Hi,
I have a problem installing Epic Game Store via Lutris (I know there is Heroic (works fine for me), but I need to install RealityCapture and for that I need a luncher). After installing it, when I try to run it after a while it shuts down.
I also tried to install it on a virtual machine but when I switch to full screen the machine stops responding to the mouse after 3-5 seconds. The keyboard works but the mouse does not. In scaled or seamless mode it works, but in Epic I have a black screen for logging in, when I click on the settings icon I can see them normally. The black screen is only at login.
Thank you in advance for your help.
lutris-wrapper: Epic Games Store
Started initial process 18870 from gamemoderun /home/przemek/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine /home/przemek/dyski/gry/lutris/epic-games-store/drive_c/Program Files (x86)/Epic Games/Launcher/Portal/Binaries/Win32/EpicGamesLauncher.exe -opengl -SkipBuildPatchPrereq
Start monitoring process.
gamemodeauto:
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
info: Game: EpicGamesLauncher.exe
info: DXVK: v2.4.1
info: Vulkan: Found vkGetInstanceProcAddr in winevulkan.dll @ 0x6fa838c0
info: Built-in extension providers:
info: Platform WSI
info: OpenVR
info: OpenXR
info: OpenVR: could not open registry key, status 2
info: OpenVR: Failed to locate module
info: Enabled instance extensions:
info: VK_EXT_surface_maintenance1
info: VK_KHR_get_surface_capabilities2
info: VK_KHR_surface
info: VK_KHR_win32_surface
LogInit: Display: Loading text-based GConfig....
info: NVIDIA GeForce RTX 2060:
info: Driver : NVIDIA 550.144.3
info: Memory Heap[0]:
info: Size: 6144 MiB
info: Flags: 0x1
info: Memory Type[1]: Property Flags = 0x1
info: Memory Type[2]: Property Flags = 0x1
info: Memory Heap[1]:
info: Size: 23632 MiB
info: Flags: 0x0
info: Memory Type[0]: Property Flags = 0x0
info: Memory Type[3]: Property Flags = 0x6
info: Memory Type[4]: Property Flags = 0xe
info: Memory Heap[2]:
info: Size: 246 MiB
info: Flags: 0x1
info: Memory Type[5]: Property Flags = 0x7
info: AMD Radeon Graphics (RADV RENOIR):
info: Driver : radv 24.3.4
info: Size: 5422 MiB
info: Flags: 0x0
info: Memory Type[2]: Property Flags = 0x6
info: Memory Type[5]: Property Flags = 0xe
info: Memory Type[6]: Property Flags = 0xe
info: Memory Type[8]: Property Flags = 0xc6
info: Memory Type[10]: Property Flags = 0xce
info: Size: 10844 MiB
info: Flags: 0x1
info: Memory Type[0]: Property Flags = 0x1
info: Memory Type[3]: Property Flags = 0x7
info: Memory Type[4]: Property Flags = 0x7
info: Memory Type[7]: Property Flags = 0xc1
info: Memory Type[9]: Property Flags = 0xc7
info: Flags: 0x1
info: Flags: 0x0
info: Size: 246 MiB
info: Flags: 0x1
info: Flags: 0x0
info: Flags: 0x1
info: D3D11InternalCreateDevice: Maximum supported feature level: D3D_FEATURE_LEVEL_12_1
info: D3D11InternalCreateDevice: Using feature level D3D_FEATURE_LEVEL_11_1
info: Device properties:
info: Device : NVIDIA GeForce RTX 2060
info: Enabled device extensions:
info: VK_EXT_attachment_feedback_loop_layout
info: VK_EXT_conservative_rasterization
info: VK_EXT_custom_border_color
info: VK_EXT_depth_bias_control
info: VK_EXT_depth_clip_enable
info: VK_EXT_extended_dynamic_state3
info: VK_EXT_fragment_shader_interlock
info: VK_EXT_graphics_pipeline_library
info: VK_EXT_line_rasterization
info: VK_EXT_memory_priority
info: VK_EXT_non_seamless_cube_map
info: VK_EXT_robustness2
info: VK_EXT_shader_module_identifier
info: VK_EXT_swapchain_maintenance1
info: VK_EXT_transform_feedback
info: VK_EXT_vertex_attribute_divisor
info: VK_KHR_external_memory_win32
info: VK_KHR_external_semaphore_win32
info: VK_KHR_maintenance5
info: VK_KHR_pipeline_library
info: VK_KHR_present_id
info: VK_KHR_present_wait
info: VK_KHR_swapchain
