
spectre-meltdown-checker 0.43-1
speedtest-cli 2.1.2-3
speex 1.2.0-3
speexdsp 1.2.0-2
spirv-tools 2020.6-1
splix 2.0.0-15
sqlite 3.34.1-1
sratom 0.6.8-1
srt 1.4.2-1
startup-notification 0.12-7
stoken 0.92-4
subversion 1.14.1-1
sudo 1.9.5.p2-1
suitesparse 5.8.1-1
svt-hevc 1.5.0-1
syncthing 1.13.1-1
sysfsutils 2.1.0-11
syslog-ng 3.30.1-1
systemd 247.3-1
systemd-fsck-silent 239-1
systemd-libs 247.3-1
systemd-sysvcompat 247.3-1
t1lib 5.1.2-8
taglib 1.12-1
talloc 2.3.2-1
tar 1.34-1
tbb 2020.3-1
tdb 1.4.3-4
telepathy-glib 0.24.2-2
terminus-font 4.49.1-1
tevent 1:0.10.2-3
texinfo 6.7-3
texlive-bin 2020.54586-11
thin-provisioning-tools 0.9.0-1
tlp 1.3.1-2
tracker3 3.0.3-1
tree 1.8.0-2
tslib 1.22-1
ttf-bitstream-vera 1.10-14
ttf-dejavu 2.37+18+g9b5d1b2f-2
ttf-droid 20121017-9
ttf-font-icons 1.1-5
ttf-inconsolata 1:3.000-2
ttf-indic-otf 0.2-11
ttf-liberation 2.1.3-1
twolame 0.4.0-2
tzdata 2021a-1
udisks2 2.9.2-1
ueberzug 18.1.9-2
ufw 0.36-5
upower 0.99.11-3
urxvt-perls 2.3-1
usbmuxd 1.1.1-1
usbutils 013-1
util-linux 2.36.2-1
util-linux-libs 2.36.2-1
v4l-utils 1.20.0-1
v86d 0.1.10-5.1
vertex-maia-themes 20180519-4
vi 1:070224-4
vibrancy-icons-teal 2.7-1
vid.stab 1.1-3
viewnior 1.7-3
vim 8.2.2489-1
vim-runtime 8.2.2489-1
vlc 3.0.12-1
vmaf 1.5.3-1
volume_key 0.3.12-5
volumeicon 0.5.1-5
vpnc 1:0.5.3.r468.r81-2
vte-common 0.62.3-1
vte3 0.62.3-1
vulkan-icd-loader 1.2.169-1
w3m 0.5.3.git20200507-2
wallpapers-juhraya 1.1-2
wavpack 5.4.0-1
wayland 1.19.0-1
wayland-protocols 1.20-1
web-installer-url-handler 1.0.2-1
webkit2gtk 2.30.5-1
webrtc-audio-processing 0.3.1-2
wget 1.21.1-1
which 2.21-5
wildmidi 0.4.3-3
wireless-regdb 2020.11.20-1
wireless_tools 30.pre9-3
wmutils 1:1.4-1
woff2 1.0.2-3
wpa_supplicant 2:2.9-8
wpebackend-fdo 1.8.0-1
x11vnc 1:0.9.16-4
x264 3:0.160.r3011.cde9a93-1
x265 3.4-1
xarchiver 0.5.4.17-1
xautolock 2.2-6
xbitmaps 1.1.2-2
xcb-proto 1.14.1-3
xcb-util 0.4.0-3
xcb-util-cursor 0.1.3-3
xcb-util-image 0.4.0-3
xcb-util-keysyms 0.4.0-3
xcb-util-renderutil 0.3.9-3
xcb-util-wm 0.4.1-3
xcb-util-xrm 1.3-2
xcursor-breeze 5.11.5-1
xcursor-chameleon-pearl 0.5-5
xcursor-maia 20160417-2
xdg-dbus-proxy 0.1.2-2
xdg-desktop-portal 1.8.0-1
xdg-desktop-portal-gtk 1.8.0-1
xdg-user-dirs 0.17-3
xdg-utils 1.1.3+19+g9816ebb-1
xdotool 3.20160805.1-3
xf86-input-elographics 1.4.2-2
xf86-input-evdev 2.10.6-2
xf86-input-libinput 0.30.0-1
xf86-input-void 1.4.1-5
xf86-video-amdgpu 19.1.0-2
xf86-video-ati 1:19.1.0-2
xf86-video-intel 1:2.99.917+916+g31486f40-1
xf86-video-nouveau 1.0.17-1
xfburn 0.6.2-1
xfce4-notifyd 0.6.2-2
xfce4-power-manager 4.16.0-2
xfconf 4.16.0-1
xfsprogs 5.10.0-2
xkeyboard-config 2.32-1
xmlsec 1.2.31-1
xorg-fonts-alias-misc 1.0.4-1
xorg-fonts-encodings 1.0.5-2
xorg-fonts-misc 1.0.3-10
xorg-mkfontscale 1.2.1-2
xorg-server 1.20.10-3
xorg-server-common 1.20.10-3
xorg-setxkbmap 1.3.2-2
xorg-twm 1.0.11-1
xorg-xauth 1.1-2
xorg-xdpyinfo 1.3.2-4
xorg-xhost 1.0.8-2
xorg-xinit 1.4.1-3
xorg-xinput 1.6.3-2
xorg-xkbcomp 1.4.4-1
xorg-xkill 1.0.5-2
xorg-xmodmap 1.0.10-2
xorg-xprop 1.2.5-1
xorg-xrandr 1.5.1-2
xorg-xrdb 1.2.0-2
xorg-xset 1.2.4-2
xorgproto 2020.1-1
xournalpp 1.0.20-2
xsel 1.2.0.20190821-1
xterm 366-1
xvidcore 1.3.7-2
xxhash 0.8.0-1
xz 5.2.5-1
yajl 2.1.0-4
yay 10.1.2-3
yubico-c 1.13-6
yubico-c-client 2.15-5
yubikey-personalization 1.20.0-3
zbar 0.23.1-6
zenity 3.32.0+55+gd7bedff-1
zensu 0.3-1
zeromq 4.3.3-2
zita-alsa-pcmi 0.3.2-3
zita-resampler 1.8.0-1
zlib 1:1.2.11-4
zsh 5.8-1
zsh-autosuggestions 0.6.4-1
zsh-completions 0.32.0-1
zsh-history-substring-search 1.0.2-1
zsh-syntax-highlighting 0.7.1-1
zsh-theme-powerlevel10k 1.14.6-1
zstd 1.4.8-1
zvbi 0.2.35-4
zxing-cpp 1.1.1-1
zziplib 0.13.72-1
