I was trying to install on my laptop, the hard drive on the laptop does not have anything else installed on it. I got an error: failed to unpack image /run/miso/bootmnt/manjaro/x86_64/desktop.sfs.
I do not know what might be causing the error.
Laptop specs:
lenovo ideapad 130-15IKB
x86_64bit
1TB hard drive
8GB ram
Please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
