Enlarge partition on SSD
Hello,
I want to enlarge the volume of partition /dev/sda5 ext4 (/,/run/timeshift/backup) with the volume of an unused partition.
How to realize this ?
Thanks in advance for your reply.
Best regards.
If it is a partition on a different device - you cannot.
If the unused partition is immediately adjecent to the right ot the partition you want to extend then you can.
Just open the partition manager - remove the unused partition and add the reclaimed space to the preceeding partition.
And please don’t forget your backup ! before resizing a partition.
