Manjaro>Budgie>Dell Inspiron I3 7000
Tap to click works fine here BUT when I installed and use E24 (from the AUR) it does not work, even thought it shows as “enabled” in Settings.
Probably enlightenment not working well with libinput?
You can try setting it manually … or you could try replacing with xf86-input-synaptics
You mean enlightenment
0.24? It’s in the Arch community repo. Did you install enlightenment-git
from the AUR? Please don’t invent abbreviations and make people guess what you mean.
Touchpad module for Enlightenment is still on the ToDo…
For tap-to-click you can enable in /usr/share/X11/xorg.conf.d/40-libinput.conf
mine looks like this:
Section "InputClass"
Identifier "libinput touchpad catchall"
MatchIsTouchpad "on"
MatchDevicePath "/dev/input/event*"
Driver "libinput"
Option "Tapping" "True"
Option "TappingButtonMap" "lmr"
re-login and tap-to-click works
Worked! Thank you!
