I want to replace the default dmenu in my manjaro i3 with rofi. I installed it and it worked fine. Now I downloaded an AppImage and created a symlink in /usr/local/bin. The issue is that dmenu find the symlink but rofi (rofi -show drun) not. Has anyone an idea why rofi doesn’t find the symlink?
rofi -show drun shows .desktop files of installed applications, not executable files, like the one you mention in /usr/local/bin.
You can either create a .desktop file for the said application in the ~/.local/share/applications directory (see the Arch Wiki for more information), or try using the command rofi -show run.