info: VK_KHR_win32_keyed_mutex
info: VK_NV_descriptor_pool_overallocation
info: Device features:
info: robustBufferAccess : 1
info: fullDrawIndexUint32 : 1
info: imageCubeArray : 1
info: independentBlend : 1
info: geometryShader : 1
info: tessellationShader : 1
info: sampleRateShading : 1
info: dualSrcBlend : 1
info: logicOp : 1
info: multiDrawIndirect : 1
info: drawIndirectFirstInstance : 1
info: depthClamp : 1
info: depthBiasClamp : 1
info: fillModeNonSolid : 1
info: depthBounds : 1
info: wideLines : 1
info: multiViewport : 1
info: samplerAnisotropy : 1
info: textureCompressionBC : 1
info: occlusionQueryPrecise : 1
info: pipelineStatisticsQuery : 1
info: vertexPipelineStoresAndAtomics : 1
info: fragmentStoresAndAtomics : 1
info: shaderImageGatherExtended : 1
info: shaderClipDistance : 1
info: shaderCullDistance : 1
info: shaderFloat64 : 1
info: shaderInt64 : 1
info: variableMultisampleRate : 1
info: shaderResourceResidency : 1
info: shaderResourceMinLod : 1
info: sparseBinding : 1
info: sparseResidencyBuffer : 1
info: sparseResidencyImage2D : 1
info: sparseResidencyImage3D : 1
info: sparseResidency2Samples : 1
info: sparseResidency4Samples : 1
info: sparseResidency8Samples : 1
info: sparseResidency16Samples : 1
info: sparseResidencyAliased : 1
info: Vulkan 1.1
info: shaderDrawParameters : 1
info: Vulkan 1.2
info: samplerMirrorClampToEdge : 1
info: drawIndirectCount : 1
info: samplerFilterMinmax : 1
info: hostQueryReset : 1
info: timelineSemaphore : 1
info: bufferDeviceAddress : 0
info: shaderOutputViewportIndex : 1
info: shaderOutputLayer : 1
info: vulkanMemoryModel : 1
info: Vulkan 1.3
info: robustImageAccess : 0
info: pipelineCreationCacheControl : 1
info: shaderDemoteToHelperInvocation : 1
info: shaderZeroInitializeWorkgroupMemory : 0
info: synchronization2 : 1
info: dynamicRendering : 1
info: VK_AMD_shader_fragment_mask
info: extension supported : 0
info: attachmentFeedbackLoopLayout : 0
info: extension supported : 1
info: customBorderColors : 1
info: customBorderColorWithoutFormat : 1
info: depthClipEnable : 1
info: depthBiasControl : 1
info: leastRepresentableValueForceUnormRepresentation : 1
info: floatRepresentation : 0
info: depthBiasExact : 1
info: extDynamicState3AlphaToCoverageEnable : 1
info: extDynamicState3DepthClipEnable : 1
info: extDynamicState3RasterizationSamples : 1
info: extDynamicState3SampleMask : 1
info: extDynamicState3LineRasterizationMode : 1
info: fragmentShaderSampleInterlock : 1
info: fragmentShaderPixelInterlock : 1
info: VK_EXT_full_screen_exclusive
info: graphicsPipelineLibrary : 1
info: rectangularLines : 1
info: smoothLines : 1
info: VK_EXT_memory_budget
info: memoryPriority : 1
info: nonSeamlessCubeMap : 0
info: robustBufferAccess2 : 1
info: robustImageAccess2 : 1
info: nullDescriptor : 1
info: shaderModuleIdentifier : 1
info: VK_EXT_shader_stencil_export
info: VK_EXT_swapchain_colorspace
info: swapchainMaintenance1 : 1
info: VK_EXT_hdr_metadata
info: transformFeedback : 1
info: geometryStreams : 1
info: vertexAttributeInstanceRateDivisor : 1
info: vertexAttributeInstanceRateZeroDivisor : 1
info: maintenance5 : 1
info: presentId : 1
info: presentWait : 1
info: descriptorPoolOverallocation : 1
info: VK_NV_raw_access_chains
info: shaderRawAccessChains : 0
info: VK_NVX_binary_import
info: VK_NVX_image_view_handle
info: Queue families:
info: Graphics : 0
info: Transfer : 1
info: Sparse : 0
LogAnalytics: Display: [UnrealEngineLauncher.Release] APIServer = https://datarouter.ol.epicgames.com. AppVersion = 18.0.0-40242966+++Portal+Release-Live
LogWindowsDesktop: Warning: FDLLPointers() FPlatformProcess::GetDllExport(CFGDLLHandle, TEXT("CM_Get_Device_Interface_PropertyW") failed. A placeholder function that does nothing and reports failure will be used.
