Entangle can't detect my camera
  Kernel: 5.18.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0 Desktop: GNOME v: 42.3.1
  Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
    serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <superuser required>
    UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
  ID-1: BAT0 charge: 43.8 Wh (99.1%) condition: 44.2/60.0 Wh (73.7%) volts: 17.1 min: 15.4
    model: Celxpert L19C4PC0 status: N/A
  Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
    rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
  Speed (MHz): avg: 1623 high: 2987 min/max: 1400/2900 boost: enabled cores: 1: 2041 2: 1397
    3: 1878 4: 1395 5: 1673 6: 1606 7: 1397 8: 1523 9: 1397 10: 1624 11: 1472 12: 1395 13: 1394
    14: 2987 15: 1397 16: 1397 bogomips: 92663
  Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia v: 470.129.06
    arch: Turing bus-ID: 01:00.0
  Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5.1 bus-ID: 05:00.0
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
  Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 driver: X:
    loaded: amdgpu,nvidia gpu: amdgpu resolution: 1920x1080~120Hz
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
    bus-ID: 05:00.6
  Sound Server-1: ALSA v: k5.18.12-3-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
    v: kernel port: 2000 bus-ID: 03:00.0
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
  IF: wlp4s0 state: up mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:3
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 476.94 GiB used: 282.43 GiB (59.2%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB temp: 39.9 C
  ID-1: / size: 459.72 GiB used: 282.31 GiB (61.4%) fs: ext4 dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 8.8 GiB used: 128.5 MiB (1.4%) dev: /dev/nvme0n1p2
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 40.0 C
  Processes: 379 Uptime: 50m Memory: 15 GiB used: 5.68 GiB (37.8%) Init: systemd Compilers:
  gcc: 12.1.0 clang: 14.0.6 Packages: 1601 Client: gnome-shell v: 42.3.1 inxi: 3.3.19
I have a Nikon Z50 and Entangle used to be able to detect the camera. After not using it for a long time, I tried using it again and now it just can’t see my camera. gphoto also can’t detect my camera.
A post was merged into an existing topic: Camera not detected
