For a little over a year now, I’ve been trying to play the Vergil DLC for Devil May Cry 5 on steam. I’ve used multiple versions of Proton, and even been able to play the base game perfectly. The game would crash midway through the loading screen (where I assume the game would normally be finished loading and have started playing said cutscene). It was suggested to me that the game might be trying to load it using the integrated graphics on my motherboard, and running out of vram, and I’ve set up prime offloading but I can’t tell if it’s actually working. I’ve talked about this on the official github for proton and another user had mentioned having the same issue, and said “it was something with Manjaro, and switching to Ubuntu fixed it”. I asked them if they knew what the issue was, and still haven’t gotten an answer. I was wondering if anyone here would have the slightest idea what that “something” would be. I’ve seen people running Manjaro play the Vergil DLC with no problem and I basically have no idea where to go from here, any help is immensely appreciated. Thanks/sorry for wasting your time if this turns out to be something stupid that I missed, in advance.
The game has a Gold rating on ProtonDB as I’m sure you already know. You can even set the filters by Distro, CPU, GPU, etc. to see more related ratings.
Have you tried both steam-manjaro
(using the Steam Runtime) and steam-native
(using native libs)?
Please post your system info as outlined here:
Firstly, thank you for the reply! As for ProtonDB, I am aware of the filter options, but none of the reviews that are related to my specs mention the issue that I am having. As for running on steam-native
as opposed to steam-manjaro
, it yielded the same result. I updated the system info in my profile but was there anything you wanted me to post here?
inxi output
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=38955901-5fe5-4bbc-b10a-2a9013120bb5 rw quiet apparmor=1
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: MSI model: Z170A GAMING M5 (MS-7977) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.I0
date: 06/26/2018
RAM: total: 15.58 GiB used: 5.63 GiB (36.1%)
RAM Report:
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4200:4400 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 64026
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Gigabyte driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2182 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5")
s-diag: 692mm (27.3")
Monitor-1: DP-2 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.47 running: yes
Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:e0a1 class-ID: 0200
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel modules: wl
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
bus-ID: 1-8:2 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 7.3 TiB used: 800.4 GiB (10.7%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 61.2 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
rev: 1A01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate
model: One Touch HDD size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1707 scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.6 GiB (98.33%)
used: 800.4 GiB (85.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 38955901-5fe5-4bbc-b10a-2a9013120bb5
used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: FDB3-1171
ID-1: swap-1 type: file size: 8.03 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: vfat label: N/A
uuid: 6FD2-34C8
ID-2: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: vfat label: N/A
uuid: 848C-3BD8
ID-3: /dev/sdd1 maj-min: 8:49 size: 4.55 TiB fs: exfat label: N/A
uuid: 7F59-E792
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-8:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-11:3 info: Razer USA Cynosa Chroma type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:022a class-ID: 0300
Device-3: 1-12:4 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
Device-1: 2-1:2 info: Realtek Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 0bda:0307 class-ID: 0806 serial: <filter>
Device-2: 2-3:3 info: Seagate RSS LLC One Touch HDD type: Mass Storage
driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 0bc2:ab62 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C pch: 32.5 C mobo: 27.8 C gpu: nvidia
temp: 50 C
Processes: 288 Uptime: 26m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1914 pacman: 1898 lib: 534
flatpak: 0 snap: 16 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