LogWindowsDesktop: Warning: FDLLPointers() CM_Get_Device_Interface_PropertyW will be a placeholder function that does nothing and reports failure.
LogWindowsTextInputMethodSystem: Display: IME system deactivated.
info: Memory type mask for sparse resources: 0x2
warn: DXVK: No state cache file found
info: DXVK: Graphics pipeline libraries supported
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/epic_logo.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Old/DashedBorder.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/cursor_grab.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/cursor_cardinal_cross.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/TrashCan.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/TrashCan_Small.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/Cross_12x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/denied_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_error_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_help_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_info_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_warning_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_Downloads_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Old/Menu_Background.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_undo_16px.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_redo_16px.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/Edit/icon_Edit_Copy_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/Edit/icon_Edit_Cut_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/Edit/icon_Edit_Delete_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/Edit/icon_Edit_Paste_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/Edit/icon_Edit_Duplicate_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/Edit/icon_Edit_Rename_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/PlusSymbol_12x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/ellipsis_12x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Old/ToolTip_Background.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Old/Border.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/eyedropper_16px.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_generic_toolbar.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_tab_toolbar_16px.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/toolbar_expand_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Old/Button.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Old/Menu_Background_Inverted_Border_Bold.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Old/Notification_Border_Flash.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/notificationlist_success.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/notificationlist_fail.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/OuterDockingIndicator.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/DockingIndicator_Center.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Tutorials/TutorialBorder.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Tutorials/TutorialShadow.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_tab_WidgetReflector_16x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/icon_tab_WidgetReflector_40x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/MessageLog/Log_Error.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/MessageLog/Log_Warning.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/MessageLog/Log_Note.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/BackIcon.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/NextIcon.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/CloseApp_Hovered.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/CloseApp_Pressed.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Icons/Empty_14x.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/ShowTabwellButton_Normal.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/ShowTabwellButton_Hovered.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/ShowTabwellButton_Pressed.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/CloseApp_Normal.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/Tab_Shape.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/Tab_Active.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/Tab_ColorOverlay.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/Tab_ColorOverlayIcon.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/AppTab_Inactive.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/AppTab_Active.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/AppTab_ColorOverlay.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/AppTab_ColorOverlayIcon.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/AppTab_Foreground.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/AppTab_Hovered.png' error.
LogStreaming: Warning: Failed to read file '../../../Engine/Content/Slate/Docking/AppTabContentArea.png' error.
LogStreaming: Warning: Failed to read file '../../Content/UI/Window/Icon_Info.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Social/SocialBang.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Social/Circle.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/CloudSave/Cloud.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/CloudSave/Machine.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Social/SocialCloseArrow.png' error.
LogStreaming: Warning: Failed to read file '../../Content/EcosystemStyle/secondary_btn.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Troubleshoot/back_arrow.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Troubleshoot/Grayed_check.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Troubleshoot/Green_Check.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Troubleshoot/Error_inline.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Troubleshoot/unfilled_check.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Troubleshoot/BlueCheck_header.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Troubleshoot/error_big.png' error.
LogStreaming: Warning: Failed to read file '../../Content/EcosystemStyle/primary_btn.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/epic.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-home.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-library.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-search.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-settings.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-social.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-store.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-download.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-profile.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-influencer.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/UE/PrimaryNavBar/nav-ue.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Social/SocialExpander_normal.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Social/SocialExpanderOpen_normal.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Social/WindowBorder.png' error.
LogStreaming: Warning: Failed to read file '../../Content/Enterprise/Vault/retry-icon.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Minimize.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Minimize_Hovered.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Minimize_Pressed.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Maximize.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Maximize_Hovered.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Maximize_Pressed.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Restore.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Restore_Hovered.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Restore_Pressed.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Close.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Close_Hovered.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New UI/Window/Close_Pressed.png' error.
LogStreaming: Warning: Failed to read file '../../Content/New Ui/Window/WindowOutline.png' error.
LogStreaming: Warning: Failed to read file '../../Content/UI/Library/EngineslotRemoveButton.png' error.
LogStreaming: Warning: Failed to read file '../../Content/EcosystemStyle/secondary_btn_hover.png' error.
